Passenger side wheel getting dirtier then the drivers side?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 043RZ, Mar 26, 2015.
  1. Mar 26, 2015 at 11:23 AM
    043RZ
    043RZ [OP] Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Im kind stupped on this one. It seems that my passenger side wheel gets god awful dirtier then the driver side front? When i first noticed this i checked to make sure that i didnt have a caliper hanging up. Drove in a straight line and applied the brakes and there is no pull to one side. I then pulled both front wheels and examined the brake pads for equal wear and they seem to be pretty close. Kinda stumped but if i had to diagnose this it seems that the passenger side is doing more of the braking then the driver side. Any imput to checking my calipers to be sure they are both equally sharing the braking load?
  2. Mar 26, 2015 at 11:37 AM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    May not be braking any harder one side or the other, just the pad itself isn't manufactured the exact same. Might be the same brand and all but just so happens the chemicals and raw goods in the one pad is ever so slightly different than the other, causing more dust...
  3. Mar 26, 2015 at 5:05 PM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    Yea everything else checks out, my last thought was slightly more brake drag (self drying) on the passenger side then the drivers side.
  4. Mar 26, 2015 at 5:10 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Passenger side wheel is closer to the edge of the road and dirt there. Perhaps that explains it?
  5. Mar 26, 2015 at 9:56 PM
    roehoe72
    roehoe72 Well-Known Member
    Dan
    Vacaville, CA
    04 dc prerunner v6 trd
    Sub'd for exact problem. I get more BRAKE DUST on pass front. Just did new pads, calipers, rotors at the end of 2012. Couldnr be more than 20k give or take. Just fwiw, i HAVE not inspected mine yet...
  6. Mar 26, 2015 at 10:47 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
  7. Mar 27, 2015 at 6:12 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Any free range dogs in your area?. There piss is dirt velcro. Once they mark your wheel,,it's a free-for-all for the next pooch.
  8. Mar 27, 2015 at 8:55 AM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    Nope non that I know of... But nothing a .357 mag cant take care of :rolleyes:..... I'm kidding calm down :p
  9. Mar 27, 2015 at 8:59 AM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    But honestly im stumped on this one. Cosmicfires may have a point. I remember when I went to put my rolled in bed liner in I had a spot of rust where the sheet metal overlapped and spot welded. I asked my auto body guy about it and he says he's sees this alot that the passenger side seems to get the brunt of where and tear cuss its closer to the edge of the road
  10. Mar 27, 2015 at 9:02 AM
    roehoe72
    Dan
    Vacaville, CA
    If that was true, wouldn't you notice that on all cars? Mine squeeks a wee bit when i first use the breaks. Just upgrade to a tundra swap
  11. Mar 27, 2015 at 9:47 AM
    CR, WA
    stock
    Does the county use the liquid road de-ice?. That also will turn into a brake dust/dirt glue on the wheel,,and vehicle.
  12. Mar 27, 2015 at 10:31 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The spoke design of some wheels can act like the blades of a fan. If one forced air "in" on the driver side, the same wheel would tend to blow "out" on the pass side (opposite rotation) carrying brake dust with it.
  13. Mar 27, 2015 at 3:46 PM
    roehoe72
    Dan
    Vacaville, CA
    That's a very interesting theory. Wonder if it holds water. Im sure mine is mechanical, cause as stated above, it sgueeks every other time i use the brake. Seems to be when mostly hot. Not very loud, or long.
  14. Mar 28, 2015 at 5:36 PM
    Larrys 02 Tacoma
    Larrys 02 Tacoma Member
    Lawrence
    Santa Maria, CA
    02 Prerunner Stnd Cab
    The brakes wear slightly faster on the curb side as well, due to the additional dust/dirt or whatever.
  15. Mar 29, 2015 at 5:10 AM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    What would be the reason for that?
  16. Mar 30, 2015 at 12:00 PM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    /\ more dust/debris on the edge of the road (passenger side) due to the crowning of the pavement to help rainwater get channeled to the curb, into a storm drain and off of the primary driving surface.
  17. Apr 9, 2015 at 5:29 PM
    comatosed
    comatosed Well-Known Member
    Central Florida
    Silver TRD Sport
    TRD roof rack, Roof Basket, Weather Tech liners, Wet Okole seat covers, bed mat, AFE Pro Dry Filter, Eclipse AVN726E dvd/nav, kicker door speakers, 8" kicker sub & amp, fox 2.0 coil overs, moab 2.0 front bumper, Full CBI Skid Set, CBI Offroad rear Bumper, CBI Sliders, BFG AT KO 2, Leer Topper setup for camping. Other mods-full synthetic, carbon filter, de-badged, center console lock.
    There may be a bigger issue I'm still trying to figure this out as well. UP until 1.5 months ago I had even amount of grime on the front wheels build up. Now my passenger side is getting way dirtier after I had my front diff replaced. It not only is dirtier than the driver side but it is happening 4x quicker than it used to get that dirty.
  18. Apr 11, 2015 at 3:27 PM
    comatosed
    Central Florida
    Silver TRD Sport
    Well I had a inner pad that was almost totally worn out, and had chunks missing, I'm thinking the caliper was stuck/sticking. I went ahead and put in all new rotors, calipers, and pads, and it seems ok!
