PCS malfunction and BSM not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by partmont, Feb 22, 2022.
  1. Feb 22, 2022 at 10:22 PM
    partmont
    partmont [OP] Member
    Peter
    2021 Black Tacoma Off Road
    Stock height truck. Pro grill after market garnish. Have a washer in top screw of tss sensor. Truck was fine for a year now the alert keeps going off.
    getting pcs error coming on for a second then going off. The blind spot monitors also seem to be not working.
    has anyone had this issue before?
  2. Feb 24, 2022 at 9:27 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Several things come to mind regarding the BCM, I will not address the PCS.
    1)Have you checked the under-dash fuses yet? There are about 5 different fuses that the fuse list says power some portion of the BCM. 7.5A and 10A dfuses. Sorry I have not figured out yet how to attach files.
    2)How does the BSM not work? i.e. what are the indications? Do the mirror lights come on for about two seconds when the button is pressed, or the ignition turned on? Do both sides not work, etc.
  3. Feb 25, 2022 at 11:03 AM
    partmont
    Peter
    1 checked fuses all seem good but,
    do u know which ones I should double check by their label?
    2 when I start the truck no the bsm in the mirrors don’t light up.
    I’ll post a video of the PCS malfunction error that I’m getting when I get home.
  4. Feb 25, 2022 at 11:54 AM
    Toycoma2021
    With the engine on, what happens when you cycle the BSM switch?
    My downloaded schematics are, I believe from 2016, but the fuses are:
    ECU-IG NO. 2
    IG 1 NO. 2
    BK UP LP NO. 3
    ECU-ACC
    The schematics also have more fuses:
    METER
    TOWING in engine compartment
    EUC-B NO. 3 in engine compartment
    These last three I believe you would be having even more problems if they were blown.
    The BSM system is one of the simplest systems on the truck. The only electronic modules involved are the two BSM modules in the bumper caps, wiring, fuses and of course the Combination Meter and the CAN bus.
    From my readings on this forum people have had problems with water and dirt at the BSM bumper modules and wiring problems. Also, alignment problems within the bumper.
    I am ignoring the PCS system as I know little to nothing about it, ...yet.
  5. Feb 26, 2022 at 7:17 PM
    partmont
    Peter
    Turned on truck and cycled through the bsm switch no indicators coming on and nothing changes on dash. Checked all the fuses they seem good.
    I just unplugged the battery to let it sit for a little unplugged see if that will reset anything.
    This alert flashes on then goes away after a second. Really annoying lol.
  6. Feb 26, 2022 at 7:37 PM
    Toycoma2021
    I don't know the years affected, but did you have the Grill Radar sensor recalled? There were posts of water intrusion to the unit.
    What activities has the truck been through lately? Mud, snow, rain, etc..
    2016 BSM Schematics
  7. Feb 26, 2022 at 7:40 PM
    partmont
    Peter
    It’s a 2021 had the truck about 14months.
    Not much besides driving on highways and surface streets.
    it was around heavy snow when I first got the truck but that was over a year ago.
  8. Jan 13, 2024 at 8:23 PM
    Duckboy23
    Duckboy23 New Member
    Did you end up figuring it out? I have the same problem
