Payload Concerns w/ Truck Cap and Rooftop Tent
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BoulderT4R, May 4, 2025 at 4:34 PM.
  1. May 7, 2025 at 7:17 AM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    bandaids... over wight is over weight. for some reason guys think these trucks are 1/2 or 3/4 ton trucks. they are super (actually pathetically) light duty. built to look like a truck and use as a truck for the occasional trip to home Depot.
    Willy Lump Lump likes this.
  2. May 7, 2025 at 7:19 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Toyota Super light Duty, I like it!
  3. May 7, 2025 at 7:20 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Where my truck goes a full size won't fit. So yeah some of us need a smaller package and make it work. We're not all pavement queens.
    71tattooguy likes this.
  4. May 7, 2025 at 7:21 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    So, you’re saying our trucks were built for Instagram only?
    Veet-88 likes this.
  5. May 7, 2025 at 7:21 AM
    Off Topic Guy
    story of my life :cheers:
  6. May 7, 2025 at 8:33 AM
    Veet-88
    It's funny I have over 210k and do more truck stuff than most full sizes do and run over loaded most of the time. Yet I have had minimal failures from actual Toyota parts. Aftermarket yep there's been issues.
  7. May 7, 2025 at 8:28 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I may be wrong, but the Tacoma is technically a 1/2 truck...
  8. May 7, 2025 at 8:31 PM
    RyanDCLB
    4/19 DCLBOR
    I haven't had any issues from Toyota, or aftermarket parts, only positive experiences. :notsure:
    :anonymous::lalala:
    For the record, this is not a stock Tacoma and all stunts were performed at an off-road course under a controlled environment
    Bonus pictures of the camper and the trailer.
  9. May 7, 2025 at 9:25 PM
    Veet-88
    Spc ucas dead in 8k
    Bent drivers side tie rod "given the situation at the time I won't fault it.
    2 sets of lca's one was siezed cam bolts second setting was warranty from dead ball joints.
    One front wheel bearing
    2 cv boots
    Trashed elka 2.0's all around including one snapped shaft.
    1 set of bed bars cracked all 4 elbows
    Finish on a prinsu rack failed horribly within a year.
    I think that's it. The truck see's alot of gravel roads and that washboard takes its toll and a fair amount of trail days. I don't abuse the truck but it gets used.
    71tattooguy and RyanDCLB[QUOTED] like this.
  10. May 7, 2025 at 9:29 PM
    RyanDCLB
    4/19 DCLBOR
    You got that right! :thumbsup:
  11. May 7, 2025 at 9:36 PM
    MGMDesertTaco
    I'm surprised you haven't broken the bed outlet cover dumping all that debris. I usually rent a truck from hd or uhaul with insurance for that kind of abuse.
    RyanDCLB[QUOTED] likes this.
  12. May 7, 2025 at 9:51 PM
    RyanDCLB
    4/19 DCLBOR
    The bed outlet cover is doing great:thumbsup:
  13. May 7, 2025 at 9:56 PM
    RyanDCLB
    4/19 DCLBOR
    I have the dirt king upper control arms, so far so good. Also, the war fab tie rod sleeves seem to help out. No problems with the lower control arms or cv boots. I went with Dobinson's over Elka :thumbsup:
    Full disclosure, I did replace one front wheel bearing with full Toyota replacement, but that's it! And, The poly bushings in the upper control arms are ready to be replaced, but I'm replacing them with the new TRD upper control arms. Other than that, nothing. The truck is an absolute complete unit.
  14. May 8, 2025 at 7:09 AM
    Veet-88
    I replaced the spc's with dirt kings and couldn't be happier 2 years later. Not ideal for tire clearance but the just work. The 2.0 elkas were apparently known for failure if you beat on them. Replaced with 2.5 dsc fronts and 2.5 rears and they have been solid. Buddies mrr set lasted about as long as my 2.0's
