PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. Feb 18, 2016 at 3:13 PM
    #4961
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Eh, not that bad. Doesn't take up much space at all.
  2. Feb 18, 2016 at 6:46 PM
    #4962
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Do you have to mount the tank upright. I know I read you have to use them when upright. I have room to mount mine underneath my toolbox.
  3. Feb 18, 2016 at 6:50 PM
    #4963
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Yes you want to keep them upright, it keeps the liquid co2 away from the regulator
  4. Feb 18, 2016 at 6:51 PM
    #4964
    gray223
    SE Missouri
    2014 Tundra Limited
    Dang that sucks...
  5. Feb 18, 2016 at 6:52 PM
    #4965
    Sacrifice
    KS
    DCSB OR 4X4 LT
    You can store it sideways but typically want to let it sit upright for a little before use
  6. Feb 18, 2016 at 6:53 PM
    #4966
    gray223
    SE Missouri
    2014 Tundra Limited
    yeah that was the plan.
  7. Feb 18, 2016 at 6:54 PM
    #4967
    PcBuilder14
    Brent
    Nor Cal
    Yes, you can mount it laying down.
    As long as the spigot on top of the tank is in the closes position it's not going to hurt anything.
    But, when you want to use them you do have to have it upright so that the liquid in the tank doesn't go through the regulator like you said.
    gray223[QUOTED] likes this.
  8. Feb 18, 2016 at 6:54 PM
    #4968
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Then itll be alright. Just give it 5 mins or so.
  9. Feb 18, 2016 at 6:55 PM
    #4969
    PcBuilder14
    Brent
    Nor Cal
    Interesting. I've never seen anybody wait before. Other people that have CO2 laying down just set it up and use it immediately without issue.
  10. Feb 18, 2016 at 6:56 PM
    #4970
    gray223
    SE Missouri
    2014 Tundra Limited
    Thanks guys:thumbsup:
  11. Feb 18, 2016 at 6:56 PM
    #4971
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Really? Id wait if it were mine.. just seems to be asking for it to clog.
    What do i know, im going with a compressor instead :D
    Scenekyd likes this.
  12. Feb 18, 2016 at 6:56 PM
    #4972
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I'll mount mine in the tool box. Then take it out once I air down and strap it down
    gray223 likes this.
  13. Feb 18, 2016 at 6:58 PM
    #4973
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I'm sure it can't hurt to wait.
    But it doesn't matter because I did it the easy way and left it upright. No moving around a heavy tank for me.
    :thumbsup:
    Sacrifice[QUOTED] likes this.
  14. Feb 18, 2016 at 6:59 PM
    #4974
    Sacrifice
    KS
    DCSB OR 4X4 LT
    See my ninja edit
  15. Feb 18, 2016 at 7:00 PM
    #4975
    PcBuilder14
    Brent
    Nor Cal
    Boring and slow haha
    But, I will get one of them fancy dual ARB compressors when it's time for an air locker. Be nice to have both options.
    NorthwestCruiser likes this.
  16. Feb 18, 2016 at 7:04 PM
    #4976
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Eh a few extra minutes to air up maybe once a day. Not really losing any useful time. Plus not having to store or get a tank filled.
  17. Feb 18, 2016 at 7:08 PM
    #4977
    PcBuilder14
    Brent
    Nor Cal
    Yeah, could be argued either way.
    Cheaper for quite a few fill-ups, no battery drain, etc..
    You're not getting an external tank for the compressor?
  18. Feb 18, 2016 at 7:11 PM
    #4978
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Negative. Dont have a current need to run air tools nor do i have any air tools i own. Ha. Never had an issue with good ole ratchets.
  19. Feb 18, 2016 at 7:12 PM
    #4979
    PcBuilder14
    Brent
    Nor Cal
    True. I'll probably do it eventually, but who knows how long that will be.
    I'd much rather have air tools for trail fixes. Sucks to have to work on the truck in the dirt let alone when you have a seized bolt with hand tools...
  20. Feb 18, 2016 at 7:16 PM
    #4980
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Dirt/garage floor, all the same to me. Just put anti-seize on everything and shouldnt be any issues.
    Also keep some atf and acetone around to mix for penetrator. Air tools take up more space also.
