Peeling off Stickers
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoman101, May 9, 2010.
  1. May 9, 2010 at 6:33 AM
    tacoman101
    tacoman101 [OP] Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    This is probably a pretty stupid question, put can I razor blade off a sticker in my back glass even if the glass is tinted. I didn't know if the tint would get scratched or peeled because of the blade. Thanks alot
  2. May 9, 2010 at 6:35 AM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    yeah because the tint is on the inside of the window.
  3. May 9, 2010 at 6:37 AM
    tacovic
    tacovic Well-Known Member
    MN/WI
    00 4x4 TRD
    stock for now
    is the sticker on the inside or the outside glass? if its on the inside then NO. if its on the outside then yes. and to answer your question, yes you will scratch the tint if the sticker is on the inside.
  4. May 9, 2010 at 6:38 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :taco:
  5. May 9, 2010 at 7:22 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    If the sticker is stuck to the (aftermarket) tint, good luck getting it off. Over time the colors in the stickers fade into the tint. My old car had a window cling permanently stuck to the tint. Then I used a razor blade and effed the whole window cuz the dealer told me it was factory tint.
  6. May 9, 2010 at 9:39 AM
    tacoman101
    scott
    vermont
    K thanks guys....the sticker is on the outside of the factory tint, so I should be safe
  7. May 9, 2010 at 9:46 AM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    Factory tint is between layers of glass. Can't scratch it without breaking the glass first, but then scratched tint is the least of your worries. Scrape away.
  8. May 9, 2010 at 10:45 AM
    Yamasaki
    Yamasaki Yamaha + Kawasaki!
    Denver, CO
    2003 Tacoma Limited TRD 4x4
    I did not want to start a new thread, but this is a similar topic so...
    The 'Limited' decals on the pillar by the extended cab on my truck have the finish flaked off in a few places. I ordered some new ones for $15 or so and I am wondering how I get off the old ones... Should I apply heat and then use fishing wire?
    Any other suggestions?
  9. May 9, 2010 at 2:23 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    yep you got er. put a hair dryer to it about a minute is long enough then start from an edge of the badge with your fishing line and kind of saw back and forth. ya may need to reheat as you work the badge off. also ya may need to use a new piece of line, itll get pretty gunked up.
