PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. Nov 3, 2015 at 7:24 AM
    #4801
    cynicalrider
    cynicalrider #NFG
    Jersey
    Damn you are giving her a lot of love.
  2. Nov 3, 2015 at 8:02 AM
    #4802
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yeah, that's what other have said due to it being so low on the engine. I know for sure my power steering pump is making a ton of noise, making it hard to know exactly if there is a pulley causing a separate noise.
    I'm hoping that, if it is a pulley, that it's just the idler pulley. Can't buy just the a/c pulley as far as I know....
    Yup, some much needed love that I should have started 2 years ago... Haha
    Making myself do it now so I can actually go on a trip next Spring/Summer. Got plenty of comp days saved up already!
  3. Nov 3, 2015 at 8:04 AM
    #4803
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Happy Birthday, fucker.
  4. Nov 3, 2015 at 8:06 AM
    #4804
    PcBuilder14
    Brent
    Nor Cal
    Thanks, douche :p
    Didn't start out well so far. Had to stay at work 2 hours after shift so now I'm going to spend the rest of the day sleeping until it's back to work all over again tonight.
    AR15xAR10[QUOTED] likes this.
  5. Nov 3, 2015 at 8:47 AM
    #4805
    cynicalrider
    cynicalrider #NFG
    Jersey
    If the PS is making noise it's likely the pump. I took my res off to clean it but it didn't fix shit until I replaced the pump. Pretty easy job too. Easy way to test is take the ac belt off see if you can hear a change in the noise. Can even take the PS belt off if you want but I wouldn't run it long since it's the belt for the fan too (at least for the manual).
  6. Nov 3, 2015 at 9:03 AM
    #4806
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I'm hoping cleaning it out fixes all the noises up front. Doubt it though... Haha
  7. Nov 5, 2015 at 1:05 PM
    #4807
    PcBuilder14
    Brent
    Nor Cal
    Cleaned out the power steering pump screen. Wasn't that clogged up at all, so I'm guessing I'm going to have to replace the pump to get rid of the whine.
    Also did a power steering fluid flush and replaced the belts.
    Was going to do the deck plate mod to the airbox, but found out the chuck for the hole saw is too big for my little Black & Decker drill. Good excuse to buy a new drill haha
  8. Nov 5, 2015 at 1:29 PM
    #4808
    cynicalrider
    cynicalrider #NFG
    Jersey
    Is it really worth doing the deckplate though? Seems like a PITA if you see a decent amount of water.
    And yeah that was my situation too. Got an A1 Cardone reman from rock auto and it's nice and quiet now.
  9. Nov 5, 2015 at 1:33 PM
    #4809
    PcBuilder14
    Brent
    Nor Cal
    Eh, some have said it does feel a little better. I want to say there's is a dyno chart for a 3.4L 4runner somewhere. I figured since I was taking out the airbox to work on other stuff, I might as well do it being just a $15 part.
    Good to know. Not looking forward to removing the pump again haha
  10. Nov 5, 2015 at 1:37 PM
    #4810
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's always easier the second time around. I just removed the res the first time I tried to do what you did. Make sure you crack the pulley bolt while it's still in the truck unless you have an impact. I had an impact so I zipped it right off. Same could be said about the res bolts too though.
  11. Nov 6, 2015 at 6:25 AM
    #4811
    PcBuilder14
    Brent
    Nor Cal
    Yeah, took me 4 hours to learn how the adjustment bolts work on the pulleys, remove the pump, clean it, and reinstall everything with new belts. Mostly because I kept tightening one bolt making another not be able to go in... Haha
  12. Nov 6, 2015 at 7:01 AM
    #4812
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I'd have to look at the FSM again but I thought that in replacing the magnetic clutch assembly, it included the pulley. But that really doesn't come cheap.
  13. Dec 16, 2015 at 3:02 PM
    #4813
    PcBuilder14
    Brent
    Nor Cal
    My engine bay is the quietest it's ever been.
    Cleaned it out a few weeks ago and after putting it back together it started to leak, whine, and the fluid was foaming.
    Finally got around to taking it back apart and found out that the o-ring between the reservoir and pump ripped. Quick trip to O'reilly's and now no more whine! :D
    AR15xAR10 and MatthewMay1 like this.
  14. Dec 16, 2015 at 9:20 PM
    #4814
    PcBuilder14
    Brent
    Nor Cal
    Finally threw money at some skids. Full set of Bud Builts ordered.
    I blame you @Sacrifice ......
    AR15xAR10, MatthewMay1 and Lost pilot like this.
  15. Dec 17, 2015 at 4:51 AM
    #4815
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
  16. Dec 17, 2015 at 6:06 AM
    #4816
    PcBuilder14
    Brent
    Nor Cal
    Your logic worked.... Haha
  17. Dec 17, 2015 at 6:12 AM
    #4817
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ha mine did the same thing! I did replace the pump anyway though since it was whining even before I replaced that o-ring.
  18. Dec 17, 2015 at 6:16 AM
    #4818
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I'm not exactly sure what fixed the original whine I had before I messed with it.
    All I did was clean out what little gunk there was in the screen and replace the o-ring. Now it's magically quiet :notsure:
  19. Dec 17, 2015 at 6:17 AM
    #4819
    PcBuilder14
    Brent
    Nor Cal
    Oh, and flush the fluid. I'm thinking somebody replaced it with power steering fluid in the past. Or the ATF was burnt, because it was very dark and stunk...
  20. Dec 17, 2015 at 6:21 AM
    #4820
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Figured it would, youre welcome
    If it stunk to high hell it was atf.
