Pedal commander
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pinktaco808, May 3, 2021.
  1. May 4, 2021 at 4:20 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
  2. May 4, 2021 at 6:31 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Then must be how you drive. I remember that time I had my Fj . My wife used it for a week when I had it back, it felt preppy . Wifey likes to mush on the pedal off the line .
    Junkhead likes this.
  3. May 5, 2021 at 5:43 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Idk, i drive the tacoma like i drove my 2001 tundra. Believe it or not, the taco runs the same rpm at the same speeds going up hills on the roads here. Really no difference. Rode in my buddies 2019 trd awhile back, it seemed to be downshifting a couple times over the same hilly roads to maintain the same speeds. I'm still thinking there are performance differences between trucks that some run better than others.
    Junkhead and bulalo[QUOTED] like this.
  4. May 5, 2021 at 6:21 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    There you go, you just explained it yourself. 2020-21 drives better with than 2016-19 d/ t updated ecu’s as what some 2020+ owners here reported although it’s performance still doesn’t compare to tacos with kdmax6.0 premium tune.
  5. May 5, 2021 at 8:19 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    Does this mean it burns more gas or will I get better mpg or gonna be the same?
  6. May 5, 2021 at 9:20 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Definitely you won’t get better MPGs, maybe same or worse, depending how you drive.
  7. May 5, 2021 at 9:27 AM
    RMTS Taco
    RMTS Taco New Member
    The Toyota Dealer clued me in on the iDrive. Does the same thing for the most part but in a clean and tiny form. I like the Auto mode the best. It does just give it the faster response when pulling out in to traffic Etc. https://idrive-usa.com/collections/toyota
    pinktaco808[OP] likes this.
  8. May 5, 2021 at 9:47 AM
    pinktaco808
    Any difference from sprint booster?
  9. May 5, 2021 at 10:25 AM
    zoo truck
    None
    Not sure what you mean, but both my 2020 and buddies 2019 have had the latest ecu update from toyota, but they definitely have performance differences between them. I have no clue about your kdmax6.0 tune how that compares. The way everything works now is fine with me.
  10. May 5, 2021 at 10:54 AM
    RMTS Taco
    Not sure. A am sure they all do about the same thing. I just know it works for me. Also has an ECO mode which works good when off road in the loose stuff to help keep me from digging in the sand by slowing down the throttle response a bit.
  11. May 6, 2021 at 11:35 AM
    pinktaco808
    Is the sprint booster and the ect the same thing or should I just save my money?
  12. May 6, 2021 at 1:23 PM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    NO not at all. The Sprint Throttle Booster provides more "juice" to the electrical signal that operates the butterfly in the throttle. It makes it react quicker, depending on how you set the setting on the Sprint controller. I have one, and it is insanely great! There are two sets of settings; eco and sport, and each has 9 different settings. Sport believe it or not, is just TOO quick for me! I have mine set on Eco9 or green9. That gives me quick response, but not so much that I screech tires just backing out of the driveway, which is what happens when one uses the Sport mode! The ECT button basically just leaves the trans in each gear a little longer, resulting in higher rpms before they shift, which of course, will result in lower gas mileage. But hey, it is all in what you want!
  13. May 6, 2021 at 2:33 PM
    RMTS Taco
    I agree! The iDrive Calls it "Custom User Settings" and on level 9 (The Highest) It is too much to enjoy driving on a daily basis but it is fun when you want it.
  14. May 6, 2021 at 2:42 PM
    pinktaco808
    Different stuff
