Pcv valve stuck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Mar 23, 2019.
  1. Mar 23, 2019 at 1:04 PM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Anyone have to use a breaker bar to get a original pcv valve unstuck?
  2. Mar 23, 2019 at 1:09 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    When you get that thing out I am thinking you will want to use a thread chaser and use anti seize to install the new one, you sure don't want to strip that thing out.
  3. Mar 23, 2019 at 1:11 PM
    2009Access4x4
    Shane
    I have Teflon thread chaser with me. Did you have to use a breaker bar too? I tried PB blaster it but No go
  4. Mar 23, 2019 at 1:15 PM
    Flatout110
    Flatout110 Well-Known Member
    Tony
    Long Island, NY
    2019 Tacoma
    Engine oil By-pass filtration system. B&M transmission cooler Rustproofed
    Try heating it up a bit with a propane torch, spray with a rust dissolver, tap lightly with a small hammer and then try to remove.
    Lucifer1 likes this.
  5. Mar 23, 2019 at 1:17 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    I started with a warm engine, penetrating oil and waited overnight, but most don't take this much effort.
  6. Mar 23, 2019 at 1:18 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Mine was hard enough that I gave up so I didn't break anything. I'll try hot engine + PB blaster on Monday and I'll update if the op doesn't.
  7. Mar 23, 2019 at 1:23 PM
    2009Access4x4
    Shane
    I will warm it up and respray with blaster. Thanks
    Beretta4x4 likes this.
  8. Mar 23, 2019 at 3:59 PM
    2009Access4x4
    Shane
    So I warmed it up and it was super easy after that. Does anyone know if it needs to be torqued to a specific amount?
    Lucifer1 and Beretta4x4[QUOTED] like this.
  9. Mar 23, 2019 at 3:59 PM
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
    Tighten snug and a little bit more. Wouldn’t hurt to smear some never seize on the threads.
    Lucifer1 and Beretta4x4 like this.
  10. Mar 23, 2019 at 4:00 PM
    Beretta4x4
    Josh
    Temple, TX
    Word. Definitely doing it Monday
