Pedal commander
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crazycardfan1, Jan 11, 2020.
  1. Jan 17, 2020 at 7:06 AM
    #41
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    So, it connects to the wire connector that goes to the pedal.. i thought it connected to the OBD port. Sounds easy and straight forward. Thanks!
    crazycardfan1[OP] likes this.
  2. Jan 17, 2020 at 7:07 AM
    #42
    El Latigo
    Anaheim CA
    Fair enough.. :thumbsup: Thank you sir,
  3. Jan 17, 2020 at 7:10 AM
    #43
    Skindiver808
    Skindiver808 FROM THE BIGISLAND
    MOUNTAIN VIEW, HAWAII
    2020 TACOMA OFFROAD 4X4
    STOCK FOR NOW
    discount code I used on PC website for 20%off code- PC20
    I should have it in, in a couple of days. will keep you guys posted.
    gasgasman and crazycardfan1[OP] like this.
  4. Jan 17, 2020 at 7:23 AM
    #44
    crazycardfan1
    crazycardfan1 [OP] Active Member
    John E.
    2019 TRD Pro
    5 minutes.
  5. Jan 17, 2020 at 7:30 AM
    #45
    crazycardfan1
    John E.
    2019 TRD Pro
    I've had mine for a week now and I just cannot believe the difference in it! The thing about it is I drive like grandpa so you know it must've been bad.
  6. Jan 17, 2020 at 7:30 AM
    #46
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    What about for a manual transmission?
    I'm used to how the truck drives now, but anybody else who dives it asks what's wrong with it.
  7. Jan 17, 2020 at 7:42 AM
    #47
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    Throttle response is improved on either the MT or AT. Throttle response is unrelated to transmission option.
    Install is plugging online to the connector at the accelerator pedal. Click. Click. Mount the unit. And set the setting to your choice.
  8. Jan 17, 2020 at 8:00 AM
    #48
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    My question was vague. I was wondering if anyone with a manual transmission had done it yet and if they like it.
  9. Jan 17, 2020 at 8:04 AM
    #49
    Color_Me_Taco
    Doug
    Utah
    Yes. I have a MT and had one installed for over a month before tuning thru OV. It does everything its advertised to do. And had 32 level of settings? 4 main settings and the ability to fine tune from 4 to -4 on each. It's hard not to like for the low cost.
  10. Jan 17, 2020 at 8:05 AM
    #50
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    Thank you!
    Color_Me_Taco[QUOTED] likes this.
  11. Jan 17, 2020 at 8:08 AM
    #51
    su.b.rat
    su.b.rat broken truck
    same. used the PC for about 6 months, that was before OV was here. when the alpha files showed for the MTs i removed the PC and never looked back. it was great. but i needed a real tune, not a work around.
  12. Jan 17, 2020 at 11:36 AM
    #52
    Super Guest
    Super Guest Active Member
    Adam
    2019 Tacoma TRD Sport
    Where is the best place to buy?
  13. Jan 17, 2020 at 11:55 AM
    #53
    Color_Me_Taco
    Doug
    Utah
    Direct, usually. Keep your eye out as they normally run sales up to 20% off.
  14. Jan 17, 2020 at 12:03 PM
    #54
    Skindiver808
    STOCK FOR NOW
    Code- PC20
  15. Jan 17, 2020 at 12:18 PM
    #55
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    IMG_20200115_181942891_MP.jpg I got the SB shipped to my door for $260. The PC and SB are the same but if you want something with a better warranty, a lot smaller unit to hide and way easier to set than the PC. Also once you set your level you like then you can remove the controller completely. SB was the first company to invent this.
  16. Jan 17, 2020 at 12:40 PM
    #56
    choose for me
    choose for me Not Sure
    Northwest Florida
    2017 Toyota Tacoma TRDOR
    Flux Capacitor
    PC significantly reduces the lag time, but there's a balance between PC setting and driveability. You can eliminate the time, but you may end up jumping an extra gear on the downshift. Your concerns were my #1 gripe about the truck, and I find that the Sport -2 setting is the best balance for me in terms of overall driveability and mitigating this issue.
    I got about .5 MPG increase. On the instant MPG gauge, I can watch the truck struggle in 6th gear at 40 MPH and lose MPGs. PC helps me maintain this speed in 4th of 5th gear, and the MPG is noticeably higher.
    Please note the PC states to unplug the battery when installing/uninstalling the unit. I called BS on that and removed it without disconnecting the battery when I was rerouting the cable. I got a message stating that my pedal was disconnected, so I ended up having to disconnect the battery to make it go away. I was wrong.
  17. Jan 17, 2020 at 12:55 PM
    #57
    Shouldnthave
    Shouldnthave Where all the white women at?
    Jay
    TRD-OR Trail Limo
    I followed their actual instructions but waited 15 minutes instead of five. Had zero issues.
  18. Jan 17, 2020 at 12:58 PM
    #58
    arcticrobot
    arcticrobot Well-Known Member
    2017 TRD Sport manual
    I am on OVTune 2.0 beta 93 octane and manual transmission. You are saying that Pedal Commander is not needed with this setup? I am actually still trying to understand what it does and whether it is a snake oil or not.
    su.b.rat[QUOTED] likes this.
  19. Jan 17, 2020 at 1:07 PM
    #59
    choose for me
    Northwest Florida
    Flux Capacitor
    Maybe they changed it. I installed one on my 3rd gen and my dad's 2nd gen, one bluetooth and one not, and both stated to disconnect the battery.
  20. Jan 17, 2020 at 1:44 PM
    #60
    su.b.rat
    the PC is definitely not snake oil. it does exactly what it is designed to do, modulate the throttle signal heading to the ECU. if you have X amount of power at whatever rpm, the PC won't change that, it will just spoof your throttle position as if you're giving it more throttle. OVT changes everything with the ECU's tune itself, so changes the power level and whatever rpm, too. you can use both together but OV's tune should have the throttle exactly where you want it and that's part of the tune you're buying: throttle response. i would not use both together, doesn't make sense, too many cooks in the kitchen. if you're in a MT then you definitely don't want both, that's just a mess.
