PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. Apr 23, 2014 at 8:08 PM
    #4081
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I still has this issue :D
  2. Apr 23, 2014 at 8:13 PM
    #4082
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Atleast your halos work.lol still have the issue with mine
  3. Apr 23, 2014 at 10:37 PM
    #4083
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Did you ever get an answer from TRS?
    I'm going to take pics of my halos and see if they'll send me a replacement....
  4. Apr 23, 2014 at 10:39 PM
    #4084
    tacodane
    Dane
    Ya. Just got a refund. IMO to much work to replace. They offered a replacement but didn't want to go thru the hard work again.
  5. Apr 23, 2014 at 10:40 PM
    #4085
    PcBuilder14
    Brent
    Nor Cal
    Would only take a couple hours haha
  6. Apr 23, 2014 at 10:41 PM
    #4086
    tacodane
    Dane
    I have safety wire holding mine plus I drilled a hole for my halo wire to route thru
  7. Apr 23, 2014 at 10:42 PM
    #4087
    tacodane
    Dane
    I'll send you my headlight and you can replace it.lol
  8. Apr 23, 2014 at 10:43 PM
    #4088
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I'll have to take apart the whole retrofit as well.
    I need to take them apart anyways because somehow a piece of jb weld came off and is sitting at the bottom... :anonymous:
  9. Apr 23, 2014 at 10:43 PM
    #4089
    PcBuilder14
    Brent
    Nor Cal
    Sure haha
  10. Apr 24, 2014 at 8:47 AM
    #4090
    tacodane
    Dane
    That's not good. Ya I had some moisture get in thru the back where the light bulb is since the gasket isn't flushed with the ballasts connector.
  11. Apr 24, 2014 at 12:28 PM
    #4091
    XJfella95
    XJfella95 Product Developer
    Brandon
    Reading Pennsylvania
    '08 Taco DCSB
    A Few
    I have the same issue with sealing between the stock rubber gasket and the bulb connector. I ordered the 80mm housing caps from TRS and think I have a good plan on how to make these bad boy retrofits watertight.
  12. Apr 24, 2014 at 12:30 PM
    #4092
    PcBuilder14
    Brent
    Nor Cal
    I haven't had any moisture issues. The silicone gasket must be doing it's job haha
  13. Apr 24, 2014 at 6:07 PM
    #4093
    tacodane
    Dane
    Well if you figure it out, please let me know.lol
    The stock silicone gasket or the d2s mini silicone gasket
  14. Apr 24, 2014 at 6:09 PM
    #4094
    PcBuilder14
    Brent
    Nor Cal
    The D2 mini gasket. I have no stock gasket.
  15. Apr 24, 2014 at 6:49 PM
    #4095
    tacodane
    Dane
    Ya. I have the fxr retrofit
  16. Apr 25, 2014 at 10:15 AM
    #4096
    PcBuilder14
    Brent
    Nor Cal
    Thanks to Bobby over at CVT, I was able to add the stargazer option to my order! :D
  17. Apr 25, 2014 at 10:35 AM
    #4097
    AR15xAR10
    Lol AWESOME!
  18. Apr 25, 2014 at 10:38 AM
    #4098
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    I do like the option but I wonder how long the windows will last before turning yellow or possibly cracking. You'll love it in Wyoming though! We have the best star gazing. I love my hammock because I can take the tarp off and lounge with the stars.
  19. Apr 25, 2014 at 10:44 AM
    #4099
    PcBuilder14
    Brent
    Nor Cal
    I like it :cool:
    True, if that does happen though I'm sure Bobby or anybody else at CVT will come through no problem. Plus you have to think how much sunlight it would have to see before that is even a possibility. Since this will be used for nights after trail riding more often than not it won't be up much at all during the day.
    Yeah, after talking about how awesome it was camping in the bed of the truck under the stars it made me want that option haha
  20. Apr 25, 2014 at 10:49 AM
    #4100
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Depends on your use I guess. If I unpack my RTT its probably for a bit longer than a night so it would sit throughout the day as well. Ill probably use my hammock on most of the trips with Monte since he is one of those set up right before sun down and pack up early morning kinda guys. Takes me a 2 minutes to get a hammock hung up as long as there are good trees nearby and its more comfortable :).
    How would replacing them work btw? Do they zip completely off?
