Pedal Commander: does it work?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Comb, Nov 17, 2016.
  1. Nov 23, 2016 at 2:28 PM
    #141
    LSartore
    LSartore Member
    Larry
    16 TRD PRO
    #1 My product is not made in China.
    #2 We have designed PC with multiple failsafes installed... it was not cheap and or easy... if anything fails it does not give out a signal... same thing that your TPS is designed to do... gotta remember what we are doing is not rocket science and companies have been doing this for a long time and even sometimes "rebrand" products.... check out Remus pedal controller....
  2. Nov 23, 2016 at 2:34 PM
    #142
    LSartore
    LSartore Member
    Larry
    16 TRD PRO
    just as much as that intake you have installed was certified by the EPA, CARB and the rest.... go find something better to do then bash my product...
    now your really upset cause you were a nay sayer and now all the reviews are coming in from people that bought them and its getting good positive reviews so your clinching for straws now to save that 3K message reputation...
    TRDPugz likes this.
  3. Nov 23, 2016 at 2:39 PM
    #143
    T4RFTMFW
    T4RFTMFW Well-Known Member
    On a side note, good product or bad product, nobody enjoys seeing a manufacturer or manufacturer representative in online pissing matches. It's a great way to not get future sales.
    Something to consider. @LSartore
    Products speak louder, if it's good, let it talk for you. No need to get into stupid arguments and dick measuring when you're representing a business.
    Mully, Tcoma16, JasonCz and 4 others like this.
  4. Nov 23, 2016 at 2:56 PM
    #144
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Good advice
  5. Nov 23, 2016 at 3:18 PM
    #145
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I'm waiting for the latest word from Chase and ZeroSpeed about a possible MPG gain in ECO mode.
  6. Nov 24, 2016 at 4:08 AM
    #146
    '16TacomaTRD
    '16TacomaTRD Well-Known Member
    2016 White Tacoma TRD Sport w/ premium tech & JBL package
    I would love to have your product. However, the only thing holding me back from ordering it is whether or not it could void any warranty. Do you or anyone else know if it would void any warranty?
  7. Nov 24, 2016 at 6:41 AM
    #147
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This is on the Sprint booster, but same thing:
  8. Nov 24, 2016 at 6:41 AM
    #148
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For those who cant see the full text:
    Actual Benefits
    The benefit of a sprint booster is that you do not have to push the accelerator pedal as far to achieve the acceleration you desire. You are saving some foot effort. There is no difference between installing a sprint booster to changing your driving style to operate the throttle in a more jerky fashion, for example flooring it violently when taking off. The only improvement in throttle response is the time it takes to push the accelerator pedal harder. This is not reaction time of the driver. It is not the time it takes to decide to floor it. It’s the extra time required to move the pedal a bit more, given you are already moving it. I estimate for example it may take an extra 1/10 of a second or 100ms for the throttle to travel from 50% to 100% if you are already moving the throttle from 0% to 50%. So in a typical scenario where you want to accelerate hard, you’ll be better off by something in the order of 1/10 of a second with the sprint booster installed. Unless you accidentally break traction due to the reduced throttle precision, in which case you’ll be faster without the sprint booster. So if possibly saving 1/10 of a second is important to you, or saving the effort of moving your foot is important for you, then a sprint booster may be a good idea.
    Disadvantages
    Installing a sprint booster means the available travel in the accelerator pedal is not fully utilized. There is a large dead zone where the voltage sent to the engine management is 100%. This means you’ve lost precision in throttle control. You’ve lost resolution. Your ability to make small adjustments to throttle has been degraded.
    Using more throttle and having a more jerky driving style will cost you more fuel, wear out your car more and increase your chances of having an accident. It also encourages poor driving habits – for example accelerating hard then braking hard in stop / start traffic rather than just driving at a steady speed.
    Offroad, a sprint booster makes it difficult to control your vehicle. Movement of your foot caused by vibration or bumps translates to much larger accidental changes to throttle then what would occur with a standard setup. Your ability to make small changes to throttle is compromised, yielding an amateur like driving style over rough terrain. Many sprint booster users will de-activate their sprint booster when offroading. Actually some vehicles automatically do the exact opposite of a sprint booster when low range is engaged in order to improve precise vehicle control. The disadvantages of sprint boosters whilst offroading are also present when on the road, but the effect is more pronounced offroad due to the rough terrain and the requirement to precisely control speed and torque whilst offroad.
    Throttle Filtering
    A sprint booster cannot circumvent the filtering performed in the ECU. Whether people describe a sprint booster as a “proportional controller” or talk about “digital setpoints” or “controller gain” or “ramp up” or “tuning” is irrelevant.
    The accelerator pedal transducer is a potentiometer with a voltage across it. It is not an intelligent device. There are no time delays or filtering performed within the accelerator pedal transducer. The filtering is done in the ECU. Why? Why would the vehicle manufacturer add complexity, expense and points of failure within the accelerator pedal transducer when that capability is already there in the ECU? Add a few lines of code and it’s done in the ECU without any extra hardware, cost or potential points of failure. Also, filtering removes information. You want to remove information only at the point where there is no disadvantage to removing it. In the case of the throttle position, the sensor usually consists of two potentiometers which both report directly to the ECU. This means the ECU is able to detect problems which otherwise could pose a safety risk. High frequency noise, step changes in signal or transient discrepancies between the two signals can be used to rapidly detect problems. Filtering at the throttle transducer would mask these issues. Diagnostic ability would be lost. Instead, the raw data is read from the device and interpreted and manipulated as required using software within the ECU. The raw voltage signals from the transducer go to the ECU where diagnostics are be performed. After that the signal is filtered and processed within the throttle controller.
    So filtering occurs within the ECU, not within the accelerator pedal transducer. This means it’s physically impossible for a sprint booster to circumvent the ECU filtering. The filtering is occurring within the ECU, after the sprint booster. The sprint booster is not changing the ECU’s software.
    What does the ECU filtering do and how does it impact the performance of a sprint booster? Engine management may filter the incoming voltage signal to make the throttle control smoother. It’s called a low pass filter. Fast changes are filtered out. High frequencies are filtered out. This manifests as a maximum rate of change that the throttle can respond to. So even if the voltage signal from the accelerator pedal instantaneously jumps from 0 to 100%, the actual throttle will be limited in how fast it can react so that it takes some minimum amount of time to open fully. As an example, lets pick a value – say 0.2 seconds. This means that no matter how quickly you change the voltage signal, if you change it at a rate faster than the rate equivalent to 0 to 100% in 0.2 seconds, it makes no difference to the actual throttle response. So engine management filtering actually masks the response of a sprint booster. Some people argue that the sprint booster will help overcome the engine management filtering. This is impossible. The filtering is occurring after the sprint booster. The engine management does not know whether the voltage signal is coming from a sprint booster or directly from the accelerator pedal. It will always limit the rate of change in throttle the same way. It is incorrect to suggest that the engine management’s filtering somehow enhances the response from a sprint booster. It will always dampen the response. So the time saving of 0.1s from having to move your foot less will always result in less than 0.1s improvement to throttle opening time. Part of the increase in speed from the sprint booster is filtered out. Faster signals get filtered more. If you are already at the limit without the sprint booster then adding a sprint booster would make no difference at all. So, for example, if you can already move the accelerator pedal from 0 to 100% in 0.2s which corresponds to the maximum rate of the throttle filter, then adding a sprint booster and reducing the time it takes for the throttle position to reach 100% by 0.1s will have absolutely no impact to the actual throttle opening time. The filter is already saturated before adding the sprint booster.
    SpoilsofWar likes this.
  9. Nov 24, 2016 at 6:55 AM
    #149
    SpoilsofWar
    SpoilsofWar Well-Known Member
    Wilmington NC
    2014 DCLB 4x4 TRD Sport Super Charged
    Wow lots of info
  10. Nov 24, 2016 at 7:17 AM
    #150
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Where is it made? Can we see some manufacturing photos?
  11. Nov 24, 2016 at 8:43 AM
    #151
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Turkey is better than China...IMHO.
    dYL0n likes this.
  12. Nov 24, 2016 at 8:45 AM
    #152
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I mean.....especially today......
    Comb[OP], T4RFTMFW and oorah54 like this.
  13. Nov 24, 2016 at 9:27 AM
    #153
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Seems everyone who has this product and doing reviews, has a low post count.
    facefirst and chris4x4 like this.
  14. Nov 24, 2016 at 9:43 AM
    #154
    Taco16LB
    Taco16LB Well-Known Member
    It also seems a lot of posters think nothing of spending $1000's more for new tires and rims and $1000's for lifts and $500 and more for a new plastic grill and $150 for a fricking shift knob, etc. ect.. I would think $280 for a pedal commander would be cheap enough just to have as a toy to try off road without blinking.
    I am not defending the product but come on , get real !
  15. Nov 24, 2016 at 10:21 AM
    #155
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Completely agree with you, which is why I was thinking that!
    You clearly haven't read the Cheap Ebay Bumpers thread.
  16. Nov 24, 2016 at 10:25 AM
    #156
    Taco16LB
    You are correct . I will do it just to see what is happening .
  17. Nov 24, 2016 at 10:26 AM
    #157
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Long story short someone came in being like "Wow, check out these bumpers!" and he worked for the company, and other "users" came in that were also workers for the company.
    Lawfarin likes this.
  18. Nov 24, 2016 at 10:28 AM
    #158
    Taco16LB
    Got you . Thanks.
  19. Nov 24, 2016 at 10:47 AM
    #159
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    I've been reading this page and your continued slamming of the product is irritating.
    For us manual trans guys, starting on a hill with this truck is very annoying given the delay and the dead pedal feel. I raced my ranger all over steep WV mtns and such, no issues... The taco, bogs in a parking lot...
  20. Nov 24, 2016 at 10:54 AM
    #160
    AFMurse2014
    Devin
    San Antonio
    Trying turning trac and vss off. The vehicle might be sensing hard acceleration and cutting power initially.
