PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. May 22, 2015 at 8:42 PM
    #4781
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yup, as much as I could anyways. All I have to do now is run a wire from my fuse block to the accessory whenever I add a new light or something.
  2. May 22, 2015 at 8:57 PM
    #4782
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    What exactly are you doing lol. Alligator clips were my best friend when wiring up some winch controls
  3. May 22, 2015 at 10:21 PM
    #4783
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Doing the 6 switch panel. And I don't wanna throw money at every at once so i wanna do it to where it'll be easier when the tike comes to wire the new stuff up whenever I get them at different points
  4. May 22, 2015 at 10:26 PM
    #4784
    bellassaiw10
    Currituck NC
    You can wire everything up and just leave the output pin blank for whatever accessory you want haha
  5. May 22, 2015 at 10:52 PM
    #4785
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    See I don't know anything about wiring. Lol thank god my dad does
  6. Jun 18, 2015 at 10:13 PM
    #4786
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Enough about switches and wiring, more talk about the '15 ktm in the backround :drool:
    JK cool spot for switches
  7. Jul 17, 2015 at 9:14 PM
    #4787
    PcBuilder14
    Brent
    Nor Cal
    Excited to be home soon... Hopefully get some long overdue maintenance complete in August-September. Then start saving for regear...
  8. Oct 26, 2015 at 11:33 AM
    #4788
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    I read mention of new headlights? Selling the ones you have?
  9. Oct 29, 2015 at 12:15 PM
    #4789
    PcBuilder14
    Brent
    Nor Cal
    I'd like to build a new set, but I need to spend money on other things first...
    Speaking of which, this came in today.
  10. Oct 31, 2015 at 5:04 PM
    #4790
    PcBuilder14
    Brent
    Nor Cal
    Finally changed the oil, rotated the tires, and got all the bolts off my drive shaft. Didn't have time to pry it off the transfer case flange yet, so it's just sitting like this for now.
  11. Nov 1, 2015 at 6:57 AM
    #4791
    PcBuilder14
    Brent
    Nor Cal
    Just finished installing the new drive shaft. Feels so much smoother when accelerating from a complete stop (no axle wrap feeling). And also just feels more solid overall.
    Old drive shaft had carrier bearing that was shot, 2 u-joints full of rust, a sheared zerk fitting, and a few dents haha
  12. Nov 1, 2015 at 9:22 AM
    #4792
    PcBuilder14
    Brent
    Nor Cal
    Oh, yeah. Also finally adjusted my e-brake so it's usable. Hasn't worked since I bought the truck nearly 3 years ago.... :anonymous:
    Scenekyd likes this.
  13. Nov 2, 2015 at 1:03 PM
    #4793
    PcBuilder14
    Brent
    Nor Cal
    Started the process of taking a grinder to my frame to knock off all the surface rust that's been building up. So far I've only done the passenger side frame from the rear tire back. Hoping it lasts a while....
    Holy schmidt likes this.
  14. Nov 2, 2015 at 8:18 PM
    #4794
    bellassaiw10
    Currituck NC
    Keep up the good work ;)
  15. Nov 2, 2015 at 8:28 PM
    #4795
    PcBuilder14
    Brent
    Nor Cal
    Trying!
    Finally making myself do all the stuff I should have started nearly 2 years ago haha
  16. Nov 2, 2015 at 8:47 PM
    #4796
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    time flies like an arrow. Fruit flies like a banana.
  17. Nov 3, 2015 at 1:12 AM
    #4797
    PcBuilder14
    Brent
    Nor Cal
    Lol what? A little too much tonight??? :drunk:
  18. Nov 3, 2015 at 1:19 AM
    #4798
    PcBuilder14
    Brent
    Nor Cal
    Still have quite a bit I'm trying to get done this month:
    - Finish cleaning and painting frame
    - Replace belts
    - Figure out what pulleys may need to be replaced
    - Clean out power steering pump and change fluid
    - New spark plugs and wires
    - Clean throttle body and MAF sensor
    - New air filter and Airbox deck plate mod
    - Coolant flush and new coolant hoses
    - Drain and fill transmission
    - Drain and fill transfer case
    - Drain and fill diffs
    - New fuel filter
    - New rear brake line
    - New wheel bearings
    - New LBJ's
    - New CV's
    AR15xAR10 likes this.
  19. Nov 3, 2015 at 2:32 AM
    #4799
    tomtom
    The Desert SW
    2012 FJ
    You just reminded me of a famous saying by Groucho Marx.
  20. Nov 3, 2015 at 5:01 AM
    #4800
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    My guess is the AC pulley, mine was making an odd sound and then finally seized up
