Pcv catch can
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bessolo007, May 19, 2017.
  1. May 20, 2017 at 9:20 AM
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    Kind of funny, we used to talk engine sizes in cubic inches such as 351, 460, 427, 289, 397, 454, 302. Now it's all about liters. Guess I'm showing my age a little bit.
    Biscuits, Lord Helmet and The hammer like this.
  2. May 20, 2017 at 9:30 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    We had a few CV's that had them, on fleet stuff, you get to see things other ppl never have to deal with
  3. May 20, 2017 at 9:36 AM
    The hammer
    Liter is the new CU.
    But oh how I loved the 351 CU Cleveland though. Couldn't resist when i saw it on your list, but I supposed that anything that changes the outside dimension size like a new manifold gets a free pass to be converted to liters I guess so I don't keep track of it any more lolo!
  4. May 20, 2017 at 9:54 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Crown Vics never came with modern 5.0.
  5. May 20, 2017 at 10:05 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    That's being more than just a little alarmist.
    If a hose bursts (from such low pressure??) you're simply venting PCV to atmosphere. Your engine will not be ruined by that. Older cars vented to atmosphere their entire service lives.
    If you have enough blowby to start a fire, you had bigger problems to begin with. Mainly the fact that you probably don't have piston rings anymore.
    Onto the question of "necessity" ... take apart a well maintained port injection engine (of any manufacturer) with ~100,000 miles on the clock and you will find that the inside of the intake manifold is coated with a foul carbon/oil buildup from the PCV.
    Here, I've got a picture, this is an intake runner from a Mazda Miata with ~120K when its manifold was pulled for salvage:
    It's not something you want in there, but at the same time the accumulation of many years & miles is not really appreciable enough to block a lot of flow or break anything.
    The worst this would do is block little vacuum passages and cause headaches with check engine lights over emissions passages and sensors.
    The "only turbo cars need it" sentiment is a misunderstanding of the fact that it's extremely important to keep this PCV condensation from happening inside an intercooler.
    Intercoolers cool the intake air, and this causes the PCV oil to condense out of the air. Oil in the intercooler makes the intercooler not work as well. Thus, you lose power because your intercooler is no longer working at an acceptable efficiency.
    So, basically TL;DR do you want that shit in your motor? Of course not. Is a catch can a good way of keeping it out? Yup.
    But at the same time, it's not like you desperately need to add one. If you have the know-how, an afternoon of free time, and ~$100, it's not going to hurt anything.
  6. May 20, 2017 at 10:59 AM
    FrankJake
    Southern California
    LOL And when you brought up the 351, everyone had their opinion on the Cleveland or Windsor. I was heartbroken when the TransAm listed liters on the hood.
  7. May 20, 2017 at 10:59 AM
    The hammer
    The problem that we had was long ago shakerhood, and the 4.6-4.9L were marketed as 5.0 at one time and we had a mixture including f-150’s at the time.
    But the bottom line is, its still a POS as far as I’m concerned but even so, if you fix it and repair it daily, it should last a very long time.
    You can read all about it here.
    http://www.curbsideclassic.com/blog/engine-history-the-ford-4-6-liter-v8/
    “In time, many of these intake manifolds would fail in the area coolant was routed. This picture shows a failure along the front of the manifold; various sources will show various locations of failure. The author experienced an intake failure on the engine of his 2001 Crown Victoria Police Interceptor at 128,000 miles. This particular failure was a crack in the thermostat housing that dumped coolant on the ground overnight after a 25 mile trip. As Ford has classified these manifolds as a wear item, an aftermarket unit with an aluminum coolant passage was installed.
    In the early 2000’s, there was a class action lawsuit brought against Ford due to the failure of these intake manifolds. Ford did provide replacements as part of the settlement, albeit for a very short period of time.
    Ford’s 4.6 liter V8 has had a few issues during its lifetime, however none of these directly relate to the overall durability of the engine. Finding stories of 4.6 liter engines with over 300,000 miles is not hard to do; on a recent trip to Kansas City the author rode in a Crown Victoria taxi with 362,000 miles on the odometer. These are robust engines that can often be found in very tortuous use, such as police and taxi service.”
    I don’t think I’m being an alarmist Nitori, I’m just playing out all possibilities into best/worst case scenarios, and I don’t see an upside to this mod.
    IDK what materials are used or anything really that proves its necessary, and a Mazda and a turbo engine is nothing like we have in our 3.5L trucks to indicate I need this, or that it will significantly improve it.
    But it is extra weight and obstruction in the engine bay should it need work, and I don't think warranty will cover the extra labor to get around or remove it.
    Moreover, I’d bet that even with the “can catch” you’d still have carbon build in there so that's a mute point for me. Only way I know to remove it completely is grind and elbow grease.
    But that’s just me, to each their own I’m not going to just install or recommend something that may or may not cause serious consequences and without factory recommendation as to its benefits.
    Hope that helps
    Cheers!
  8. May 20, 2017 at 11:04 AM
    The hammer
    Yes, it was an ongoing debate at the time FrankJake, I chose sides lolo! And the '76 TransAm was a favorite of mine, still is as it was kool as chit as I remember it from the movie "the bandit".
    FrankJake[QUOTED] and shakerhood like this.
  9. May 20, 2017 at 11:10 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    This PCV catch can is a great idea! Someone should alert Toyota!!!
  10. May 20, 2017 at 11:12 AM
    The hammer
  11. May 20, 2017 at 11:19 AM
    shakerhood
    Southern Ohio
    The 4.6 Modular Motor was never marketed as a 5.0, the Coyote 5.0 came out in 2011. There was a recall on the 4.6 Mod Motor plastic intakes that you described.
    http://www.crownvic.net/news/intake.shtml
  12. May 20, 2017 at 11:26 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I was going to add my input but you pretty much covered it :thumbsup:
    I personally believe the 2nd gen benefits more then the 3rd gen with the oil catch can due to the 2nd gen lack of the dual fuel injection setup.
    It's up to you if you want to keep your engine internals as clean as possible. One of the reasons Toyota or other car manufacturers don't install these is because they know most people have a hard time checking the engine oil level let alone popping the hood up or know where the hood prop is.
    BTW I have one and after 5k miles it catches about half the bottle when I dump it. Worth it IMO.
    737doc, Big tall dave and shakerhood like this.
  13. May 20, 2017 at 11:44 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    I did a catch can on my sons 2000 and on my 2007. When I did the heads on my sons 2000 with 200k on it the intake took three days of dipping and scrubbing to get all the oil build up out on the inside of the intake manifold. Every oil change I drain about 3 to 4 teaspoon from the catch can. If you like oil in your intake then leave the catch can out.
    737doc likes this.
  14. May 20, 2017 at 11:51 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    I thought it helps with speeding up air flow with the extra vaporized lubrication...:notsure:
  15. May 20, 2017 at 12:02 PM
    #35
    DukesTaco
    AZ
    Turd gen logic :boink:
    GPsevinSixx[QUOTED] likes this.
  16. May 20, 2017 at 12:27 PM
    #36
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I will not be doing this mod. However, I was eating grapes a moment ago and found a spider, deceased. Googled grape spider. And this is a very common thing, spider chillin in grapes. Beware guys. It's hella creepy.
    Google image that if you dare
    Biscuits likes this.
  17. May 20, 2017 at 12:29 PM
    #37
    GPsevinSixx
    Ros Angerus
    Looks almost like a black widow with it's abdomen twisted and hour glass up.
    You need to wash/ rinse those grapes!
  18. May 20, 2017 at 12:32 PM
    #38
    stun gun
    Aaronski
    Tacomas.
    No way bro. I'm a savage. I dive in, the pesticides keep me regular.
    Besides who the hell wants wet grapes. I don't wash salads because I don't like wet salad. And I don't eat cereal because I don't like milk soup.
    Biscuits and Nfarrall like this.
  19. May 20, 2017 at 12:34 PM
    #39
    GPsevinSixx
    Ros Angerus
    Why so beastly!?
  20. May 20, 2017 at 12:36 PM
    #40
    shakerhood
    Southern Ohio
    No shit, I had one in my grapes last Summer, thought it was a Black Widow!
