payload increase
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blue_tacoma, Apr 18, 2010.
  1. Apr 18, 2010 at 11:52 AM
    blue_tacoma
    blue_tacoma [OP] Member
    Ontario, Canada
    05 TRD SPORT
    3" Toytec AAl with 884 coils AFE Pro dry CAI Magnaflow Cat-back exhaust
    Hey, I am new to the site. I have a 05 tacoma double cab TRD sport. and i have noticed that it only has 3 leafs total in the rear. and the newer years have 4. Are all 2005 models this way?
    Also, i am installing a toytec 3" lift, AAL in the rear and new coils for the front. Anyone know what kind of payload increase this will give? Thanks
  2. Apr 18, 2010 at 11:57 AM
    05offroad
    05offroad Well-Known Member
    Michael
    El Cajon, California
    '05 Long Travel Prerunner
    I've lost track
    All 2005 models come that way but there is a tsb (toyota service bulletin) to fix it. Since you're a 2005 it wont be under warranty...but an aal is pretty much the same thing. You will have a higher payload not sure how much though. Someone else will chime in in that...
  3. Apr 18, 2010 at 12:02 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Odds are that the AAL will give you exactly what Toyota advertises (1500 lbs hauling, 6500 towing - if I remember correctly). The reason for the free 4th leaf was that Toyota designed the truck to haul less than advertised and had to install (for free to those who asked for it) the 4th leaf to meet their advertising claims.
    I had the 3 leafs, added the 4th TSB leaf then went to the OME 7 leaf pack... if you don't go at least with the OME, or equivalent, you won't gain much capacity at all.
  4. Apr 19, 2010 at 11:12 AM
    blue_tacoma
    Ontario, Canada
    05 TRD SPORT
    Thanks for the quick reply, do you know if the toyota service bulletin applies in Canada? Do you go into the dealership and request it?
  5. Apr 19, 2010 at 4:09 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    They expire at 3 years/36000 miles. If it's for your '05, you're too late for the TSB. I don't know that the TSBs are the same in Canada.
  6. Apr 19, 2010 at 4:50 PM
    JKD
    JKD Well-Known Member
    TSBs do not expire.
    Warranty coverage expires. If you need a repair covered by a TSB prior to your warranty expiring, it will likely be covered. If it is after your warranty expires, the repair will likely not be covered (you can pay for it).
  7. Apr 19, 2010 at 4:56 PM
    Evil Monkey
    Robert
    Escondido, CA
    Semantics. He still doesn't qualify.
  8. Apr 19, 2010 at 5:20 PM
    rmerchant3
    rmerchant3 Insert nonsense here
    Are we positive that this is covered under the comprehensive warranty and not the Powertrain warranty? 5year 60K? You would be surprised at some of the things covered in powertrain that you wouldn't even think had to do with it.
    And what years is this TSB for exactly
  9. Apr 19, 2010 at 6:34 PM
    Evil Monkey
    Robert
    Escondido, CA
    We are. It states in the TSB which warranty and for which trucks it applies:
    This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for
    36 months or 36,000 miles, whichever occurs first, from the vehicle’s in-service date.​
    http://www.divshare.com/download/4099479-cf6
