Pedal commander
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toolbox, Jun 16, 2025 at 10:01 AM.
  1. Jun 20, 2025 at 8:52 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Seems like your wife was the problem. But getting rid of the pedal commander was likely the cheaper solution.
    BattleKat, DavesSR5 and bkhlrTaco's like this.
  2. Jun 20, 2025 at 8:57 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    I just drive around in ECT power mode (automatic lol) and throttle feels good most of the time, I can easily pull away from traffic at red lights with very little throttle pressure most of the time...
    But as an old hot rodder, I do plan on getting an OTT tune one day...
  3. Jun 20, 2025 at 8:59 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    On a very loose T.W. observation, I've come to find the majority of people who tell you the pedal commander is junk have never used one.
    Their statements are null and void.
  4. Jun 20, 2025 at 9:25 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Some of us took others experiences skipped the place holder and just opted for the better option.
    Chew and bkhlrTaco's[QUOTED] like this.
  5. Jun 20, 2025 at 9:28 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I just push that ECT button when I need a little fake power.
  6. Jun 20, 2025 at 10:59 AM
    DavesSR5
    Dave
    Care to explain??
    Although it does not increase engine power at any given RPM per say, it does raise the shift points at lower throttle inputs keeping the engine at a higher RPM longer and changes the throttle response to a point.. If you follow the dyno curve, the higher the RPM, the more power the engine makes, therefor if you are staying at higher RPMs, you have more power...I feel the effects more at lower speeds <40ish mph and less at higher speeds >80ish mph...
  7. Jun 20, 2025 at 11:50 AM
    Buck Henry
    Sure, I'll explain. You can basically do the same thing with your fucking big toe.
