PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. Jan 6, 2014 at 7:38 PM
    #2281
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Ya painted mine all black. So I basically have my entire headlight blacked out except the amber reflector.lol
  2. Jan 6, 2014 at 7:39 PM
    #2282
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Haha same here :cool:
    I still need to change my running light bulb for either an amber bulb or amber led. It looks very white/yellow with my halos and HID's
  3. Jan 6, 2014 at 7:41 PM
    #2283
    tacodane
    Dane
    I have some in but they suck so I will be getting new ones real soon. Where you going to get them from?
  4. Jan 6, 2014 at 7:44 PM
    #2284
    PcBuilder14
    Brent
    Nor Cal
    If I just change out my normal ones for orange I'll just pick up some from the local autozone. If I go LED I'll order some from superbrightleds.com
  5. Jan 6, 2014 at 7:45 PM
    #2285
    tacodane
    Dane
    Yaa. I like my LEDs
  6. Jan 6, 2014 at 7:45 PM
    #2286
    saltus25
    saltus25 Well-Known Member
    Graydon
    Angleton,TX
    Flowmaster American Thunder Exhaust, K&N intake, OME 3" lift, Pro Comp Extreme MT2 tires, Mickey Thompson Classic II Wheels, Spidertrax 1.25" wheel spacers, URD short throw shifter, KC 100 watt lights, custom steel mesh grill, halo headlights, Rigid Industries Dully's, SOS Offroad Concepts front bumper, SOS Offroad Concepts custom rear bumper, All Pro and BAMF skids
    I thought there was a way to just change out the led bulb in the halo?
  7. Jan 6, 2014 at 7:46 PM
    #2287
    tacodane
    Dane
    Yours are ccfl is just a bulb. The one he uses are LED rings.
  8. Jan 6, 2014 at 7:48 PM
    #2288
    saltus25
    Graydon
    Angleton,TX
    I didn't realize you put the retro fit in the stock housings. I thought they were full aftermarket.
  9. Jan 6, 2014 at 7:49 PM
    #2289
    saltus25
    Graydon
    Angleton,TX
    Gotch ya
  10. Jan 6, 2014 at 7:49 PM
    #2290
    tacodane
    Dane
    No we retrofitted ours 6upehavu_b49740d12ddf1bbbfaceb2a4e8fc74e25e49679b.jpg
  11. Jan 6, 2014 at 7:51 PM
    #2291
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I want to switch my blinkers to LED but it's a very tight fit with the length of the stock bulbs. I'll have to do some measuring before I order and LEDs
    Nope. CCFL is like old neons on cars. It's essentially a gas. You'll have to completely remove the CCFL halo and install and LED halo
    Nope. Stock housings with a retrofit kit installed in them.
  12. Jan 6, 2014 at 7:53 PM
    #2292
    tacodane
    Dane
    Ya same mine are a type fit as well. Oh also where do you have your ground points for the retro?
  13. Jan 6, 2014 at 7:54 PM
    #2293
    saltus25
    Graydon
    Angleton,TX
    OK. Damn that seems like a huge pain in the ass and a lot of room for screw up.
  14. Jan 6, 2014 at 7:55 PM
    #2294
    tacodane
    Dane
    Yes very. Especially an after market housing
  15. Jan 6, 2014 at 7:56 PM
    #2295
    PcBuilder14
    Brent
    Nor Cal
    One ground is directly to the battery, the other is at a bolt that attaches the fender to the body.
    It seems that way, but it's not as bad as many think. Just time consuming. If you still have your stock housings, I suggest you retrofit them with a kit from theretrofitsource.com
  16. Jan 6, 2014 at 7:56 PM
    #2296
    saltus25
    Graydon
    Angleton,TX
    Well thanks for the input. Glad I found out now rather then later.
  17. Jan 6, 2014 at 7:59 PM
    #2297
    saltus25
    Graydon
    Angleton,TX
    Naw I sold them. These are my third set of headlights if you count the stock set. If had bad luck with water leaking in. I could have fixed the issues I had with the last set but I don't have an oven to bake them in. Haha
  18. Jan 6, 2014 at 8:00 PM
    #2298
    PcBuilder14
    Brent
    Nor Cal
    I don't have an oven either. I just used a heat gun. took about an hour per headlight.... Haha
  19. Jan 6, 2014 at 8:02 PM
    #2299
    saltus25
    Graydon
    Angleton,TX
    Yeah I'm not that ambitious yet.
  20. Jan 8, 2014 at 5:58 PM
    #2300
    PcBuilder14
    Brent
    Nor Cal
    Got my custom Bussmann relay/fuse block ordered! Need to order a breaker switch now...
