PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. Feb 24, 2014 at 2:28 AM
    #3181
    Onewyr
    Onewyr Active Member
    Bryan
    Norfolk, Virginia
    1998 EXT. 4X4 green SR5
    where did you buy the switches from? Sorry to ask so many questions?
  2. Feb 24, 2014 at 2:43 AM
    #3182
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    It's all good. I got them from OTRATTW.
    http://otrattw.com/
  3. Feb 24, 2014 at 3:02 AM
    #3183
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    How did you set up the truck to lock and what not?
  4. Feb 24, 2014 at 3:11 AM
    #3184
    PcBuilder14
    Brent
    Nor Cal
    A crazy combination of key turning, door closing, and button pushing! Haha
    Took me about 5 times to get it to work.... :eek:
    The first programming lets you to set the unlock button on the key fob to either unlock the driver door with one push or unlock all of the doors with one push.
    - Open driver door. Remove the key from the ignition.
    (Complete these steps within 40 seconds)
    - Insert key into and remove it from the ignition 2 times.
    (IN - OUT - IN - OUT)
    - Close, then open the driver door 2 times.
    (SHUT - OPEN - SHUT - OPEN)
    - Put the key in and remove it from the ignition 1 time.
    (IN - OUT)
    - Put the key into the ignition and leave it in.
    Close the driver door.
    - Turn the key from LOCK to ON 4 times, ending at LOCK
    (LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK)
    - Wait for the locks to stop, then remove the key from the ignition.
    On the key fob, press and release both LOCK and UNLOCK buttons at the same time.
    [For all doors unlock] press and release the UNLOCK button.
    [For driver door unlock] press and release the LOCK button.
    - Open the driver door. Should be done.
    The second program option lets you to set the doors to lock when when the key is turned on, and unlock when the key is turned off.
    - Open the driver door. Remove the key from the ignition.
    (Complete these steps within 30 seconds)
    - Put key in the ignition.
    - Turn the key from LOCK to ON 5 times, ending at ON
    (LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON)
    - Program option (select one of the following)
    [Ignition controlled lock ON] Close the driver door.
    [Ignition controlled lock OFF] Close the driver door 2 times, leaving it closed.
    (SHUT - OPEN - SHUT)
    - Turn the key to LOCK. Then you should be done. If not, then start over! Haha
  5. Feb 24, 2014 at 3:17 AM
    #3185
    tacodane
    Dane
    I'm going to have to give this a try and find out if this works with my truck.
  6. Feb 24, 2014 at 3:42 AM
    #3186
    PcBuilder14
    Brent
    Nor Cal
  7. Feb 24, 2014 at 4:44 AM
    #3187
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    You must've been bored as shit
  8. Feb 24, 2014 at 4:45 AM
    #3188
    PcBuilder14
    Brent
    Nor Cal
    Haha I've been planning on doing that for a while, just decided that while I wasn't around anybody else I'd see if it would work. so many anoying beeps in the process!
  9. Feb 24, 2014 at 4:46 AM
    #3189
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Think I'd kill myself doing that lol fuck it up a couple times and get pissed
  10. Feb 24, 2014 at 4:48 AM
    #3190
    PcBuilder14
    Brent
    Nor Cal
    Haha I'm just glad to not have to try to hit the button twice in time to make both doors unlock.
  11. Feb 24, 2014 at 4:52 AM
    #3191
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Brent go post somethin in the 30 and younger thread so I can post in it too lol
  12. Feb 24, 2014 at 4:53 AM
    #3192
    PcBuilder14
    Brent
    Nor Cal
    wut? Haha
  13. Feb 24, 2014 at 5:21 AM
    #3193
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I'm on my phone and if it hasn't been posted in a certain amount of time it won't show up in my subscribed but kase saved the day lol
  14. Feb 24, 2014 at 5:24 AM
    #3194
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Still hate you though
  15. Feb 24, 2014 at 5:42 AM
    #3195
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    You did it
  16. Feb 24, 2014 at 3:26 PM
    #3196
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    What's the difference in all those switches. I'm ordering 6 of them tonight and that same switch panel. There are too many options for one switch
  17. Feb 24, 2014 at 3:33 PM
    #3197
    PcBuilder14
    Brent
    Nor Cal
    Haha it just depends on what color and what part of the switch you want to light up when it's on.
    Independent means that it will light up whenever what you wire it to is on. Such as your dash lights.
    Dependent means that it will light up when the switch is on.
    I ordered amber upper dependent / amber lower independent. That way the words on the switch will be lit whenever my dash lights are on. And the symbol will light up whenever the accessory is on.
  18. Feb 24, 2014 at 3:35 PM
    #3198
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    How do you wire them to get lit up when the dash lights are on? I hate wiring with a passion
  19. Feb 24, 2014 at 3:37 PM
    #3199
    PcBuilder14
    Brent
    Nor Cal
    I'm going to use the wire that went to the light for the ash tray that I cut out. It's just hanging there being unused in the perfect place. Or you can just tap into any of the wiring for the dash lights or where the fuse is for it.
    If you hate wiring then I don't suggest you get switches as detailed as these are haha
  20. Feb 24, 2014 at 3:39 PM
    #3200
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Well i hate the ugly autozone toggle switches. It's not that I'm bad at wiring. I just hate vehicle electrical. I'm an HVAC tech so like 75% of my work is dealing with wiring
