Pelican 1660 hard case
Discussion in 'Buy / Sell / Trade - Other' started by Wallz, Jul 15, 2017.
  1. Jul 15, 2017 at 6:09 AM
    Wallz
    Wallz [OP] Well-Known Member
    OR DCSB Taco
    SOLD
    Up for sale is a brand new Pelican 1660 hard case. It's black in color, lockable, waterproof, & has the foam inside so you can shape it to your specific needs. I had plans for this but decided to go another route however it would be a perfect camp box for someone.
    Here's Pelicans description:
    This is the #1660 CASE. It comes with Pelican’s unique Pick ‘N Pluck foam. This foam is pre-cut which allows you to customize the interior by half inch cubes. Trace out the item you want in the case and simply pluck the foam out by hand, no tool required. You can customize your case in less than 15 minutes.
    Unbreakable, watertight, airtight, dustproof, chemical resistant and corrosion proof. These are some of the features of this Pelican Protector Case that offers total protection for your equipment. It is made of Ultra High Impact structural copolymer that makes it strong and durable. Its exclusive 1/4" (6.4 mm) neoprene o-ring and ABS ‘easy-to-open’ latches seal perfectly and includes an automatic purge valve for quick equalization after changes in atmospheric pressure. It is equipped with heavy duty wheels, a retractable extension handle and multiple fold down carrying handles. Your equipment can fit into the high density foam (included) or padded dividers (see the 1660NF below) for total subjection and protection against impact, vibration or shock.
    TEMPERATURE RATING:
    MINIMUM -10° F (-23° C) MAXIMUM +210° F (+99° C)
    DIMENSIONS:
    INSIDE: 28.20" x 19.66" x 17.63" (71.6 cm x 49.9 cm x 44.8 cm)
    OUTSIDE: 31.59" x 22.99" x 19.48" (80.2 cm x 58.4 cm x 49.5 cm)
    LID DEPTH: 3.50" (8.9 cm) CASE DEPTH: 14.14" (35.9 cm)
    INTERIOR CUBIC VOLUME: 5.66 cubic feet (160.17 cubic decimeter)
    BUOYANCY: Floats in salt water with 350.1 lbs (158.8 kg) load
    WEIGHT of Case:
    With Foam: 42.16 LBS
    Without Foam: 34.16 LBS
    NSN : 6760-01-500-9632
    Note - This case has internal wheel and/or handle wells that will reduce usable area. Please review for each application.
    Asking Price: sold
  2. Jul 16, 2017 at 8:36 AM
    Wallz
    OR DCSB Taco
    Bump
  3. Jul 18, 2017 at 2:10 PM
    Wallz
    OR DCSB Taco
    Bump
  4. Jul 20, 2017 at 5:29 PM
    Wallz
    OR DCSB Taco
    Bump
  5. Jul 22, 2017 at 3:05 AM
    Wallz
    OR DCSB Taco
    Bump
  6. Jul 23, 2017 at 10:04 AM
    Wallz
    OR DCSB Taco
    Bump
  7. Jul 26, 2017 at 3:28 PM
    Wallz
    OR DCSB Taco
    Bump
  8. Jul 26, 2017 at 5:47 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Nice case GLWS
  9. Jul 29, 2017 at 12:19 PM
    Wallz
    OR DCSB Taco
    Thanks
  10. Jul 30, 2017 at 9:57 AM
    Wallz
    OR DCSB Taco
  11. Jul 31, 2017 at 4:00 PM
    Wallz
    OR DCSB Taco
  12. Aug 1, 2017 at 2:32 PM
    Wallz
    OR DCSB Taco
    Bump
  13. Aug 2, 2017 at 1:19 PM
    Wallz
    OR DCSB Taco
    Bump
  14. Aug 5, 2017 at 3:35 AM
    Wallz
    OR DCSB Taco
    Bump
  15. Aug 5, 2017 at 3:41 AM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    first person Ive seen from Sanford. I was in the area for about 13 years
  16. Aug 5, 2017 at 9:58 AM
    Wallz
    OR DCSB Taco
    Nice, I look forward to coming back to WA someday.
    Skootter14 likes this.
  17. Aug 8, 2017 at 3:12 PM
    Wallz
    OR DCSB Taco
    Bump
  18. Aug 12, 2017 at 7:32 PM
    Wallz
    OR DCSB Taco
  19. Aug 14, 2017 at 6:33 PM
    Wallz
    OR DCSB Taco
  20. Aug 19, 2017 at 11:41 AM
    Wallz
    OR DCSB Taco
