passing wires through firewall
Discussion in 'Lighting' started by WYOTAC, Feb 28, 2011.
  1. Feb 28, 2011 at 7:15 AM
    WYOTAC
    WYOTAC [OP] Well-Known Member
    Joel
    Santa Barbara
    06 AC TRD OffRoad Desert Sand
    ICON 2.5 with JBA UCA, OME Dakar
    I'm trying to get my Hella 500's wired up, but I can't seem to figure out how to send the wires through the firewall to my switch. I've located a rubber plug with a bunch of wires going through it on the floor behind the clutch. The clutch however, is making it difficult for me to tinker around up there and figure it out. Anyone have any pointers?
  2. Feb 28, 2011 at 7:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    There are other rubber grommets you can pass the wires thru, if that one is overcrowded.
  3. Feb 28, 2011 at 7:19 AM
    WYOTAC
    Joel
    Santa Barbara
    Now do you have to pop the grommet out or just "smash" the wires through?
  4. Feb 28, 2011 at 7:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I useually poke a small hole tru it first, then push the wire thru. I use a lond peice of bailing wire, and tape the wires Im gonna use to it. Then, after I push the bailing wire thru, I pull the wires thru from the other side.
  5. Feb 28, 2011 at 7:27 AM
    WYOTAC
    Joel
    Santa Barbara
    Ok.. that makes sense. I suppose that way it still creates a fairly tight seal around the wires. I guess I'll look around and see if I can find a more accessible spot to send them through.
  6. Feb 28, 2011 at 7:37 AM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    yup. i use a straightened coathanger and tape the wire to the hanger on one end, so when you push the hanger through the wire goes with it. its a tight fit, but you can make it work
  7. Feb 28, 2011 at 7:40 AM
    Special_K
    Special_K o_o
    Eddie
    Alexandria, VA
    2019 Tacoma Cav Blue
    x2 on the coathanger
  8. Feb 28, 2011 at 7:44 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
  9. Feb 28, 2011 at 7:54 AM
    WYOTAC
    Joel
    Santa Barbara
  10. Feb 28, 2011 at 12:44 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Yep, I used the same place as netmonkey. Poke the hanger through, tape the wires and pull! Just tape it up real good. You could even make a U at the wire end, so that they "hook" each other, and pull it through. It'll make it a little tougher since its now thicker, but still works. Either way, you'll be good though.
  11. Feb 28, 2011 at 12:47 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    make sure you tape up any connections you make with electrical tape. had one wiggle lose on me the other day:cool:
