PcBuilder's 2003 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by PcBuilder14, Dec 21, 2012.
  1. Feb 9, 2013 at 3:00 PM
    #101
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Thats alot cheaper than $100/hr even if you lose one saturday at $40
  2. Feb 9, 2013 at 3:01 PM
    #102
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    You dont HAVE to seperate them to get the Eibachs in. Did you compress the coils?
  3. Feb 9, 2013 at 3:02 PM
    #103
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Would this way work well
    4WD suggested this:
    loosen the lower ball joint bolts & remove (4 of them), lower the ball joint, now loosen (do not take out !! ) the 2 bolts of your lower control arm (not really neccessary to mark the current adjustment location) this should allow your LCA to drop plenty to slide the assembled strut up into the strut/shock tower, put the 3 nuts on the studs to hold strut in place & you shouldn't have any problem aligning the lower bolt hole with the LCA...
  4. Feb 9, 2013 at 3:02 PM
    #104
    PcBuilder14
    Brent
    Nor Cal
    What do you mean by compress the coils? I compressed them when I installed the top plate?
  5. Feb 9, 2013 at 3:04 PM
    #105
    PcBuilder14
    Brent
    Nor Cal
    What's a pickle fork and how do I use it?
  6. Feb 9, 2013 at 3:08 PM
    #106
    PcBuilder14
    Brent
    Nor Cal
    Would a pry bar work? How do I do that without tearing the boot for the ball joint?
  7. Feb 9, 2013 at 3:09 PM
    #107
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Yes. All i had to do was pull out the old coil assembly, drop the LCA enough to slide the new coil assembly up, then bolt the lower shock bolt.
  8. Feb 9, 2013 at 3:30 PM
    #108
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    That's why I bought new top plates from Napa and assembled the new 883 and shocks.
    -I took the old setup out
    -I used my trucks bottle jack and jacked the UCA down until I could fit the new assembly in
    The fronts were the easy ones. The new dakars leafs punished me thoroughly!
  9. Feb 9, 2013 at 4:07 PM
    #109
    PcBuilder14
    Brent
    Nor Cal
    I used my bottle jack as well, but every time I got the uca low enough the spring couldn't get past the upper ball joint...
  10. Feb 9, 2013 at 4:39 PM
    #110
    Madjik_Man
    Colorado Front Range
    *ahem*
  11. Feb 11, 2013 at 10:11 AM
    #111
    PcBuilder14
    Brent
    Nor Cal
    Question, how important is it that I torque everything on my suspension back to spec vs. with just a impact wrench? I know that after 500 miles or so you're supposed to tighten everything up again. I was just wondering because using a impact is a lot faster than making sure each and every bolt is to spec.
  12. Feb 11, 2013 at 11:15 AM
    #112
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Use the impact on low setting untill it just snugs. Then use torque wrench
  13. Feb 11, 2013 at 5:04 PM
    #113
    PcBuilder14
    Brent
    Nor Cal
    Gotcha, Thanks!
    On a different note, anybody have any good ideas for a good in bed spare tire mount? Or are there modifications I can do to the stock spare tire carrier to fit a 33x12.50x15 tire?
  14. Feb 12, 2013 at 2:04 PM
    #114
    PcBuilder14
    Brent
    Nor Cal
    So my wheels came in today, but they just slightly rub the brake caliper... I'm just going to get some 1/4 wheels spacers and it should be good to go. Anybody have any recommendations on where to by the wheel spacers from?
  15. Feb 12, 2013 at 2:37 PM
    #115
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    How much do they rub? Can you perform some creative honing to stop the rubbing?
  16. Feb 12, 2013 at 2:39 PM
    #116
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    I was hoping they weren't going to rub either...Their shipping costs are so much lower than Wheelers.
  17. Feb 12, 2013 at 2:43 PM
    #117
    PcBuilder14
    Brent
    Nor Cal
    The barely rub at all, just enough to not be a good idea to drive. I could probably grind off a very thin amount of the calipers, but I'd rather just buy some 1/4" spacers and be good.
  18. Feb 12, 2013 at 4:37 PM
    #118
    PcBuilder14
    Brent
    Nor Cal
    Thinking about getting these spacers from Wheelersoffroad... Seem like a good idea?
  19. Feb 12, 2013 at 5:56 PM
    #119
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    Get 4 but maybe just use on the front? Do you think 1/4" is all you need?
  20. Feb 12, 2013 at 5:59 PM
    #120
    PcBuilder14
    Brent
    Nor Cal
    I would expect 1/4" to be enough, but I'm not 100%... I think that buying four and if 1/4" isn't enough then stacking them will be what I do... These wheels let you use pretty much all of the wheel studs, so I'm not worried about the lugs not having enough to hold on to.
