Pedal commander
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crazycardfan1, Jan 11, 2020.
  1. Jun 27, 2021 at 7:26 AM
    #121
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    There is no such thing as 100% of throttle on our tacomas. You can have100% of accelerator pedal
    The throttle is limited by ECU.
    On stock ecu, the amount of accelerator does not reflect the amount of the trottle.
    ECU limits the throttle for each gear, also wont allow to advance trottle under heavy loads..
    PC just allows you to get to those limits faster, but does not eliminate the issue
    Pablo8 likes this.
  2. Jul 7, 2021 at 8:24 PM
    #122
    r81984
    r81984 Active Member
    2017 Black Tacoma TRD Sport 2WD 6cyl
    That is my point. It just takes you to the 100% of what you can already do, but making you not have to push the pedal down as far. Seems like no benefit while adding another point of failure on your throttle.
  3. Jul 7, 2021 at 8:46 PM
    #123
    Pengowirr
    Pengowirr Well-Known Member
    2018 TRD Off Road Manual Transmission Cement
    265/75/r16 Cooper ST MAXX
    How would this work for a MT?
  4. Jul 7, 2021 at 8:47 PM
    #124
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Pointless.
  5. Jul 7, 2021 at 8:48 PM
    #125
    Pengowirr
    dang
  6. Jul 14, 2021 at 3:58 PM
    #126
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    I installed PC on my 2013 6MT and there is a huge difference in throttle response. I've scaled back to using city at +1 because the enhanced response in 1st gear leads to losing traction on the rear tires more often then I'd like.
    Overall, I really like the change in acceleration. Shifting into 2nd and 3rd the truck doesn't bog down as much at low RPMs. I've only burned one tank of gas on it, but my MPGs went up by 1.8 (from 16.7 to 18.5) from the last tank with exactly the same type of driving because I no longer feel I need to burn out RPMs in 1st, 2nd, and 3rd, to avoid bogging down after a shift.
    With that said, I'm not a fan of how it drives in 1st when e.g. in a parking lot, the throttle can feel "goosey" kind of like starting in 4lo on flat ground. I'm going to wait and see if I get used to it, and if not I'll probably return the PC. I love driving in gears 2-6 now, just not a fan of how much more touchy the gas pedal is when in 1st gear.
  7. Jul 14, 2021 at 5:37 PM
    #127
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2nd Gen? Yes that I don't know.
    You kinda made my point (touchy the gas pedal is), but I have no problem with you liking it.
    I just meant PC adds no power. Pointless to me.
  8. Jul 14, 2021 at 7:28 PM
    #128
    anthemAnathema
    No one has ever claimed it adds power, just the response of the throttle to pressure on the pedal which, as far as I'm concerned, is a very noticeable difference. So noticeable that I may return the product because it makes too much of a change.
    As someone mentioned in another thread, it seems like most of those who criticize PC as useless are the ones who've never owned or tested one, YMMV.
    Pablo8[QUOTED] likes this.
