PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. Feb 15, 2014 at 9:50 PM
    #3001
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    So my friend that was helping me and letting me use his garage couldn't sleep. He just called me saying he got the leafs flipped around and everything bolted back on. All that's left to do tomorrow is re-connect the driveshaft and u-joint, install the shocks, and bleed the new brake line! :goingcrazy:
  2. Feb 15, 2014 at 9:52 PM
    #3002
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Tell him to finish
  3. Feb 15, 2014 at 9:55 PM
    #3003
    PcBuilder14
    Brent
    Nor Cal
    Haha nah he went to bed.
    Is came apart when we pulled the axle back to try to bolt it to the leafs when they were backwards. I marked it with a sharpie just in case it happened though because people warned me that it might fall out.
  4. Feb 15, 2014 at 10:12 PM
    #3004
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Haha awesome! That's a good friend right there.
  5. Feb 15, 2014 at 11:17 PM
    #3005
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    18x12 FTMFW
  6. Feb 15, 2014 at 11:24 PM
    #3006
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Do you have to disconnect brake line? Id rathet not bleed brakes...
  7. Feb 15, 2014 at 11:32 PM
    #3007
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Yee
  8. Feb 16, 2014 at 5:36 AM
    #3008
    PcBuilder14
    Brent
    Nor Cal
    You're telling me! I owe him when it comes time to put on his suspension! Haha
    No... Haha
    I haven't dicsonnnecting anything but one tab so far, and it wasn't for the brake line. But I'm going to put on an extended line before I flex anything. I'm not 100% sure if you'll need one, but it couldn't hurt.
    I've been checking every time we raise the truck away from the axle, and the brake line has been fine so far :notsure:
    :facepalm:
  9. Feb 16, 2014 at 5:48 AM
    #3009
    PcBuilder14
    Brent
    Nor Cal
    My dumb mistake from yesterday haha
  10. Feb 16, 2014 at 5:57 AM
    #3010
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Didn't drain any fluid when that happened did it?
  11. Feb 16, 2014 at 6:00 AM
    #3011
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    The driveshaft has a splined slip joint on the shaft. It just pulled apart
  12. Feb 16, 2014 at 6:01 AM
    #3012
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    DOH!! Extended wheelbase ftw :p
  13. Feb 16, 2014 at 6:02 AM
    #3013
    PcBuilder14
    Brent
    Nor Cal
    No, what this guy said. VVVVVVVVV It's just a greased slip joint that slides apart. I marked it with a sharpie beforehand so I can line it back up.
  14. Feb 16, 2014 at 6:03 AM
    #3014
    PcBuilder14
    Brent
    Nor Cal
    Haha yeah... :eek:
    But my friend couldn't sleep and got it swapped all around while I had a migraine last night. I hit my head pretty good on the sliders...
  15. Feb 16, 2014 at 6:05 AM
    #3015
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Ha that's a good friend. And yeah, I tend to get beat up when I'm under my truck too lol
  16. Feb 16, 2014 at 6:13 AM
    #3016
    PcBuilder14
    Brent
    Nor Cal
    When I was cutting one of the u-bolts down somehow a shard of metal flew around the safety glasses and just barely hit the edge of my eyelid, luckily I was able to get it out before it got in my eye... Haha
  17. Feb 16, 2014 at 6:38 AM
    #3017
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Amateurs... :rolleyes:
  18. Feb 16, 2014 at 6:40 AM
    #3018
    PcBuilder14
    Brent
    Nor Cal
    Right haha
  19. Feb 16, 2014 at 7:36 AM
    #3019
    AR15xAR10
    Didn't see it in the picture until after i posted.
    I was hoping the shaft end that goes in the transmission wasn't what popped out...sometimes some fluid follows when that part pops out.
  20. Feb 16, 2014 at 7:43 AM
    #3020
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Bummer on the leaf install Brent! I stopped in here to ask if you've got your relay box wired up yet? I've been looking at putting one of them in. What config did you get? AB or C?
