Pedal Commander installed....WOW
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Oct 31, 2020.
  1. Feb 6, 2021 at 4:33 PM
    #141
    dbbd1
    dbbd1 Well-Known Member
    For the record, I did have one, on my 2016 Yukon, and returned it.
    You can't beat a tune.
    Boomkanani likes this.
  2. Feb 7, 2021 at 2:12 AM
    #142
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    1EFB55B1-8193-42FD-BA29-4273693E0514.jpg ED02E93A-1EFC-416C-97B2-03288B5A9562.jpg
  3. Feb 7, 2021 at 4:40 AM
    #143
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    That’s. Given but a tune dependent on price can be double or more the price
  4. Feb 7, 2021 at 7:23 AM
    #144
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
  5. Feb 10, 2021 at 10:45 AM
    #145
    MarcoTaco
    MarcoTaco Active Member
    Mark
    South Maryland
    2017 TRD Sport Taco 4x4 Acc Cab A/T V6
    Hellwig rear leaf, BFG 265/70 KO2 tires, Method rims, Bilstein 5100 frt struts, OVT
    Glad someone NAILED this! (Thank you Badger) I believe this post needs no more said.
    I am getting ready to pull the trigger on a Sprint Booster myself, but I am hoping that it stops the "floating RPMs" ALONG WITH pedal lag in the throttle.
    When I sold my SC T-100 and all of its URD mods, I promised myself (and my wife) I wasn't going to throw the extra thousands on the new Tacoma.
    So although Gadget might miss the added profit a tiny bit, I have been happy having something I don't have to stay up late working on.
    But the OEM issues with the Gen 3 FORCE anyone who enjoys fine powertrains and matched components to GO BAT$HIT CRAZY. It is just a mess!
    The 6 speed tranny shifts HORRIBLE, the throttle floats forever, (when you release it AND when you nail it) and they left too much power in that 3.5L engine on the shelf and wasted.
    The OVT guys did a half-baked job in the engine department, but left the rest stumbling. I tried the ShiftSense Pro - and it too just isn't enough.
    I am going to dump this last $300 into it - THAT IS ALL! Toyota HAD their best pickups when they put those 4 cyl 22R engines in them. Hate to say it but they will be forgotten soon if something MAJOR isn't done - AND I AM A FAN! Our other car is an Avalon Ltd and we love it. But my A/T V6 2017 TRD Sport 4x4 access cab is sad - considering its looks, legacy, and cost.
    And I think Scotch or Bourbon may be required Badger - beer might not do it. (But we COULD try).
    JGO and Shawner1974 like this.
  6. Feb 10, 2021 at 2:20 PM
    #146
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Just wanna say. HI getting them SEXY 2012+ xrunners. mmmm.
    TacoSalad119 likes this.
  7. Feb 13, 2021 at 7:46 AM
    #147
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    Don't like it, don't buy it. Why spend so much time on something that you don't have and that you don't don't want?
    I have the Sprint Booster, I like it. I'd get another. I recommend you get one for yourself then you could speak with both authority and experience. They have a thirty day return - no questions.
    As Chef Boyardee used to say back in the day, "Try it, you'll like it".
    Lynntropy, hemitruk and tinker_troy like this.
  8. Mar 20, 2021 at 2:56 PM
    #148
    TacoSalad119
    TacoSalad119 Active Member
    18 TRD SPRT M/T
    Does anybody have any experience with a pedal commander or similar product on a 3rd gen manual transmission?
  9. Mar 20, 2021 at 3:35 PM
    #149
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    TacoSalad119[QUOTED] likes this.
  10. Mar 23, 2021 at 1:37 PM
    #150
    MonsterGuy
    MonsterGuy Well-Known Member
    Hill Country, Texas
    2009 DCLB TRD Sport 4x4
  11. Mar 23, 2021 at 3:48 PM
    #151
    Jacked Burton
    Normal mode felt exactly like it did before I installed it.
    It has 5 other levels eco,eco +,sport,sport+,race with 9 adjustment that can be made in each.
    It also had an auto mode which learns how you drive and adapts accordingly.
    I tried race mode on the 9th adjustment for shits n giggles and it will snap your neck back and breakloose the tires easily.
    I like it on sport+ about 6th notch, gets my 35s going nicely.
    Pedal Commander functions exactly the same except less adjustability but has does have bluetooth/app feature where mine doesn't(don't care).
    Lynntropy and MonsterGuy[QUOTED] like this.
  12. Mar 23, 2021 at 4:12 PM
    #152
    Zman37
    Zman37 Member
    Adam
    2019 Tacoma TRD Off Road Black premium pkg
    Just to be clear this is not a performance chip, or a reprogram to add power....It changes the resistance of the gas pedal.
    I was on the fence, but decided to get it. So The difference is night to day. Lag is gone. adjustable sensitivity is perfect. Im in city mode +2 and my gas mileage has actually gone up by 1.5mpg. No more issues approaching hills. And the truck doesnt seem to be looking for the right gear anymore.
  13. Jun 15, 2021 at 10:21 AM
    #153
    Lynntropy
    Lynntropy Active Member
    Lynn
    NV
    2006 TRD ORACLB 6-spd 6-cyl
    Hey thanks, this video did it for me. 1:07 speaks for itself.
    JGO likes this.
  14. Jun 15, 2021 at 10:59 AM
    #154
    JGO
    I have had the Sprint Booster for quite some time now. No buyer's remorse. It does what it says it will do and I am very pleased with mine. I have a '14 with the mighty 2.7 and an automatic transmission. Whether such a product is worth the cost, I can only answer for myself. SB does offer a 30 day money back guarantee, so the risk is the time you spend installing and the fact that SB has your money while you decide.
    Point 1.07 and a few seconds beyond - you can feel that quickened response.
    charliehex likes this.
  15. Jun 15, 2021 at 11:12 AM
    #155
    charliehex
    charliehex I belong in the dirt.
    Charlie
    Phoenix, AZ
    2021 Barcelona Red TRD OR DCSB
    285/70/17C BFG All Terrain TA KO2 Method 701 - Bronze 3”F/1"R Spacer Lift Sprint Booster MESO: Gasshole, Map Lights, Sequential Turn Signals Rough Country: Speedometer Calibrator, F/R Seat Covers R4T: Tail Gate Remote Rago: Center Console Molle Panel sPOD: Switch Controller Lamin-x: Amber Fog Light Covers ARB: Twin Compressor Slee Off Road: ARB Twin Compressor Mount Expedition Essentials: 3TPAM Accessory Mount RAM Mounts: Short, Long, Long arm, GoPro Mount
    I got an SB a few days after buying my 3rd Gen and finding out you have to put your foot through the floor to make a left turn in traffic or merge on the freeway. It does what it says it will; give you the ability to make your throttle up to 1:1 of your pedal input. I like it at Sport 5 for city driving. I’m migrating to a tune to improve shift points and a few dudes said not to use the SB with a tune so I’m going to get rid of mine if anyone wants it.
    Lynntropy likes this.
  16. Jun 15, 2021 at 1:28 PM
    #156
    Lynntropy
    Lynn
    NV
    Oh, thanks, I have no doubt. ;) That throttle body draaagging open and draaagging closed is just *absolutely ridiculous*. I bought a 2nd gen (2006 6-spd) for that sweet spot between an actual mechanical vehicle and a computer on wheels, so fixing up that pesky little drive-by-wire issue I think she'll be even more fun. :)
    I was on the fence about which unit, but I liked a few more things about the Sprint Booster (can disconnect it, small control in case I want to keep it connected, appears to be the original patent in the field, etc). So for kicks, I followed the link in that YT video (https://sprintboosternow.com/) and called the phone number to see if someone would answer the phone and answer my questions - and that finalized it for me.
    https://sprintboosternow.com/ is the domain that Burtman Industries uses to sell the Sprint Booster, for $289.99, and they're (Burtman) the only sales arm with a 5-year warranty situation with the manufacturer. (I checked a few of the other similar domains and found 3-year and $299.99 most places.)
    Jason answered the phone quickly, answered my questions right off the bat (Yes, there is a mode which can act like a theft prevention by disabling the throttle completely. No, it doesn't interfere with remote start systems.), he mentioned a couple other things (like the manual/automatic switch on the side of the unit), and then we got into manual transmissions, Toyota generations (he's got a '97 4Runner), Sprint Booster versus the others, etc.
    Long story short, I like the 5-year warranty, like to support the original patent, and I like that somebody will answer the phone with experience in the unit both installing it and using it.
    JGO[QUOTED] likes this.
  17. Jun 15, 2021 at 7:43 PM
    #157
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I just can't figure why anyone "WHO HAS NEVER TRIED ONE" wants to act like they know all about them. Then there's the guys like ddbd1, in posts 129 & 136 he wants someone to give him one or buy him one so he can try it out & then give an honest review, the next day he said he had already had one & sent it back. Kind'f seemed he wasn't thinking too straight. Then there's all the charts & electronic talk, charts & talk do nothing but look official. I know some of these folks think they know what they are talking about, but how can they argue with the folks who "HAVE TRIED THEM" & appx. 95% given pos. comments & are completely happy with "THE DIFFERENCE THEY HAVE SEEN". Also with the Sprint Booster 30 day return policy, for any reason, & full refund why don't they try one except they are afraid of being shown they were wrong. I talked myself into a SB in late Feb., got it installed & love it. I thought after a while the new would ware off & I would no longer notice the improvement, but no, now everyday I enjoy driving the same Taco I had been so disappointed in for the past 2 1/2 yrs. Also another idea, I mounted my controller on the inside edge of the glove box, wire plenty long to run under the dash then in from the back & attached with vel-cro that they supplied, Handy to get to if needed & nothing visible anywhere. Congrats to those who have & enjoy them. And to the naysayers, Please just try one.
    Lynntropy, Hawapino and charliehex like this.
  18. Jun 15, 2021 at 8:38 PM
    #158
    nd4spdbh
    SoCal
    If i showed you a video of a stock truck without a pedal commander / spirit booster opening a throttle blade of the throttle body quickly and in sync with the throttle pedal would you understand what us people with actual knowledge of how the system works are trying to get at?
    I dont need to jump off a cliff to understand its a bad idea....
  19. Jun 15, 2021 at 8:43 PM
    #159
    charliehex
    Charlie
    Phoenix, AZ
    I would like to see this vid. Not even being sarcastic.
  20. Jun 15, 2021 at 8:54 PM
    #160
    nd4spdbh
    SoCal
    I think im going to be freeish on friday. Ill rig up two web cams to my computer to record two things at the same time so i can get throttle pedal inputs and throttle blade opening in real time for yall to put this shit to bed.
    charliehex[QUOTED] likes this.
