Pellet grill on bed outlet?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Enfield1, Sep 8, 2018.
  1. Sep 8, 2018 at 4:28 PM
    Enfield1
    Enfield1 [OP] Well-Known Member
    Brad
    Bryan, Tx
    '18 White DCSB OR 4wd auto
    I'm curious as to whether I can run my RecTec trailblazer with my bed outlet. RecTec says it uses 350w for the first 5min, then 100w continuous.
    Is that enough info to go on? I see the outlet is rated for 400w, just wanted to be sure.
  2. Sep 8, 2018 at 4:51 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    It’s 400W when the truck is running and 100W when in drive from what I’ve read.
  3. Sep 8, 2018 at 4:58 PM
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
    Just have to run your truck for the first 5 mins
  4. Sep 9, 2018 at 6:36 PM
    Enfield1
    Brad
    Bryan, Tx
    I've been doing some more reading and it looks like our inverters don't provide clean enough power for this. It could burn up the auger or ignitor rod.
  5. Sep 9, 2018 at 6:48 PM
    svdude
    svdude Well-Known Member
    jonathan
    Maybe put in a heavy duty inverter and thicker wiring? I've been contemplating doing that to mine.
  6. Sep 9, 2018 at 7:08 PM
    Enfield1
    Brad
    Bryan, Tx
    I may end up doing that. I can just as easily pack a charcoal or gas grill though.
  7. Sep 9, 2018 at 7:16 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The bed outlet does not work at all without the engine running. It’s 400W when idling, and 100W when driving around.
    TRD OR BUST! likes this.
  8. Sep 9, 2018 at 7:28 PM
    Grossomotto
    2017 4WDV6LB6MT
  9. Sep 10, 2018 at 7:11 AM
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
    False, I've had 100W with the ignition on and the truck not running. Is it good for the battery though, probably not.
    Rustytaco71 likes this.
  10. Sep 10, 2018 at 7:24 AM
    Stocklocker
    17TRDORDCSBAT
    Truth of life: There is always a bigger nerd.
    You are correct, but c’mon, sitting with your ignition on and all of the vehicle systems energized, with the engine not running, is kinda for wankers.
  11. Sep 10, 2018 at 7:28 AM
    SContiVT
    Central Vermont
    :fistbump: It's cool, only reason I knew this, before reading it in other threads, was because I needed to "fast charge" my phone to get some quick battery life, but I didn't have a DC fast charger...lol I only did it for about 20 minutes.
    Stocklocker[QUOTED] likes this.
  12. Sep 10, 2018 at 7:36 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    With all the discussion above, how about a Webber Charcoal Grill with some wood chips..... sounds much easier.
    Juforrest, pinochle and ScottyR like this.
  13. Sep 10, 2018 at 7:57 AM
    phsycle
    phsycle Well-Known Member
    CA
    And tastes better
    Just smoked some salmon on the Weber kettle yesterday. Pork shoulder the week before. So good.
    pmstoy10 and pinochle like this.
  14. Sep 10, 2018 at 7:57 AM
    Enfield1
    Brad
    Bryan, Tx
    Yeah, that's the conclusion I've come to.
  15. Sep 10, 2018 at 8:10 AM
    Woodrow F Call
    Colorful Colorado
    At home I use an electric smoker.... I call it lazy Q as it's so easy to hold temp. It makes some beautiful and tasty meats. All you need is smoke and the ability to hold temps.... I'm sure you can do that with a pellet grill.
    I also use a Weber Kettle for grilling..... and some smoking. It can hold temps pretty well, but not as well as that electric smoker.
    Anyway, I only said the Weber because you can do quite a bit with it and the fuel is readily available most anywhere. I just don't see you getting the power needed from the outlet on the truck. I'm not biased against any grill as you can make awesome food on anything provided it'll hold temps for you.
    I'll also plug this fella since we are talking a little about cooking. Good stuff, tons of tasty recipes, and the boy can cook!
    http://howtobbqright.com/
    Hobbs and rlx02 like this.
  16. Sep 10, 2018 at 8:11 AM
    Woodrow F Call
    Colorful Colorado
    And oops..... I put to many b's in Weber.
  17. Sep 10, 2018 at 8:15 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I have a traeger, weber smokey mountain and a regular weber grill. They all have their place but I'm selling both smokers for a full electric for the exact reasons you describe. Easy to hold temp and easy to start. I still will keep my big weber grill if I really want to "true" smoke some meats.
  18. Sep 10, 2018 at 8:26 AM
    Woodrow F Call
    Colorful Colorado
    They are stupid easy to operate. If you get a Masterbuilt, they also have good customer support in case you need to replace parts. Mine will hold 275F and you can touch the sides while running. It holds in heat well.
    I still want to get a Primo or a Big Green Egg in the future, but that'll be for doing other things. If I want a brisket, pork shoulder, ribs..... it'll probably be done on the electric.
    Make sure you get the 40 and not the 30 if you are getting Masterbuilt. The 30 is just too small. Also, don't trust the Bluetooth on the grill if it comes with. It gets confused when you get out of range. Get a thermo pro alarm or a chef alarm.
    Flash1034 likes this.
  19. Sep 10, 2018 at 8:29 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I was thinking of either the masterbuilt or charbroil. The charbroil is set up for a temp. probe for the meat as well, but I'm still concerned about the build quality.
  20. Sep 10, 2018 at 8:36 AM
    Enfield1
    Brad
    Bryan, Tx
    My RecTec is great. Internal probe, plus two meat probes and wifi control. Easily hits 650F for searing, plus I use grates to help.
    GoGoGadget likes this.
