PCV Valve, check it.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaptainBart45, Mar 4, 2024.
  1. Mar 5, 2024 at 1:42 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Driver side. Left and right when referring to a vehicle match the turn signals. The video above does a good job showing where it is.
    Stevie17 and kahanabob[QUOTED] like this.
  2. Mar 5, 2024 at 4:52 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I got the same recall on my 2017 , but no fuel issues that I know of or have noticed
    tonered[QUOTED] and Stevie17 like this.
  3. Mar 5, 2024 at 5:03 PM
    CaptainBart45
    CaptainBart45 [OP] Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Mine was plugged and leaking at 89,000 miles. I don't know but I think the direct injection on these engines is harder on the PCV valve.
  4. Mar 5, 2024 at 5:11 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. It's a weird one for sure.
  5. Mar 5, 2024 at 5:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but DI has no relation to the PCV. Now, if you said ACIS, maaaaaaybe?
  6. Mar 5, 2024 at 5:44 PM
    CaptainBart45
    Bart
    Work in progress...
    OK, it was an uneducated guess.
    tonered[QUOTED] likes this.
  7. Mar 5, 2024 at 5:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    All good! :cheers:
  8. May 13, 2024 at 6:56 AM
    Greatdane01
    Greatdane01 Well-Known Member
    3rd Gen TRD Sport Tacoma
    3” lift, XD Wheels, BFG Tires, GT momentum cold air intake
    I’ve got a similar issue w my 2020, 115k… leaking oil suddenly. Dealer says it’s the main seal and wants $2400. Eek
  9. May 13, 2024 at 7:45 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i don't recall the socket size but, if you have a long extension (or a few extensions attached together) it is not too difficult to access it from the passenger side. **I know the PVC is not on the passenger side**.
    What you can do is go across the back of the engine with the extensions to reach it. Easy peazy. Just be careful installing the new one and do not over-torque it.
  10. May 13, 2024 at 8:02 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Left as if you were sitting in the driver seat
  11. May 13, 2024 at 8:06 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Great explanation…..easiest way to access it.
    The socket needed is a 22mm
  12. May 13, 2024 at 8:10 AM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    Check out team oil drop video. They have a diy video for it. It's by the brake fluid reservoir kinda, but under some insulation .
    Josephray70 and faawrenchbndr like this.
  13. May 13, 2024 at 8:17 AM
    BLtheP
    Plano, TX
    PCV was super easy to change during my spark plug replacement. The insulation gets removed by one bolt removal, then you can get to the PCV by pulling the hose off and putting a 22mm deep socket on it. I spun it out and reinstalled the new one by hand. It seals by o-ring, not thread tightness, so it only needs to be spun until it stops. It's plastic so it definitely should not be spun to any degree that stresses the threads.
    Definitely worth checking/replacing PCV before agreeing to any type of RMS repair.
    Curveball30 and YE2KA like this.
  14. May 13, 2024 at 8:25 AM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    I found it was easy enough to get out with a small adjustable wrench while I had some other stuff out of the way to do the spark plugs. I think I used a 6in wrench, but even shorter would be better.
    Mine looked good at 129k miles. Didn't even seem like it was worth cleaning or replacing.
  15. May 13, 2024 at 10:40 AM
    #35
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Cleaned my throttle body at 60k and it had a small stream of oil going from the air cleaner neck to the butterfly. Wiped it out. When I cleaned my dry AFE air filter last week the oil hadn’t returned. Gonna change the pcv just because.
  16. May 13, 2024 at 11:37 AM
    #36
    SilverTRD Sport
    SilverTRD Sport Well-Known Member
    Houston, TX
    2016 TRD Drowned now 2017 Inferno TRD Sport
    Drivers side. Left and right is always as you are sitting in the drivers seat looking forward out the windshield. Not a dumb question.
  17. May 13, 2024 at 11:44 AM
    #37
    M85
    Colorado
    2019 SR ACLB
  18. Oct 28, 2024 at 8:30 AM
    #38
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    What was your millage when you replaced yours
    Anyone have the OEM part number
  19. Oct 28, 2024 at 9:10 AM
    #39
    SilverTRD Sport
    Houston, TX
    12204-0P020 Ventilation Valve Sub-Assembly
    YE2KA and 6MTPro like this.
  20. Oct 28, 2024 at 9:17 AM
    #40
    BLtheP
    Plano, TX
    I replaced at 50K. Nothing wrong with it, but I’m going to keep it refreshed every 50K long with spark plugs. Only reason I did spark plugs so early is I’m turning pretty high rpm on the highway, so I figured do it at 50K to make it easier to keep track of and since they are racking up use more quickly due to the higher rpm. Figured it couldn’t hurt anyways.
    12204-0P020 as posted above.
    andy044, YE2KA[QUOTED] and RotorRPM like this.
