Pelfreybilt Bumper Fog Light Install
Discussion in 'Lighting' started by ReadyForAdventure, May 22, 2014.
  1. May 22, 2014 at 6:06 PM
    ReadyForAdventure
    ReadyForAdventure [OP] Well-Known Member
    HTX -> Milwaukee, WI
    '12 DCLB Super White TRD Sport 4x4
    I'm trying to install a pair of Rigid D2s in the fog light holes and I can't seem to figure out how to position them. Could some one tell me how to do it?
    Thanks!
  2. May 22, 2014 at 6:14 PM
    Large
    Large Red
    I had to bend down the tabs to fit duallies there, I don't think there is another way
  3. May 22, 2014 at 6:17 PM
    ReadyForAdventure
    Oh ok. Did you use the mounting bracket that came with the lights and place the carriage bolt through the tab?
  4. May 22, 2014 at 6:23 PM
    Large
    Large Red
    Yes, put the bracket on the light, bend down the tab and use the carriage bolt to hold the bracket (with the light attached) to the tab on the bumper.
  5. May 22, 2014 at 6:31 PM
    ReadyForAdventure
    Ok sounds simple enough. I'll find a way to confuse myself. Haha. How much should I bend it down? I know you can adjust the height of the light on the bolt but I don't want to bend it too much. Also should I just pull on it with a couple pliers or bang on it with a deadblow?
  6. May 22, 2014 at 6:35 PM
    Large
    Large Red
    I just used my fingers, you'll see when you try to put the bumper on lol. Just bend it down to where the top of the dually is flush with the top of the bumper, maybe 1/2" lower. You can bend it back up when the bumper is on the truck also which is what I did. I just eye balled it really until I got them where I liked them.
  7. May 22, 2014 at 6:36 PM
    ReadyForAdventure
    I'll give it a shot this weekend. Thanks for all the help! You've helped a lot.
  8. May 22, 2014 at 6:37 PM
    Large
    Large Red
    No problem, if you need some pics I can go snap a couple
  9. May 22, 2014 at 6:38 PM
    ReadyForAdventure
    That would be a huge help! Thanks again.
  10. May 22, 2014 at 6:43 PM
    Large
    Large Red
    Gimme a few minutes
  11. May 22, 2014 at 8:18 PM
    Large
    Large Red
    Here you go:
    You can see it's bent at least 30 degrees. Sorry but it's the only pic that came out good.
  12. May 22, 2014 at 8:21 PM
    ReadyForAdventure
    That's perfect. Thanks so much!
