Pcv valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12retire, Nov 2, 2021.
  1. Nov 2, 2021 at 2:06 PM
    12retire
    12retire [OP] •••••••••••••
    So Cal
    2014 TRD Off Road. Pyrite Mica
    Does anybody ever change their pcv valve? Ive never changed it in any of my vehicles but I guess its an important part. How often?
  2. Nov 2, 2021 at 3:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I changed mine out when i did cam gears as the valve cover was off. Easy peasy part to change regardless if its still on the truck or not. Also just as easy to pull it off, clean it with some brake cleaner and make sure it functions properly.
    NAAC3TACO likes this.
  3. Nov 3, 2021 at 1:33 PM
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    I replaced the PCV valve when I did the spark plugs at about 60k. I can't find any pictures but I recall it was a little easier to get to with the intake off so that is why it is a recommended item with the plugs. I remember the old one being still fine but it was a cheap part so I went ahead and replaced. I'll do it again next spark plug change every 50 or 60k miles is my plan.
  4. Nov 3, 2021 at 3:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Way back a long time ago.
    Before I knew much about cars, I did change a PCV valve.
    My best buddy and I, while in high school, attempted to fix his mom’s Ford Windstar van.
    If we got it fixed, we got to used the van. So, being the teenage kids we were, we bummed a ride to the Auto-parts store. Talked to the guys their, (they should know, right ) They sold us a PCV Valve. It didn’t fix the van. We didn’t have a ride, and I haven’t changed one since.
    Jimmyh, Waasheem and Island Cruiser like this.
  5. Nov 3, 2021 at 3:57 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    I picked on up and will replace at my 60K spark plug, TB, MAF, work coming up in 1k
  6. Nov 3, 2021 at 4:11 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Change mine every two years .....its such a low cost item but an item that is often forgotten to change out all the same!
  7. Nov 3, 2021 at 4:20 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    Change at 80K throw the old one behind the back seat in a zip lock bag as a back up. Just like my belts! Probably no need to but I'm just stupid that way! I would definitely keep the belts as a back up though.
    EdgemanVA likes this.
  8. Nov 4, 2021 at 3:38 PM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    Did mine a couple of weeks ago when I changed plugs. Since it's on the D/S, and I had to move a bunch of stuff anyway, it made sense to get it done. Old one was a little less "springy". To my surprise, the factory one was torqued on pretty good. I didn't go balls out when I installed the new one - monkey-tight, not gorilla-tight.
  9. Nov 4, 2021 at 3:49 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Next spark plug change Im doing mine
  10. Nov 4, 2021 at 4:27 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
