Past time to do my timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grocko, Sep 26, 2024.
  1. Sep 26, 2024 at 3:53 PM
    Grocko
    Grocko [OP] Active Member
    Greg
    2004 tacoma 4 door v6 trd
    I have an 04 tacoma TRD 4 door, 6cyl. With 139k. I'm missing my original hood. Would appreciate help figuring out engine number and a good source for the kit. I see the the tkt -026 basic kit on Amazon, and OEM kits on Ebay. Would like to be certain these are the correct ones. Thank you.
  2. Sep 26, 2024 at 4:36 PM
    DoktorSlowburn
    DoktorSlowburn Well-Known Member
    Escondido, CA
    1997 White Tacoma SR5
    4runner seats and center console, ARB rear locker, Icon 1.5” AAL, Bilstein 5100 on 4th notch in front (to support future tube bumper & future winch), 4600s in the rear. In-Cab CB radio. Hella 500 Driving lights. All-Pro Baja front bumper.
    For timing I wouldn’t use anything but OEM, meaning Aisin. Go to RockAuto, they sell the Aisin kit for a good price, TKT025.
    Do not skip the tensioner either. Thats what I’m replacing this weekend. Previous owner did the timing belt & pulleys but not the tensioner… why they skipped a $50 part I’ll never know, but now I basically have to do the whole job over again just for the tensioner.
  3. Sep 26, 2024 at 4:41 PM
    Grocko
    Greg
    Thank you for the quick reply, is there anything else I need to know about my engine to be certain the tkt025 is correct?
  4. Sep 26, 2024 at 4:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Aircabinman is the go-to for kits if you're going the Ebay route
    100% genuine OEM and he bundles stuff pretty well
    DoktorSlowburn likes this.
  5. Sep 26, 2024 at 4:43 PM
    DoktorSlowburn
    Escondido, CA
  6. Sep 26, 2024 at 4:44 PM
    Grocko
    Greg
    Thanks
  7. Sep 26, 2024 at 4:55 PM
    Grocko
    Greg
    Thanks, I will.
  8. Sep 26, 2024 at 6:57 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Yotashop.com. They have everything you need including OEM parts. Out of Washington state.
  9. Sep 26, 2024 at 7:43 PM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
    What is the issues with the tensioner?
    I am ticking near 360k on original tensioner with no issue that I am aware of? Will it start making a noise or something
    I did get a new OEM one in case its needed next down the road but don't recall that being a 50$ part from the YOTA dealershop on the 40 discount on MSRP
  10. Sep 26, 2024 at 7:45 PM
    Grocko
    Greg
    Thanks, i sent them an email
  11. Sep 26, 2024 at 7:48 PM
    DoktorSlowburn
    Escondido, CA
    I posted a video in another thread I started, take a listen. Sounds like something slapping under the timing cover. I wrote it off originally as just old engine sound but I’m glad I asked the forum.
    Edit: here’s a direct link
    https://youtube.com/shorts/5FqVUZCwtMU?si=cZfKUtsMkqc20k5x
    Black97v6MT[QUOTED] likes this.
  12. Sep 26, 2024 at 7:55 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    AISIN kit from rockauto. I've installed at least a dozen of them and have had no issues on my cars or friends or customers. That goes for 3.4L 5vz, 3.3L 3mz and 4.7L 2UZ.
    JustADriver and DoktorSlowburn like this.
  13. Sep 27, 2024 at 8:04 AM
    Grocko
    Greg
    Do you do always do cams and crank seals by default?
  14. Sep 27, 2024 at 8:14 AM
    Superdave1.0
    SoCal
    No. If they are leaking or seeping then I would.
  15. Sep 27, 2024 at 10:32 AM
    d33pt
    d33pt Well-Known Member
    Is that because disturbing them might cause them to leak later?
  16. Sep 27, 2024 at 12:03 PM
    Superdave1.0
    SoCal
    A little of that. Also depends on the mileage and vehicle age. If this is a sub 200k mile engine, I'm not swapping them unless leaking. A 300k mile engine I would definitely recommend it.
  17. Sep 27, 2024 at 12:12 PM
    Grocko
    Greg
  18. Sep 27, 2024 at 12:23 PM
    d33pt
    I have an 01 with 180k miles on it. Almost time to tear into the timing belt and I'll have to decide whether to replace those seals or not. I'm kinda in agreement with you, no leaks then leave it alone. But the next time I do that belt would probably be in another 15 years. So what would you do, assuming it's not leaking right now?
  19. Sep 27, 2024 at 12:26 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Replace them. It's easy to do.
  20. Sep 27, 2024 at 4:38 PM
    CD20H
    Ben
    North Texas
