Passenger tail light not working help....
Discussion in 'New Members' started by Tkirkland31, Feb 12, 2023.
  1. Feb 12, 2023 at 10:32 AM
    Tkirkland31
    Tkirkland31 [OP] New Member
    Tyler
    2003 tacoma 3.4 4wd 5speed
    6 inch lift 37s
    New harness from rear shackle back new bulbs new tail lights all lights function as should but my passenger tail light is the only light not working I have power at the driver side jumper connector but also noticed my passenger side licsence plate light is not working tried swapping bulbs to to driver side bulbs work in desperate need of help with this if anyone has any input please also checked fuses put all new fuses in too
  2. Feb 12, 2023 at 10:36 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    So the brakelight works on pass. side? And blinker? if not it's prob. ground. Power at bulb base?
  3. Feb 12, 2023 at 10:38 AM
    Tkirkland31
    Tyler
    6 inch lift 37s
    Yes brake light works turn work and reverse all work just not tail light im not the best at electrical stuff so if there are any grounds in the rear idk where it be located to check
  4. Feb 12, 2023 at 10:42 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Use the test light (or any 12V light) to check the bulb sockets for power. You'll get the hang of it. The shell of the socket is grounded, The lead poles IN the socket should supply power.
  5. Feb 12, 2023 at 10:53 AM
    Tkirkland31
    Tyler
    6 inch lift 37s
    I'll check when I get back home but just a ? If my brake light is working but not tail light the socket should be getting power rite? Or no?
