Pedal Commander: does it work?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Comb, Nov 17, 2016.
  1. Apr 14, 2017 at 10:10 PM
    #261
    TooHip
    TooHip New Member
    2016 Tacoma
    Cruise worked exactly the same.
  2. Apr 15, 2017 at 7:19 AM
    #262
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    I installed it last night and tried a few settings around the neighborhood. Sport 2 is the right one for me. Lag is gone.
    I haven't been able to drive it off-road, but Eco felt like it would be awesome in the dirt and rock.
    remgu2000 likes this.
  3. Apr 15, 2017 at 8:02 AM
    #263
    su.b.rat
    su.b.rat broken truck
    i also use Sport 2 as my daily setting. i personally wouldn't say the lag is totally gone, but it is definitely changed and reduced to the point of having fun again.
  4. Apr 15, 2017 at 9:38 AM
    #264
    scornwel
    Fort Worth
    None
    Yeah, after driving up to Costco and back I would agree on the lag. Not totally gone but much more responsive.
    su.b.rat[QUOTED] likes this.
  5. Apr 24, 2017 at 3:59 PM
    #265
    sig916
    sig916 Well-Known Member
  6. Apr 28, 2017 at 12:52 AM
    #266
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    Saw this and had to chime in. I've owned and used one for the past year and whatever the naysayers think... let em think. I went from an 06 prerunner access cab to a 12 crew trd sport 4wd. I was shocked at how sluggish it was. Took the leap, put it on and wouldn't even consider taking it off. I dont really care about mpg to be honest. No I didnt have it on the dyno. This thing works... it is no where near the same as just mashing it harder. Eco works great crawling through the canyon and city gives me a easy time towing. Sport and up are just flat out fun. You dont really get more power out of your engine but it makes it feel like did. Short of a turbo there isnt a whole lot out that does make a really dramatic diffrence.
    su.b.rat likes this.
  7. Apr 28, 2017 at 7:48 AM
    #267
    su.b.rat
    pretty much my experience as well. :thumbsup:
  8. Apr 28, 2017 at 7:50 AM
    #268
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    good to hear on the reviews from a couple of you. I put off purchasing it
    in consideration of the OV tune that dropping soon... no idea on cost though.
  9. Apr 28, 2017 at 7:51 AM
    #269
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    It is absolutely the same as mashing the pedal harder. You would be absolutely no faster in a drag race.
  10. Apr 28, 2017 at 7:52 AM
    #270
    su.b.rat
    I'm with you, waiting on the OV or any proper tune. there will be no full substitute for that, but in the meantime you still need to pay to play... well, speaking for myself. on a truck I've spent probably 10k modding, this $250 unit is the top shelf piece. it brings the fun back.
    and then I start thinking of what kind of fun can be had if we had full VVT from, say, 1500rpm up lol.
  11. Apr 28, 2017 at 7:59 AM
    #271
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    how is the install of the pedal commander? Any worries about voiding the factory warranty?
  12. Apr 28, 2017 at 8:06 AM
    #272
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    I respectfully disagree with you on that one. If you dont have one you know the difference I am referring to.
  13. Apr 28, 2017 at 8:07 AM
    #273
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    Negative, if you were to experience an issue simply unplug it
    remgu2000 and goose443[QUOTED] like this.
  14. Apr 28, 2017 at 8:09 AM
    #274
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    I have had one on my last 2 trucks as well as a car. My bmw had an equivalent built in.
    I know how it feels, and I actually like the effect it has. But don't be fooled into thinking it adds power, "removes lag", or makes your truck faster. It simply amplifies the pedal input to the ecu.
  15. Apr 28, 2017 at 8:10 AM
    #275
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    It is just plug and play. You unplug the connection at your pedal and plug the pedal commander in, the other connection goes to the other side of the pedal commander. Thats it. The wire could be a bit longer but other than that, no complaints
    goose443[QUOTED] likes this.
  16. Apr 28, 2017 at 8:12 AM
    #276
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    True and I stated as much in my post. It does not add power, just feels like it does. But mashing the pedal harder was IMO not the same effect
  17. Apr 28, 2017 at 8:16 AM
    #277
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    I agree it does feel different. Just don't want someone coming in here thinking their truck is magically faster or less lag as that is not what the unit does. It does not Rev faster. It simply amplifies throttle input.
    It is a cool device though
  18. Apr 28, 2017 at 8:25 AM
    #278
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    Agreed
  19. Apr 28, 2017 at 8:37 AM
    #279
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    @gainman You watched the video of how it works. It is not the same as just mashing the pedal. It opens the throttle plate much faster than is allowed stock.
    Correct, it does not add power, but it makes the vehicle more responsive.
    Will it cost you mpg's, yep.
  20. Apr 28, 2017 at 8:40 AM
    #280
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Yes. You know what else opens the throttle plate faster? Pushing the pedal faster.
    You have to remember, this thing is getting a voltage in and a voltage out. It doesn't reprogram anything or magically swap a new throttle plate motor in there
