Pelfreybilt Rock Sliders Install? HELP!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PandaTRDPro, Jun 19, 2017.
  1. Jun 19, 2017 at 9:45 PM
    PandaTRDPro
    PandaTRDPro [OP] Member
    2017 Tacoma TRD Pro
    Dual ARB Air Compressor, Pelfreybilt Steel Skid Plates Front to Back, Pelfreybilt Top Plated Rock Sliders, RCI Rear Steel Bumper w/ Rigid SQ Back up Lights. Pending: RCI Aluminum Bed Rack sPOD 6 switch Tepui RTT
    I just bought these rock sliders for my 2017 TRD Pro and the directions they came with are very vague and not helpful at all...Has anyone installed these on a 3rd gen Tacoma?? Please let me know ASAP!!!
  2. Jun 19, 2017 at 9:55 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
  3. Jun 19, 2017 at 9:57 PM
    tcjacado
    tcjacado Well-Known Member
    Bolt on or weld on? Bolt ons you need to notch the pinch weld on the bottom under the door and drill holes in the frame. Weld on, notch pinch weld and weld slider to frame.
  4. Jun 19, 2017 at 10:03 PM
    bamfupinya
    bamfupinya Well-Known Member
    17 Taco TRD OR DCSB
    did you try to call them for assistance?
  5. Jun 19, 2017 at 10:05 PM
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    If I remember you'll have to move some line thats in the way around the slider or something, don't quote me on it.
    @Socalduckslayer @Pelfreybilt
    desertjunkie760 likes this.
  6. Jun 19, 2017 at 10:11 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Very descriptive...
    Their directions are very confusing until you realize the parts/lingo they are describing. I did mine but never done a 3rd gen.
    JoeCOVA likes this.
  7. Jun 19, 2017 at 10:11 PM
    PandaTRDPro
    2017 Tacoma TRD Pro
    They are weld on. I have not called them yet as they were closed when i was trying to install them this evening. I really wish they would make an instrucutonal video bc their instructions are not helpful at all!
  8. Jun 19, 2017 at 10:11 PM
    desertjunkie760
    Shane
    Check My Sig.
    Where are you located?
  9. Jun 19, 2017 at 10:12 PM
    desertjunkie760
    Shane
    Check My Sig.
    Are you going to do the welds? I would think they would be easier to install.
  10. Jun 19, 2017 at 10:14 PM
    PandaTRDPro
    2017 Tacoma TRD Pro
    Sorry idk why i said they were weld on ha they are bolt on! I am located in Santa Barbara, CA.
    tcjacado and Pirhett like this.
  11. Jun 19, 2017 at 10:16 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    can you wait till morning?
  12. Jun 19, 2017 at 10:17 PM
    desertjunkie760
    Shane
    Check My Sig.
    Oh damn, too far for me to help too much. Haha.
  13. Jun 19, 2017 at 10:18 PM
    jonmartin
    jonmartin Well-Known Member
    Jonathan
    818
    CEMENT 17' TRD PRO 6MT
    TRD CAI Intake, Audison Bit ONE HD,Audison AV 5.1k HD Amp, Focal/Voce Speakers , Morimoto HID,Bakflip MX4..More to come
    How long did you have to wait for them? is it really 8+ weeks or whatever it says on their site?
  14. Jun 19, 2017 at 10:18 PM
    tcjacado
    What are you having difficulty with.... placement? Or something else?
  15. Jun 19, 2017 at 10:19 PM
    PandaTRDPro
    2017 Tacoma TRD Pro
    It took 3 and a half months!!
  16. Jun 19, 2017 at 10:20 PM
    PandaTRDPro
    2017 Tacoma TRD Pro
    Im having trouble with placement and where everything is supposed to line up... Do you happen to have any pics of install or anyone else perhaps??
  17. Jun 19, 2017 at 10:22 PM
    tcjacado
    2016-2017 TACOMA 79″ BOLT ON SLIDERS INSTALLATION INSTRUCTIONS
    Sliders should be prepped and painted or powder coated prior to installation for best results. Mask mounting areas from paint or powder. Please Note: Certain model years may have a frame rivet or two toward the rear that needs to be ground flush prior to installation. Certain 2016+ models will need to drill (2) holes per side for mounting, do to variations from Toyota Factories. The driver’s side of the frame has 2 brake line clips that must be pulled away from the frame to allow for the large front nut plate to be inserted into the forward boxed area of the frame. The rear brake line clip will be reinstalled using the supplied 1” brake line spacer. This will be bolted to the frame using the hole that is was clipped into and the supplied ¼” screw and washer.
    There are 6 bolts per side. The front two bolts go thru the frame to the large nut plate (2 nuts) One per side goes to the rectangular nut plate that fits inside the front cross member. 2 | Page The other 3 nut plates make up the remainder. The rear mounting points will use the C channel reinforcement brackets. The large nut plates for the front are side specific as well. The rear uses the small c channel plates. The factory flange bolt that is on the bottom of the frame will be replaced with the supplied flange bolt that is longer and higher strength.
  18. Jun 19, 2017 at 10:24 PM
    PandaTRDPro
    2017 Tacoma TRD Pro
  19. Jun 19, 2017 at 10:33 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    There are only so many ways that the sliders will fit on. The instructions should be pretty damn clear with the sliders laying on the ground next to the vehicle. If you can't figure it out from there take it to a shop. To be perfectly honest, it sounds like you're in over your head. Take a step back and seriously reconsider if you're capable of installing those. Good luck with whichever route you choose.
  20. Jun 19, 2017 at 10:35 PM
    tcjacado
