peiceing a lift together????
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowhunter11199, Apr 23, 2011.
  1. Apr 23, 2011 at 4:50 PM
    bowhunter11199
    bowhunter11199 [OP] Well-Known Member
    Edit:
    Changed mind, please check out post # 14
    oppions apperiated
  2. Apr 23, 2011 at 4:53 PM
    toytaco1
    toytaco1 Well-Known Member
    jed
    moreno valley
    05 supercharged trd off road
    trd supercharger, TRD intake, magna flow exhaust, JBA headers, walker evans front, fox rear, leaf pack, drilled slotted rotors, All Pro Front Bumper, Warn 8000 Winch
    Yes they do
  3. Apr 23, 2011 at 4:57 PM
    bowhunter11199
    its says they arent recomended. is that just bs or does something F up when you put them together?
  4. Apr 23, 2011 at 5:00 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I would use the 881's unless your running a big ole bumper. The 882 are designed to carry more weight.
  5. Apr 23, 2011 at 5:19 PM
    bowhunter11199
  6. Apr 23, 2011 at 5:55 PM
    bowhunter11199
  7. Apr 23, 2011 at 6:46 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Ya they do work with the stock coil overs but if you have the extra money get some 881's it will improve the ride substantially. I planning on changing my fronts to 5100's and ebaich or 881's.
  8. Apr 23, 2011 at 7:03 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    So you want to mount a prostitute on the front of your truck?
    Think you mean winch.
  9. Apr 23, 2011 at 8:48 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    A prostitute would be pretty unique+ if you get into an accident its cheaper to replace than a bumper.
  10. Apr 23, 2011 at 9:48 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    yes, 882s (and 881s, and 880s) will fit on 5100s. I'd run an OME spring with an OME shock though.
  11. Apr 24, 2011 at 7:25 PM
    bowhunter11199
    ya man (after i sell my truck and buy another) im going all out(coilovers/struts/a arms/diff drop/new leaf pack).....but not all at once:D
    but were can you find those ebaich 881's for 1st gen?????:confused: i looked hard for them
  12. Apr 24, 2011 at 7:26 PM
    bowhunter11199
    haha that would be pretty crazy but ya thats what i meant.....winch
  13. Apr 24, 2011 at 10:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  14. Apr 25, 2011 at 8:54 PM
    bowhunter11199
    looks good man thanks...
    so how does his sound:
    ebaich 881's with 5100's (no 882 cuz i going to have prerunner bumper and smallll winch or should i go with 882 so i dont have sag?)
    ome daker leaf pack with blillies in the back
    and diff drop
    after that( with in a month of buying above things)
    10mm "lift enhancer basically 1/2"-5/8" more lift
    and light racing UCA's (spendy:eek:)
    this is what im thinking about for bumper(but this one doesnt have winch)
  15. Apr 25, 2011 at 9:12 PM
    bowhunter11199
  16. Apr 26, 2011 at 2:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    why get the "enhancer" lift? seriously, the 3'' lift and 33'' tires is more then enough i think..
  17. Apr 27, 2011 at 7:38 PM
    bowhunter11199
    the 5100's only give me 2.5" in the front
  18. Apr 27, 2011 at 7:51 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    So why not go ahead and get eibach coils so that you can have 3" with tehm set at 0? then after they break in real good and start to sag you just bump the billies up to 1.5 setting, thats what i plan on doing once i get my bumper and winch. Just my .02
  19. Apr 27, 2011 at 8:08 PM
    bowhunter11199
    the eibach will sag????
  20. Apr 27, 2011 at 8:17 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Well with added weight and some time any coil is going to start sagging, but mine havent yet and I have had them for about 6 months so far, but ill be adding around 160 pounds to the front w/ bumper and winch and by then they might be sagging a bit, and if I set it to 1.5 and teh cv angles are bad ill just drop them back down to 0 till down the road
