PCV valve replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undermoneyed, Aug 13, 2012.
  1. Jul 17, 2013 at 9:40 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Sub'd. Need to do this when I do my next major tune-up, too.
  2. Jul 17, 2013 at 9:45 AM
    Manwithoutaplan
    ID
    Takes about 20 mins roughly.
  3. Jul 17, 2013 at 10:17 AM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    No problem. Might as well do it while I'm in there swapping out plugs and have the tools out anyways.
  4. Jul 17, 2013 at 10:20 AM
    Manwithoutaplan
    ID
    Yea, if you have long arms it will be easier to screw the pcv valve back in. How many miles you got on your truck?
  5. Jul 18, 2013 at 4:48 PM
    mardoqueo galindo
    mardoqueo galindo Well-Known Member
    marcos
    socal
    08 preruner
    toyota 20" wheels,borla double tip exaust,running boards,K&N air filter.
    good job man,thanks
  6. Feb 21, 2014 at 9:10 AM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    173k. Still haven't changed it, but it's getting done this weekend. :eek: Ordered one off Amazon for $3.50 with Prime shipping.
    edit: I have a significant oil leak in the passenger side valve cover gasket. Had it for about 2 years, but in the past 6 months it has gotten more prolific. I'm changing the PCV valve and both valve cover gaskets, and I'm hoping having a very old PCV didn't cause other issues. I'll degrease the engine and watch for future leaks, hopefully nothing from a main seal. I'm running Mobil 1 synthetic.
  7. Mar 7, 2014 at 4:00 PM
    devkurf
    devkurf Member at Large
    midwest
    I just took mine out and cleaned it really good. Mine's got 150,000mi. and I have no idea if its ever been looked at.
    I wiped the excess gunk off with an old sock, then sprayed the inside real good with WD-40 and more gunk ran out. Then I blew it out with compressed air, sprayed with WD-40 again, and blew it out with compressed air one more time. The valve seemed to be quite a bit more free than when I started, and looked clean with a flashlight.
    I also ran a piece of speaker wire through the hose it connects to and pulled a small cutout of the sock through it twice. It was really gunked up as well. It seems better built than the PCV valve on my old chevy which felt really cheap, I don't really see the benefit to buying a new one when you can just clean it up, restore the original functionality and put it back on.
  8. Mar 26, 2014 at 10:34 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I just took my PCV valve out last night. My truck has 54K miles and this was the first time that I have taken it out. It still rattled good after I first took it out. I cleaned it out from both sides with brake cleaner. It did sound like it rattled even better after the cleaning. I applied some never seize to the threads and put it back in and torqued it to 20 ft-lbs like the OP did. It was a ten minute job.
  9. Mar 26, 2014 at 11:39 AM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Yeah it was a piece of cake. I did it when I did my tune up a few weeks ago. Mine still rattled but it was crudded up pretty good and not worth the risk for a <$5 part.
  10. Mar 26, 2014 at 11:46 AM
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    Good info. I guess I should do mine once it warms up especially for a $5 part
  11. Mar 26, 2014 at 2:56 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    It's good maintenance. If it gets stuck closed, you could force too much pressure out of the gaskets and possibly rupture a main seal and have a nice oil leak. I'm just going to do one every time I do spark plugs because it's right there by the driver's side plug closest to the firewall. If you're already in there moving stuff around to get to plugs, you're already clearing a path to the PCV.
    Hay Lobos likes this.
  12. Mar 27, 2014 at 8:52 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    recommend only-oem. They are cheap on ebay w/shipping included from lots of dealers. Non-oem may not open/close as speced.
    If they clog, they will contribute to engine oil contamination although there's a second vent hose on the engines to keep from blowing out gasgets. I've also cleaned them so theoretically they can last indefinitely.
  13. Aug 3, 2014 at 11:27 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I was looking into this today, and the service manual refers to this as the ventilation valve (in my manual, page EC-14)
    For installation, torque the PCV to 20 ft lbs.
  14. Dec 2, 2014 at 8:32 AM
    nevenelestate
    nevenelestate Well-Known Member
    Andrew
    Southern MD
    12 Tacoma V6 4X4 SR5
    Stock
    Sub'd for later use, thanks!
  15. Dec 2, 2014 at 8:35 AM
    #35
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    I did this about a week ago when I was doing the spark plugs. Quick and easy as it was supposed to be.
  16. Dec 3, 2014 at 9:39 AM
    #36
    OCNutty
    Northern, Va.
    Seal blow out is a very real problem;
    Had a front main seal blow out on an old '99 Plymouth voyager; the hose routing for the pcv vent allowed for a low spot that leads to the valve cover. So when the pcv plugged up, moisture started building in the engine and was being expelled thru the vent hose, except the low spot collected moisture and one 25F night the water froze. next morning, blow-by pressure in the motor took out the front main seal. (traded it in - a POS and it had mucho other problems anyway).
    So on the Tacoma, even if no low spots to freeze, it's possible for it to sludge up and cause the same problem...
  17. Dec 3, 2014 at 9:53 AM
    #37
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers, TRD Pro Suspension
    Sub'd
  18. Dec 3, 2014 at 9:55 AM
    #38
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Will be doing mine soon.
  19. Apr 6, 2015 at 2:09 PM
    #39
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Subbeeddddd, this will be part of my next oil change :)
  20. Apr 6, 2015 at 3:57 PM
    #40
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Check the hoses. My pcv valve was good but the hose ends were cracked. The breather hose on the passenger side was also cracked. The breather hose is molded with a sharp bend so I couldn't use a standard automotive vacuum hose. I had to pay like $30 at the dealer for it.
