Pcv catch can
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bessolo007, May 19, 2017.
  1. May 19, 2017 at 10:26 PM
    Bessolo007
    Bessolo007 [OP] New Member
    2017 trd off road
    King lift
    anyone install one of these on there truck yet? I do it to all of my vehicles and was looking for some ideas
  2. May 19, 2017 at 10:30 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Why do this?
  3. May 19, 2017 at 10:32 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
  4. May 19, 2017 at 10:33 PM
    AWDDude
    AWDDude Well-Known Member
    2017 Tacoma TRD Off Road DCSB, QuickSand
    it helps keep oil out of the intake
  5. May 19, 2017 at 10:39 PM
    smitty99
    Scottsdale
    Seems unnecessary? To each their own I guess.
    Hank Heel and GPsevinSixx like this.
  6. May 19, 2017 at 10:44 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Because"race truck" and thought of being able to overtake the F150 ecoboost at stop lights.
    :rofl:
    Seriously, there is no point in it...
  7. May 19, 2017 at 10:49 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  8. May 19, 2017 at 10:49 PM
    Bessolo007
    2017 trd off road
    King lift
    Thanks ironpeak that's what I was looking for. Anyone seen a 3rd gen with one installed?
    Smitty99, it keeps your intake manifold and valves clean. Maybe it's unnecessary but so are most things I spend my money on lol
    vprgts, Lord Helmet and Boneretreiver like this.
  9. May 19, 2017 at 11:15 PM
    smitty99
    Scottsdale
    Amazing that a truck designed in 2017 would be susceptible to getting oil in the manifold and valves...@z50king you better get on it
    Hank Heel, DjSamthrax and Garrett75x like this.
  10. May 19, 2017 at 11:37 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    I am a bit buzzed, but is this really a necessary mod?
    NM Lance and Hobbs like this.
  11. May 20, 2017 at 3:09 AM
    Sandeman
    Sandeman Well-Known Member
    Home of the Headless Horseman, NY
    '17 TRDOR, '04 GX470
    I only found it necessary on my boosted cars
  12. May 20, 2017 at 5:21 AM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    When direct injection started to become the standard, some manufacturers (especially Audi) had issues with carbon buildup inside the intake runners and on the back of the valves. This caused a lot of problems and often required that the intake manifolds were removed so a tech could chip that stuff off and vacuum it out.
    Installing a catch can supposedly helped in these situations.
    What most people don't realize is that most engines already have a baffled can/box/container that's integrated into the PCV system, usually on block.
    Tl;dr, dont use poor quality gasoline and you're probably fine.
    Inferno500 and boynoyce like this.
  13. May 20, 2017 at 6:45 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Every vehicle with a pcv (positive crankcase breather valve) routes hot gas buildup back into the intake to be burned. Carbon buildup on valves isnt a new thing, been an issue since they started burning carbon based fuel. Bigger issue on direct injected cars because they do not have gasoline with its cleaning agents putting gas past the back of the valves. This is a major reason i think our trucks come with both direct and port injectors (and mpg).
    An oil catch can seperated the oil out of the pcv mixture so only hot air is returned to the intake of an engine. Some motors are more susceptible to carbon buildup than others. Every engine should have one but it is one more maintenence item people would have to pay attention to and most people dont like maintence items
    jonnymtb, Lord Helmet and boynoyce like this.
  14. May 20, 2017 at 7:39 AM
    batman900
    batman900 Well-Known Member
    Oklahoma
    24-TRD-0R
    This^ On my Chevy truck I had a catch can as it didn't have the dual system of port and direct injection, I dumped out a can full of sludge at least once by-weekly. I'm less worried about it with Toyota's system though, if they didn't have any port injectors I'd buy one no doubt as 30k miles on any DI only engine will cause it to be coaked up and need walnut blasting to run at 100%.
    boynoyce likes this.
  15. May 20, 2017 at 7:46 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I don’t see any viable reason for this mod on a stock DD vehicle, except to tinker some time away, spend money and possibly ruin you engine if a hose should burst and void your engine warranty, or maybe even catch it on fire.
    Toyota direct fuel injection uses self cleaning injector cycle to clean valves and that’s one of the noise some ppl find so annoying under the hood.
    But if you’re concerned about your intake manifold carbon and sludge build up, use top tier fuel, replace oil every 5k, and replace you pcv valve every 3yr or 36k miles.
    You may find some of those recommended in the owners manual as part of regular maintenance, but you won’t find a PCV catch can system recommended anywhere on it last time I checked.
    That is totally up to you, and to each their own.
    Cheers!
  16. May 20, 2017 at 8:31 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had actually done a little research on this and it does seem that modern vehicles can benefit from the catch can. In the never ending quest to meet EPA MPG standards they started using Low Tension Piston Rings along with thinner Oils thus creating this issue.
  17. May 20, 2017 at 8:47 AM
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    Somehow I don't think this catch can is necessary, at least not on a Toyota. personally I know of two trucks and 1 4Runner with over 250,000 and another truck just under 200,000. They seemed to do fine without it. Unless you simply don't maintain the vehicle, a Toyota just keep running and running and running. Longer than the frickin energizer bunny.
    boynoyce and The hammer like this.
  18. May 20, 2017 at 8:59 AM
    The hammer
    I’ve put hundreds of thousands of miles on mainly Toyota family vehicles and on domestic model fleet vehicles and with only regular maintenance, no major internal engine failures have occurred.
    The only concerns have mainly been sensors on domestic fleet vehicles and there were some plastic intake manifolds on the 5.0L fords that cracked, and there was sludge build up on those too, but it was due to a faulty EGR system which was corrected by the factory but may not have been covered if they’ve would have a had catch can.
    Cheers!
  19. May 20, 2017 at 9:00 AM
    shakerhood
    Southern Ohio
    Your older trucks would have still had higher tension piston rings and heavier oil, that said if you go under the 2nd Gen Section and look up the catch can you will see it even collects quite a bit.
    Lord Helmet likes this.
  20. May 20, 2017 at 9:13 AM
    shakerhood
    Southern Ohio
    Never heard of any issues on the 5.0 Intakes, l am aware of cracking plastic Intakes on the old 4.6 for about a 5 year period in the late 90s to early 2000s.
