Pen 15/salary/build cost measuring thread. With lots of BS
Discussion in 'Solid Axle Suspension' started by bayareataco, Apr 13, 2016.
  1. Apr 13, 2016 at 11:11 AM
    bayareataco
    bayareataco [OP] Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Hey guys, I am trying to figure out for sure what my shift patterns should be to
    Make sure I'm not missing any gears.
    My setup is as follows,
    Inchworm crawlbox with a Tacoma J shift rear case.
    RAD triple stick shifter setup.
    - that means my shifters from Left to Right are:
    Left stick- rear case left rail
    Center stick- inchworm crawl box
    Right stick- rear case right rail.
    If someone could lay out the shift patterns for me from Left to Right with certainty that would be great thanks!
  2. Apr 13, 2016 at 12:46 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Shift pattern would be from left to right: 2wd/4wd, crawl box, rear case h/l
  3. Apr 13, 2016 at 4:22 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    So you have a dual case set-up? Kind of a vague post... post some pics.
  4. Apr 13, 2016 at 4:33 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Trying to figure mine out as well but am only twin sticks. I have the inchworm prerunner adapter, 2.28 crawl box with 4.7 transfer case. Crawl box has one shifter, Tcase has the twin sticks. From just messing with them in the garage, I am assuming the passenger stick is 2wd/4wd and the middles on the other shifters are neutral. Is foward or back high or low? Thanks.
  5. Apr 13, 2016 at 4:48 PM
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    I don't know that's what I am Trying to figure out as well, that's the same setup as me. My shifters are just a forward shift twin stick. The rear case shifters are in line with the front case shifter.
    Uhh yes exactly what my post says inchworm crawl box with a j shift case behind that. What is vague about it? I'm listing what shifters correspond to which case/rail and want to know the pattern on each shifter. H-N-L etc.
  6. Apr 13, 2016 at 4:48 PM
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Thank you. Only saw the picture at first not the writing. I think I asked you already but you didn't seem to sure that time haha, thanks again
  7. Apr 13, 2016 at 4:50 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Actually be just the opposite the tcase hi-lo will be on the left side l, crawl box in middle, 2/4wd on right.
  8. Apr 13, 2016 at 4:53 PM
    malburg114
    Las Vegas, NV
    AKTACOTRUCK likes this.
  9. Apr 13, 2016 at 4:56 PM
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Well, which is it?
  10. Apr 13, 2016 at 4:57 PM
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Sweet, cut that console with a butter knife? :luvya:
  11. Apr 13, 2016 at 4:59 PM
    PSU Taco85
    optional
    The high low shifter is on the driver side. Easy to check by cycling the shifters and turning the input shaft as well.
  12. Apr 13, 2016 at 4:59 PM
    malburg114
    Las Vegas, NV
    Air dremel, butter knife.. all the same thing haha. Cleaned it up a little so it doesnt look so janky now and made a plate to go over the top of it :luvya:
  13. Apr 13, 2016 at 5:02 PM
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Thanks, yeah we were checking with the flanges but wanted an answer to know if we had it right.
    Haha well I'm sure it looks good now!
    PSU Taco85[QUOTED] likes this.
  14. Apr 13, 2016 at 7:23 PM
    Ritchie
    Uhhh, uhh, OK Beavis, next time say dual cases. Crawl boxes are equipped with a J shift.
    I suggest crawling under your truck to figure out the linkage configuration... uhh.
  15. Apr 13, 2016 at 7:28 PM
    Ritchie
    Malburg,
    Post a pic. Typically, the twin stick is as follows:
    Left stick is for going from 4hi to 4lo with a detent in the middle for neutral.
    Right stick is 2hi to 4hi.
    As for the 2.28 case, can't answer that as I don't have one.
    Hope this helps.
  16. Apr 13, 2016 at 7:40 PM
    PSU Taco85
    optional
    For the crawl box it only contains one shift rail and that's the hi/neutral/low shift rail. There's a piece of keystock you weld onto the shift rail to keep the shifter in place since you don't use the 4wd shift rail anymore
    Gear Head likes this.
  17. Apr 13, 2016 at 7:48 PM
    Ritchie
    weird... mine has two shift rails. Mine is a gear driven case which may make a difference, dunno.
  18. Apr 13, 2016 at 7:52 PM
    PSU Taco85
    optional
  19. Apr 13, 2016 at 8:13 PM
    malburg114
    Las Vegas, NV
    So left stick is 4hi/neutral/4 low and right stick is 2hi/2low? That makes more sense now. To put the truck in 4low, would it be 4low, 2low? And vice versa for 4high?
  20. Apr 13, 2016 at 8:17 PM
    PSU Taco85
    optional
    The left (drivers side) is for the hi/low range and the right (passenger) stick is for 2wd/4wd. The benefit to the twin stick is that you can access 2wd low which is normally locked out with an interlock pill in the case. If you one step further and get yourself a dana 300 twin stick you can do a front dig too :D
    Ritchie and bayareataco[OP] like this.
