PCV Valve Installation
Discussion in 'Technical Chat' started by killrsurfr, Dec 22, 2010.
  1. Dec 22, 2010 at 4:41 PM
    killrsurfr
    killrsurfr [OP] Member
    Point Loma
    99 Tacoma Pre-Runner
    jiffy lube wanted me to replace my air filter and pcv valve. i stepped up and said not thanks, went to autostore and bought them myselfs and want to install them. time to learn. the air filter was the easiest thing ever, but I can not find the PCV value in my '99 tocama. any suggestion where to look? advise on installation?
  2. Dec 22, 2010 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What engine do you have?
  3. Dec 22, 2010 at 4:46 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  4. Dec 22, 2010 at 4:46 PM
    98tacoma27
    Ben
    Not Beech Creek
  5. Dec 22, 2010 at 7:54 PM
    killrsurfr
    Point Loma
    yes i have the 190 HP 3.4 Liter V6 Automatic.
  6. Dec 22, 2010 at 7:56 PM
    98tacoma27
    Ben
    Not Beech Creek
    Front pass side.
  7. Dec 22, 2010 at 7:57 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    They are just held in with a rubber grommet. Just pull it out (may need a little twisting) and pop in the new one. Easier than an air filter.
  8. Apr 6, 2012 at 8:56 PM
    hawlisjawt
    hawlisjawt Well-Known Member
    Did you notice a better fuel economy with new pcv valve?
  9. Apr 13, 2012 at 2:46 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    I just changed mine. Nothing noticeable but for a few bucks it was an easy sense of assurance to change out the hose, grommet, and valve.
  10. Apr 29, 2012 at 7:05 PM
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    Just replaced pcv valve and grommet. The area around my grommet was fairly moist so I'm glad I spent the few bucks to set my mind at ease.
