Passenger Side Water Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Topher, Feb 4, 2018.
  1. Feb 4, 2018 at 1:31 PM
    Topher
    Topher [OP] Member
    Cottage Grove, OR
    2018 TRD off road
    I have read every post about this issue and still not having any luck. The front and rear passenger side of the truck inside is pooling water . I removed the carpet on the passenger side, vacuumed the carpet and the water underneath. I sat in the truck with the carpet up with a sprinkler running and saw no water coming in from front or back. Ive checked the drain tubes up front, Sprayed the doors directly, back window. Any suggestions?
  2. Feb 4, 2018 at 1:36 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    check your grommets under the truck... they may be worn out
    check your door seals for rips / tears / dry rot...
    hopefully that fixes it
    DrFunker likes this.
  3. Feb 4, 2018 at 2:20 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Have you been running the AC?
  4. Feb 4, 2018 at 2:26 PM
    Topher
    Topher [OP] Member
    Cottage Grove, OR
    2018 TRD off road
    No AC has been off, water seems to be pooling up more in the back seat. Just went out and put a coat hanger up the drain tube and found nothing.
  5. Feb 4, 2018 at 2:57 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Do you have Front Mud flaps??? Bottom of door seal may be allowing splashing water between the door?
  6. Feb 4, 2018 at 5:29 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Is the headliner anywhere wet? Does it only happen after it's been raining or all the time? Do you run the HVAC system in the defrost position?
  7. Feb 4, 2018 at 8:26 PM
    Topher
    Topher [OP] Member
    Cottage Grove, OR
    2018 TRD off road
    It only happens when it rains. And yes I do run the HVAC in defrost most the time in the winter especially now because there is alot of condensation on the inside of the windshield. I've checked the headliner and is completely dry also up under the dash is completely dry.
  8. Feb 4, 2018 at 8:27 PM
    Topher
    Topher [OP] Member
    Cottage Grove, OR
    2018 TRD off road
    No I do not have mud flaps up front. I'll have to check that out.
  9. Feb 4, 2018 at 11:09 PM
    Earthnsurf
    Earthnsurf New Member
    2011 Tacoma TRD
    If you’ve had your windshield replaced ever, they often ruin the lower plastic seal while removing it. If there is any gap between the windshield and this strip, then you’ll need to somehow seal it. I used some black electrical tape just to eliminate it from the equation and bingo, no more pooling.
    Canufixit likes this.
  10. Feb 4, 2018 at 11:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Is the cabin air filter getting wet? If so it is the plastic cowling under the windshield allowing water to enter the air inlet under the cowling on the passenger side.
    Here is a picture of the inlet with the cowling lifted.
    ProfHobbit likes this.
  11. Feb 5, 2018 at 5:22 AM
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    Maybe your AC drip line is plugged...
    ChadsPride likes this.
  12. Feb 5, 2018 at 6:36 AM
    Topher
    Topher [OP] Member
    Cottage Grove, OR
    2018 TRD off road
    I didn't think of this I'll check it when I get home. Thank you
  13. Feb 5, 2018 at 6:38 AM
    Topher
    Topher [OP] Member
    Cottage Grove, OR
    2018 TRD off road
    I ran a coat hanger up the line didn't find anything. Thank you
  14. Feb 5, 2018 at 6:42 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Check to see if you have any water coming in from your rear sliding window.
  15. Feb 5, 2018 at 6:47 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    A service TSB bulletin regarding your issue.
    Basically, the trough drains for the sliding rear window plug up and overflow into the truck.
    T-SB-0134-10
    May 20, 2010
    Rear Window Water Leak
    Some 2005 - 2010 model year Tacoma vehicles may exhibit a condition where the interior carpet has become wet or water is found in the interior due to water draining into the cabin from the rear window. This can occur in heavy rain or a car wash if the rear window molding seal is covering the rear cab drain vents allowing water to enter the vehicle. Use the following repair information to correct this condition.
  16. Feb 6, 2018 at 6:31 AM
    hitech
    hitech Well-Known Member
    Blair
    Southern MD
    2014 MGM DCSB TRD Sport 4x4
    Just some dumb regular crap everyone else has
    If i run my defroster, my condensation hose drips. I believe that's how it's supposed to be, but I could be very wrong, i have been before.
  17. Feb 6, 2018 at 6:54 AM
    Jeffs68
    Stock
    You would be correct this time...
  18. Feb 6, 2018 at 7:39 AM
    Canufixit
    New England
    I believe I remember a thread(s) on this issue a while ago .... IIRC the water as getting behind the door seal way up high on the top/sides of the door seals and dripping down behind the door seals onto the floor. Front lower edge of passengers door was, I seem to remember a the water exit point.
  19. Jul 2, 2018 at 3:34 PM
    jtirwin27
    jtirwin27 2016 TRDOR4x4
    JT
    North Atlanta
    2016 TRD Off Road 4x4
    level kit, window tint, 285 series tire
    Any luck figuring our where your issue was? my 16 is doing the exact same thing and for the life of me I cant find the source. Its driving me crazy
    I had water pooled on my passenger floor only in the front. Not a lot, but enough to saturate the underlining and carpet. I checked my seals and everything is in great shape. AC drain is clear, cabin filter dry. No clue how to check the rear window though. I feel it may be that. Water can enter in one place and show up on complete other side so Im not ruling anything out
  20. Jul 2, 2018 at 3:40 PM
    Topher
    Topher [OP] Member
    Cottage Grove, OR
    2018 TRD off road
    No I never was able to find it.
