PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. Jun 23, 2013 at 9:33 PM
    #721
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    How much rear lift did you get with the 2" AAL on your previously sagging leaf packs?
  2. Jun 23, 2013 at 9:51 PM
    #722
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    2", I haven't measured it since I got it installed, so it may be less now.
  3. Jun 26, 2013 at 12:34 PM
    #723
    PcBuilder14
    Brent
    Nor Cal
    Drove through Coyote Canyon again today. Finally put my stock skids to use and bent and dented them pretty good. Also slammed hard on my frame coming down some rocks, luckily I didn't dent it.
    A little IFS flex
    Probably could have gone a little farther back, but my leafs were already negative...
    Learned a lot on how much of a difference your angle and the line you take makes on this spot. kept slipping until I took one line, and then just climbed right up.
    I need a plate bumper! Pushing in my valence.... But I still made it up.
  4. Jun 26, 2013 at 1:26 PM
    #724
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    You kill the blinker?
  5. Jun 26, 2013 at 1:27 PM
    #725
    PcBuilder14
    Brent
    Nor Cal
    Surprisingly not! I had it smashed in pretty far, but it just popped back out by itself. All it did was leave a few gouges in the plastic.
  6. Jun 26, 2013 at 3:25 PM
    #726
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Why do you need longer bump stops? Are the shocks bottoming out? Are the tires rubbing? Because the springs will still flex more (down to the overload) which looks to be about the same distance before your bump stops make contact.
    Oh, and you need some sliders soon if you're gonna keep playing like that.
  7. Jun 26, 2013 at 4:38 PM
    #727
    PcBuilder14
    Brent
    Nor Cal
    I thought you weren't supposed to negatively arch your leafs? Not that it matters really, I plan to get expos sometime next year anyway.
    Yeah, I definitely need sliders! Already busted up my passenger side rocker panel. I plan to get those next, but if I get the style I want I won't have them until this fall. By then I'll be back in Missouri and won't have the need for them.... :(
  8. Jun 27, 2013 at 9:39 AM
    #728
    Box Rocket
    Adam
    Syracuse, Utah
    Negative arching the springs isn't ideal because it can cause slightly quicker wear of the springs but they're designed to do it. That's why the overload is arched the way it is. It is like it is for when the springs go into neg. arch and the overload stops it from going any further.
  9. Jun 27, 2013 at 9:45 AM
    #729
    PcBuilder14
    Brent
    Nor Cal
    Oh, okay. Makes sense. I'm not too worried about these leafs anyways since they're stock plus an add-a-leaf. I'll worry about bump stops when I redo the rear setup.
  10. Jun 28, 2013 at 3:57 PM
    #730
    PcBuilder14
    Brent
    Nor Cal
    Spent 4 hours washing, clay barring, waxing, and vacuuming it today. Hasn't been this clean in a while!
  11. Jun 28, 2013 at 8:11 PM
    #731
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Your truck is badass
  12. Jun 28, 2013 at 9:49 PM
    #732
    PcBuilder14
    Brent
    Nor Cal
    Eh, it's okay haha
    I really need sliders and skids right now!
  13. Jun 28, 2013 at 9:58 PM
    #733
    TACOMABOSS
    96 SR5 4x4
    You and me both :(
  14. Jun 28, 2013 at 9:59 PM
    #734
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I've got two dents in my passenger side rocker panel and my stock skids are torn up just from to runs....
  15. Jun 28, 2013 at 10:03 PM
    #735
    TACOMABOSS
    96 SR5 4x4
    I don't have that at least haha
  16. Jun 28, 2013 at 10:05 PM
    #736
    PcBuilder14
    Brent
    Nor Cal
    Haha I'm trying to get as much trail time as I can while I'm in New Mexico, because once I go back to Missouri I'll be out of luck.
  17. Jun 28, 2013 at 10:16 PM
    #737
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Just wanted to say I'm jealous of your sig pic...
  18. Jun 28, 2013 at 10:18 PM
    #738
    PcBuilder14
    Brent
    Nor Cal
    Haha it's not too bad. It'd look a LOT better if the grille was repainted and it was clean...
  19. Jun 28, 2013 at 10:18 PM
    #739
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Ok. Now do one for me. And no, I'm not jealous of your KM2s. lol
  20. Jun 28, 2013 at 10:20 PM
    #740
    PcBuilder14
    Brent
    Nor Cal
