PCS Braking
Discussion in '4th Gen. Tacomas (2024+)' started by 29savoy, Apr 24, 2024.
  1. Apr 24, 2024 at 3:46 AM
    29savoy
    29savoy [OP] New Member
    2024 Tacoma TRD Sport 4WD
    My taco has the Toyota Safety Sense suite including the pre collision system (PCS). I'm new to this kind of function and feel like the system is riding the brake ahead of my normal braking. I also assume it's activating the brake lights, but haven't had someone confirm. I don't want to become dependent on PCS or to put excessive wear on the brakes. Any thoughts?
  2. Apr 24, 2024 at 4:03 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Welcome to TW!
    Curious as to why your PCS activates so much. In my 3G, I can count on one hand the number of times it interceded on my behalf. Mine is 2018 with 91K miles. Things might have changed in the broke gen.
    As to the longevity of your brakes. I am still on my first pads with plenty of material left. My guess is your pads will do just as well. Just confused as to why your PCS is lighting up that often. Maybe a check out at the dealer for re-calibration?
    29savoy[OP] likes this.
  3. Apr 24, 2024 at 4:18 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Are u braking to late or driving to closely to the vehicle in front of you ? I know on the 3rd gen u can change the sensitivity to the system . Might want to look in the manual to see if it has an option on the 4th gen .
  4. Apr 24, 2024 at 4:57 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You'll get a warning chime and a big "BRAKE" message in the gauge cluster if PCS kicks in. You're probably feeling the truck downshifting for engine braking. Are you new to Tacomas in general? They've been doing that since 2005.
    29savoy[QUOTED][OP] likes this.
  5. Apr 24, 2024 at 4:57 AM
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    Your brake light activation shows in the bottom part of your speedo/tach screen. It lights up as 2 red lines when your brake lights are on. I've had the same feeling as you...but the brakes aren't been applied nearly as often as i thought.
  6. Apr 24, 2024 at 5:44 AM
    29savoy
    Some great input. I'm new to tacomas and these kinds of "assists". What I'm sensing is like having a second driver on the controls a half second ahead of me. I'd only had the beep come on once and will play with the sensitivity adjustment as I run some tests this week. I hadn't thought if the system downshifting/ engine braking so will look for that.
  7. Apr 24, 2024 at 6:39 AM
    Poot Klopp
    Poot Klopp Well-Known Member
    Ben
    New Jersey
    2024 Bronze Oxide TRD OR
    The 4g has a newer version TSS 3.0 vs TSS-P on the 3g. I think the OP is describing the Proactive Driving Assist feature which does what he is explaining. I think you can adjust the settings for PDA. This video explains it pretty well
    snickers[QUOTED] likes this.
  8. Apr 24, 2024 at 8:19 AM
    snickers
    OP, p275 of your manual describes PDA. P.265 describes the overall settings you can customize. Looks like you can only turn PDA on/off.
