Pedal Commander installed....WOW
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Oct 31, 2020.
  1. Feb 1, 2021 at 8:37 PM
    #101
    badger
    badger Well-Known Member
    07 SR5
    I have a sprint booster on the way. One issue that drove me crazy for a long time with my Tacoma, was that the lag completely destroyed my shift timing with my 6 speed. I've spent a lot of time in race cars, so I know how to shift, but I literally had to relearn how to drive this thing. Up shifting is bad enough, but downshifting? FFFFFT. I should have done this a long time ago.
  2. Feb 1, 2021 at 9:17 PM
    #102
    6 gearT444E
    Deep South
    Herculiner Hootus
    You can take a nap in between shifts the way the lag and the rev hang is on these trucks.
    Toyota needs to take some lessons from Honda, my drive by wire 6 speed accord and f350 feel like a 180 compared to the Tacoma.
    badger[QUOTED] likes this.
  3. Feb 1, 2021 at 10:43 PM
    #103
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    When I would drive other vehicles like my bosses f150, I would think this thing has so much torque cause the gas pedal is so touchy. But when I floor it, it’s not fast. So it’s actual the program of the drive by wire.
    I had my Xrunner ever since 2015 and been racing it ever since. I don’t street race anymore but i like to open her up once in a while and the lag in between shifts always kills me. I’m shifting the fastest I can but still doesn’t “go”. Now with the sprint booster having it a couple month ago solved that issue. Feels touchy like my bosses f150 at certain settings.
    So it “feels” torque only cause the throttle is opening up quicker/sooner even if pressed lightly.
    My only regret is not getting this device in my racing days lol
    Lynntropy and tinker_troy like this.
  4. Feb 1, 2021 at 11:16 PM
    #104
    Xmplry808
    That being said. For normal driving it’s not necessary but if you want to make it a bit more exciting then this is for you. Coming from a supercharger owner, that feeling of having a good throttle response, makes a world of a difference
    tinker_troy likes this.
  5. Feb 2, 2021 at 5:02 AM
    #105
    badger
    07 SR5
    Exactly. Initially I fought it, but slow and smooth is the only way this truck will shift. Forget about throttle blips, rev matching and all the rest.
  6. Feb 2, 2021 at 12:27 PM
    #106
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    I don't even bother with the clutch anymore. It's pointless after starting out in first gear... :(
    I use the clutch on downshifts because of the dumb rev hang.
  7. Feb 4, 2021 at 7:43 AM
    #107
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    Have you ever used one?
  8. Feb 4, 2021 at 7:45 AM
    #108
    JGO
    How many hours have you driven using one?
  9. Feb 4, 2021 at 7:46 AM
    #109
    JGO
    You base this on personal experience or your imagination?
  10. Feb 4, 2021 at 7:56 AM
    #110
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    I'll tell you the same info as @nd4spdbh and yes I have one. Answer this; how can you add wires and a component to the throttle circuit and yet decrease throttle lag?
  11. Feb 4, 2021 at 7:59 AM
    #111
    Shawner1974
    Shawner1974 Well-Known Member
    Shawn
    CNY
    2012 Base Tacoma 2.7. 5 spd Regular Cab
    I have had my Sprint Booster installed for 3 weeks now. I really like it. I set it at Sport 5 then I unhooked the controller and put it away. It now stays at that setting permanently. Haven't had any issues this far.
    Lynntropy likes this.
  12. Feb 4, 2021 at 8:00 AM
    #112
    JGO
    The 'component' does what it is designed to do, that should be obvious. IF you have one and find no differece when using it then you should re-read the installation instructions, you installed it wrong.
  13. Feb 4, 2021 at 10:08 AM
    #113
    Boomkanani
    Goldsboro, NC
    Some stuffz
    Yes, and that component "is simply simulate you pushing on the gas pedal further than you are.... Hate to break it to you that is it." You're lying to yourself and others if you claim otherwise. It has a use and convenience, but don't take offense when people explain the "how."
  14. Feb 4, 2021 at 10:35 AM
    #114
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    FBW is supposed to be an improvement. But now I need to spend $200.00 or $300.00 hundred dollars to purchase & install a new "Throttle pusher" to get throttle back to operating as good as it did before this improvement was put on there. PUT THE DAMN THROTTLE CABLE BACK ON THERE & THROW THIS FBW PIECE OF SHIRT AWAY!!!!!! Please just put the cable back ..... Just my opinion.
  15. Feb 4, 2021 at 12:13 PM
    #115
    JGO
    And you have little to no idea what it is that you are talking about. The effect does not merely simulate stomping on the gas pedal and, if you had one as you say you do, then you would know that. Face it bud, you are typing here in utter ignorance. Those of us who use these devices understand that.
    akojsp likes this.
  16. Feb 4, 2021 at 12:29 PM
    #116
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If you understood the electrical circuit at play here you would understand why the pedal commander / spirit booster inline pedal things do nothing more than simulate pushing on the gas pedal more or less than you actually are. Its a simple analog circuit, reference voltage in, and the further the pedal is pushed reference voltage increases or decreases (depending on the way the potentiometer is wired) at the same rate. The ecu takes this voltage back and compares it to the reference voltage and calculates how far you are pushing the gas pedal. YOU CAN NOT REPORT BACK A HIGHER THAN REFERENCE VOLTAGE OR LOWER THAN 0...
    THATS ALL THE ECU SEES. REGARDLESS OF ANY DEVICES, SWITCHES, ETC PLUGGED INLINE TO THE THROTTLE PEDAL.
    You could literally put an on off switch in place of the throttle pedal to simulate 0 to 100% gas pedal pushing as quick as possible and the throttle body would only move as fast as the ecu would let it (which is almost instant unless a traction control event takes place - also do not put a switch in the throttle pedals place).
    I dont understand why this is so hard to grasp.
    EDIT - Diagram - Two simple sweeping analog potentiometers within the gas pedal assembly.
  17. Feb 4, 2021 at 12:36 PM
    #117
    Shawner1974
    Shawn
    CNY
    I can only write about my experience with the Sprint Booster, and I'm not here to argue about how it works and I won't pretend to know how it works. As some have said, it simulates mashing on the gas but I personally feel it's not just that...there's a time element involved. I personally like mine, and feel I paid for a better driving experience, much the same as how the intermittent wiper mod made my driving experience better. To each their own. As far as more HP or torque increases...no way. I can see how some people may feel like it does but that is illusory.
    Lynntropy and JGO like this.
  18. Feb 4, 2021 at 12:41 PM
    #118
    nd4spdbh
    SoCal
    Some more information for those who actually want to read up on how the throttle pedal works and its simplistic nature of analog cicruits. I digress i was wrong above they are not potentiometers but contactless hall effect sensors... needless to say they go about doing the same exact operation but via a slightly different method....
    https://www.safetyresearch.net/Library/Preliminary_Report022110.pdf
    Pages 5 and 6 are of value
  19. Feb 4, 2021 at 12:58 PM
    #119
    Shawner1974
    Shawn
    CNY
    That's good info! Now I don't know much about electronics, but Hall Effect switches are magnetic, right? We use lots of those type sensors at work.
    nd4spdbh likes this.
  20. Feb 4, 2021 at 2:49 PM
    #120
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Reading all this stuff & trying to understand. It seems fairly simple. If I drive my stock Taco & push the pedal to the floor there is appx 6 sec. lag, will take 6 sec till throttle is wide open. With a pedal commander push the throttle to the floor & it will take maybe 3 sec. depending on the setting for the throttle to be wide open. No doubt it should feel peppier as the throttle is opening quicker. I also see why just mashing the pedal more wouldn't do the same as the pedal commander, no matter how much you push the pedal the computers still only open the throttle as fast as "IT" wants to, the pedal commander makes the computer open the throttle quicker thus the more responsive feel without any increase in HP or torque. Now Back up to post 114, If they still had a cable from the pedal to the throttle your foot would control how fast the throttle was opening, like it did for the past 100 yrs & there would never have been any discussion about Pedal commanders, do they work, do they not work, do I need to spend $300 to get it to run as well as it did with a cable, do they have potentiometers, is it analog, are they snake oil, do they mess up the electronics. Put the cable back & throw throw FBW away....After reading all this I'm now wondering if this is why I was always happy with my old "98", RC, 2.7, 4X4 Taco & have been terrible disappointed with my 2013, RC, 2.7, 4X4 Taco ever since I traded 2 1/2 yrs. ago. If this Pedal commander will make my 2013 feel like my old "98" did it would be well well well worth the cost. Also from the past 6 pages of reading it seems the cheaper ones do about what the expensive ones do. I don't mind spending more if I'm getting more, but I really hate spending twice as much & getting the exact same thing. Any recommendations?
