Pedal position sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Joserdog, Jul 8, 2020.
  1. Jul 8, 2020 at 12:45 PM
    Joserdog
    Joserdog [OP] Member
    Jose
    San Jose
    2003 Tacoma TRD
    3" lift
    Does anyone know where I can buy a pedal position sensor for 2003 Tacoma 3.4L 4x4 auto tranny crew cab without having to buy the whole throttle body at the dealer ?
  2. Jul 8, 2020 at 1:03 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    That is the weird one that only comes with the Throttle Body.
    Just what is wrong in your case ??
    Not having to ever solve that problem I don`t know how much work it would be to swap to a different year and if it would mean a ECM to match .
    Look for a used one throttle body.
    It is called Throttle Position Sensor or TPS
  3. Jul 8, 2020 at 1:11 PM
    Joserdog
    Jose
    San Jose
    2003 Tacoma TRD
    3" lift
    The check engine code P-2138 is coming up. I will hit the gas and it will not respond it’s say it’s either the TPS or the sensor on the other that pulls the fly by wire to open up the throttle. And if I can’t find the sensor alone I may have to buy the whole throttle body
  4. Jul 8, 2020 at 1:16 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I think @mechanicjon knows the part number for the sensor specifically
  5. Jul 8, 2020 at 1:35 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Last I heard this was not sorted out but I did not need to solve this so really was not paying real close attention
  6. Jul 8, 2020 at 2:22 PM
    eon_blue
    Azusa, CA
    There was some talk in the other big 1st gen thread about how someone was able to find a sensor overseas that worked for the later year 1st gen TPS, rather than having to buy the whole throttle body.
  7. Jul 8, 2020 at 4:28 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I have never been able to locate a pedal postion sensor. (The sensor closest to the actual throttle cable) Only the Thottle position sensor. The TPS is available on partsgeek.
    I have the part number at home. I'm camping until Saturday.
  8. Jul 8, 2020 at 4:33 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    It is possible to use a 2nd gen gas pedal that has the pedal position sensor built in to it. That would eliminate the throttle cable and require some wiring to tie it into original plug at throttle body.
    I've researched it as a last resort type of deal. The resistance readings are similar. Of course this is all in theory and on paper. It hasn't ever been done that I know of.
    Wyoming09 likes this.
  9. Jul 8, 2020 at 4:38 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Also called an accelerator position sensor
