Passenger window malfunction?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patricknola, Dec 11, 2022.
  1. Dec 11, 2022 at 8:13 AM
    patricknola
    patricknola [OP] Member
    Patrick
    2019 Toyota Tacoma TRD Pro
    Lifted
    Hey Guys, I've got a 2019. Trd pro, when I hit the passenger window button to raise/close the window the window raises half way and then opens/goes down all the way. I have to keep hitting the button and after 5 or 6 attempts the window will close. What gives?
  2. Dec 11, 2022 at 8:16 AM
    Sierrahunter
    Sierrahunter Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    It's broken.
    RIX TUX likes this.
  3. Dec 11, 2022 at 8:32 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Probably needs realigned, set back in it's track, or cleaned/greased. Something is physically resisting the lift mechanism and it's tripping the safety circuit, aka, the "dumb and dumber" auto-retract.
    I'd pull the door card and see if there's anything obviously wrong or blocking the window path.
    Chew, Skydvrr and Tacospike like this.
  4. Dec 11, 2022 at 8:59 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Did you by chance install In-Window Channel Rain Guards? If so, are they correctly installed?
    hiPSI likes this.
  5. Dec 11, 2022 at 9:53 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Some Toyota vehicles have a reset procedure. Does it do it on the pass side door switch or just on the driver's side?
    kahanabob likes this.
  6. Dec 11, 2022 at 11:20 AM
    patricknola
    Patrick
    Lifted
    I just bought this truck but it does have In-Window Channel Rain Guards, I'll have to check it out. It just occurs on the passenger side not the driver side.
  7. Dec 11, 2022 at 11:58 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    someone here should chime in on how to re set it.
  8. Dec 11, 2022 at 12:15 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    What brand? Do the extend all the way down, in front by mirrors. Weathertech extend down, if so that would be your problem. The tight fit is causing window to go back down.
  9. Dec 11, 2022 at 12:21 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Take it out. See if it still does it.
    wilcam47, Chew and na8rboy like this.
  10. Dec 11, 2022 at 1:35 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    rip them all off and sell them on the AARP website
    wilcam47 likes this.
  11. Dec 11, 2022 at 3:22 PM
    VaToy
    Parts Unknown
    Which door switch? Does it do it on the pass side door switch?
  12. Dec 11, 2022 at 4:39 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
