Passenger temp climate control knob issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 09facivicsi, Nov 1, 2016.
  1. Nov 16, 2016 at 7:05 PM
    #41
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    This happened on a test drive tacoma I drove and almost bought.
    It was also a problem on a limited loaner I got when my truck was in for service. So, its probably fairly common but not normal. They should fix it for you.
    side note: the limited loaner also had a terrible diff howl, rumble strip vibe stopping, and the shift knob was completely loose. (All characteristics of the vehicle) GG toyota
  2. Nov 16, 2016 at 7:20 PM
    #42
    jmdwifi
    jmdwifi My Inferno
    Fredericksburg, Virginia
    See profile
    I noticed mine today. I have 1800 miles on it. They will replace it I hope.
  3. Nov 25, 2016 at 7:28 PM
    #43
    gr0ver
    gr0ver Taco Supreme
    Charleston, SC
    2017 MGM Tacoma TRD Sport 4x4 DCSB Manual
    So just to let everyone know, the dealer replaced mine in 0.4 rated hours, so I was able to drop off and pickup same day dropping it off around noonish and picking up at 7. They had quoted me a longer time thinking they would have to disassemble the dash assembly some, but I believe they only had to pry it out since I can see a couple points they had to get into to pop it out. Nothing a little elbow grease can't fix! Everything seems to work fine though, so I'd let the dealer whip a new one in for you if you don't mind being without a truck for an afternoon.
    09facivicsi[OP] likes this.
  4. Nov 25, 2016 at 8:41 PM
    #44
    Hank Heel
    Hank Heel Well-Known Member
    WA
    I'll have to work my knob a bit and see if it gets hard..
    gr0ver likes this.
  5. Nov 25, 2016 at 9:10 PM
    #45
    gr0ver
    gr0ver Taco Supreme
    Charleston, SC
    Don't try to hard, it might get everywhere.
    Hank Heel[QUOTED] likes this.
  6. Nov 26, 2016 at 6:49 AM
    #46
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
    Yes, I noticed the same thing, it feels like it gets tight and then smooths out again.
  7. Dec 18, 2016 at 7:25 PM
    #47
    NTSALL4
    NTSALL4 Active Member
    2016 TRD
    Took mine is for same problem at 5k service dealer replaced entire panel passenger side really stiff.
  8. Dec 18, 2016 at 8:00 PM
    #48
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
  9. Dec 18, 2016 at 8:10 PM
    #49
    InfernoSTi
    InfernoSTi Active Member
    USA
    2016 Quicksand Tacoma 4x4 TRD OR DC SB
    KO2 265/75R16
    Mine is different on each side (normal on the driver side). Will bring it up at the next service...
  10. Dec 18, 2016 at 8:57 PM
    #50
    thechadd3
    thechadd3 Well-Known Member
    16 Inferno DCSB MT TRD Sport
    Same issue, bringing it up at 10k service on tuesday
  11. Dec 19, 2016 at 6:14 AM
    #51
    09facivicsi
    09facivicsi [OP] Well-Known Member
    ATL
    2016 Inferno TRD Sport DCSB Tech
    17"TRD Pro Wheels, TRD Pro Grill
  12. Dec 19, 2016 at 4:05 PM
    #52
    Marvelousone
    Marvelousone Well-Known Member
    San Francisco CA
    2017 DCSB Sport
    I have a 2017 and im having the same issue on the passenger knob.
  13. Dec 23, 2016 at 6:19 PM
    #53
    thechadd3
    Dealer said it's not a problem that they have seen before but ordered me a new HVAC control unit. Called me 2 days later and said the part was in a ready to be installed and I'm having it put in on Tuesday. I'm anxious to see if there's a difference. Mine was only noticeable when it was cold out. Luckily the morning of my 10k service it was 10 below.
    09facivicsi[OP] and shakerhood like this.
  14. Dec 24, 2016 at 7:39 PM
    #54
    NTSALL4
    2016 TRD
    Got my whole panel replaced took 1.5 at dealer.
  15. Dec 25, 2016 at 7:59 AM
    #55
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    My two knobs have the same resistance when turning. I normally leave it in sync, but now have them operate separately to see how they both hold up while under warranty.
  16. Oct 19, 2017 at 9:03 AM
    #56
    09facivicsi
    ATL
    Finally took it to toyota after 15k miles and they'll fix it. They are ordering a new control panel.
  17. Oct 19, 2017 at 9:29 AM
    #57
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Same here - my passenger knob is a little harder to turn than driver side, but I don't use it much. And yes, why the heck is level 3 on heated seats like sitting on the sun, but 1 and 2 don't do anything. I wish there was a way to decrease the heat on third setting and increase the heat on second setting
  18. Oct 19, 2017 at 10:22 AM
    #58
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    Have we found out if there is a way to install this on a TRD Sport that doesn't have the feature?
  19. Oct 19, 2017 at 10:35 AM
    #59
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Mine seat heaters work just fine.
    3 - sitting in hot coals
    2 - hot but tolerable
    1 - warm and cozy
  20. Oct 19, 2017 at 10:49 AM
    #60
    ratcityrain
    Seattle, WA
    Maybe I better have Toyota look at it. 1 and 2 are basically useless and I don't feel them at all. 3 - hot lava like you said.
