Pelican 1750 rifle case, tan, ready to mount.
Discussion in 'Buy / Sell / Trade - Other' started by MisterKitchen, Dec 23, 2019.
  1. Dec 23, 2019 at 8:54 PM
    MisterKitchen
    MisterKitchen [OP] Well-Known Member
    FABIAN
    2018 CONCRETE TACOMA TRD OFF ROAD
    Too many
    SOLD!
    I have a 1750 I no longer need. Mounted to prinsu type rack for about 8 months. Mounted via 1/4x20 carriage bolts.
    I can include the foam. It’s cut for an AR, 870 and Pistol. Plus some mag slots. I used it for tools mostly on the truck.
    $90
    Located in El Paso.
  2. Dec 24, 2019 at 6:03 AM
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Wish you were closer!
    MisterKitchen[OP] likes this.
  3. Feb 10, 2020 at 1:57 PM
    TacoSauce23661
    TacoSauce23661 Active Member
    2020 Tacoma TRD OffRoad Long bed Crew Cab
    Icon stage 10 with extra leaf config Leitner ACS forged with two small gear pods, one large gear pod, two fuel rotopax, two water rotopax, caliraised molle front bed wall rack, highlift mount, onboard shower, cutting board tailgate face, molle rack above rear passenger seating between handles, Uptop overland Alpha cab rack, FSR evolution RTT, Method 703 wheels, Nito Ridge Grappler tires, Outerlimit Supply first aid kit and mount, fire extinguisher, solar panels and solar generator, 23Zero Peregrin 270awning with walls, window visors, Lock’er Down steel console safe with combination lock.. more coming soon.
    How did you mount it to the roof rack? With the bolts? I’m doing something similar and have the exact same case. Not a huge fan of drilling through it and would prefer an option which doesn’t make a hole in the pelican case if at all possible.
  4. Feb 10, 2020 at 2:08 PM
    MisterKitchen
    FABIAN
    Too many
    Unfortunately, yes I drilled 4 holes in the case. I didn’t mind though. I sealed it with some rubber fender washers and called it good. They’re staying on the truck as storage so it didn’t really bother me.
