PCS is such a BS Feature
Discussion in '3rd Gen. Tacomas (2016-2023)' started by arthur106, May 9, 2023.
  1. May 9, 2023 at 7:58 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I can almost reliably trick PCS to activate at the same place every time. On a curved residential street there's usually a car parked on the outside of the curve and the system thinks I'm going to hit it. Curious if it considers steering angle in its programming.
  2. May 9, 2023 at 8:53 PM
    GBR
    GBR Well-Known Member
    19 TRD OR
    I didn't know or had forgotten you could change the sensitivity. Good to know. It's only beeped at me a couple times and applied once. The one time it applied I was cut off by a hard braking car and I don't think I could've reacted in time. It's good in my book.
  3. May 9, 2023 at 10:37 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I anticipate turning off one or more of the safety sensors depending on the circumstances. LDA is not on ... just an annoyance. But the Pre-Collision only becomes annoying in miles of stop-and-go construction traffic, BSM in the same conditions because cars are always in your blind spot, etc.
    Other times they serve me well.
  4. May 10, 2023 at 6:24 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    In my experience many of the features of these trucks could be offset by a good driver. Personally, I wish they were options. I would opt out.
  5. May 10, 2023 at 6:36 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I know how to adjust the sensitivity when using the cruise control. Is that different than adjusting it for the PCS? If so, how do I adjust the sensitivity for the PCS. And yes the LDA is a PITA.
  6. May 10, 2023 at 9:08 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    yes, I believe they are two different settings,,, but using the same sensor for two different functions.
    Not being a wise-ass, but it is in the manual. If I could remember, I would tell you, but I set it day 1 when I got it 4 years ago, and never touched that setting again.
    jego and HisDad[QUOTED] like this.
  7. May 10, 2023 at 9:12 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Late 3rd Gen problems…. :devil:
  8. May 10, 2023 at 9:13 AM
    HisDad
    Texas at last
    Yes, they use the same hardware and likely share most of the firmware as well. Toyota doesn't make it all that easy to find things in the manual, but then again I don't know that any manual from any manufacturer had the answer to a question I had. I use the manual to find the tire changing information and jacking points, but little more.
  9. May 10, 2023 at 9:29 AM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Good problems to have sometimes homes! It saved me from rear ending someone once. Tripped me out, but that’s what happens when you stop paying attention in our tight freeway traffic.
    LDA is used when I’m traveling up the 395 to Mammoth exclusively!!!! Keeps me out of trouble when I be staring into the Eastern Sierra granite.
    Most of the time, it’s the laziness in us that causes these issues. Don’t use it in traffic.
    Chew likes this.
  10. May 10, 2023 at 9:36 AM
    AvockAdoo
    AvockAdoo Well-Known Member
    Sam
    Denver, CO
    '21 DCLB TRDOR
    I've only had my PCS activate when it needed to. Everybody gets distracted to some extent while driving, and this system has saved my ass a time or two. I'm an attentive and competent driver, but the aids have their place. I love PCS, on my '21 it works perfectly.
    As far as those complaining about ABS - do you know how physics work? ABS works damn well. If you think it makes it worse, pull your ABS fuse and slam on your brakes - but dont complain to me when your wheels lock up & you slam into a wall.
    GBR, joeyv141, MagneTrail and 3 others like this.
  11. May 10, 2023 at 9:38 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    TW is full of "my generation and model Tacoma is best" curmudgeons.
    Just give it a minute, Father Time will call their flip phones and distract them.
  12. May 10, 2023 at 9:45 AM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I don’t have this feature. I’m sorry I bumped into this thread as a new post and I have to comment. I really dislike all the warning lights we have these days in newer vehicles. We used to just check the air in our tires once a week and when we’re filling up the tank we’d check the oil, scheduled regular tune-ups and if your car didn’t seem to be running right you had it looked at. Todays vehicles take most of the thinking out of the equation, tell you basically all you need to know and maybe more. I guess some of these features like keeping you in your lane or this PCS help you stop, probably a good idea for the people that drive around distracted on there phones
  13. May 10, 2023 at 9:45 AM
    HisDad
    Texas at last
    ABS has improved tremendously since it was first introduced in the mid 1980s. We had Ford chassis ambulances starting around 1986. Front ABS only and it was horrible, especially in wet or icy conditions.
    So bad we just called it the Anti Braking System.
  14. May 10, 2023 at 9:50 AM
    Topanga Taco
    Rick
    :evil:
    Chew[QUOTED] likes this.
  15. May 10, 2023 at 10:13 AM
    #35
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I happen to be interested in this...it's activated twice in my 2021 Sport in the almost 2 years of ownership.
    Both times I was aware that my approach speed was slightly too fast.
    Automatic Braking did not take place because I reacted quickly.
    I have not had a problem with PCS.
    HisDad[QUOTED], scocar and Chew like this.
  16. May 10, 2023 at 10:15 AM
    #36
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    It's never triggered when I wasn't ready to take action to brake myself.
    Except for going under an overpass a couple times on the highway, the shadow triggered it - happened a couple times.
  17. May 10, 2023 at 10:26 AM
    #37
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Welcome to the Nanny state mandated by federal requirements.
    I still believe that new cars wont even have mirrors in ten to twenty years because the majority of the public is too dumb to use them.. But hey, why invest a little into better schooling and training for the younger generations when we can invest wayyyy more into developing dumb technology that makes out lives "better" :mad:
    /rant
    02Duck likes this.
  18. May 10, 2023 at 10:29 AM
    #38
    RYE793
    RYE793 Well-Known Member
    2022 Lunar Rock SR5 Trail
    I've had mine chime a few times telling me to brake but has never applied the brakes for me. Will it actually do that or is my truck (SR5 Trail) not equipped with that?? Hoping it isn't...
  19. May 10, 2023 at 10:31 AM
    #39
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Mine works fine. can always adjust the settings, I think can turn off I believe?
  20. May 10, 2023 at 10:31 AM
    #40
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What the hell does PCS stand for?
    Post Crash Sensors?
