Pending engine codes, should I be worried?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZMan2k2, Feb 19, 2012.
  1. Feb 19, 2012 at 11:31 AM
    ZMan2k2
    ZMan2k2 [OP] Well-Known Member
    Richard
    Calgary, Canada
    06 DC LB SR5
    So upon reading through a few threads, I decided to go check out my ScanGuage, and see if I had any codes in my truck. Good news, no codes. But I went to check the pending codes list, and as the truck is running, the counter on codes just keeps going up. It also goes so much, that I can't check the codes, to see what they are, except for one. P3070. I checked the FAQ here, and it doesn't list that code for anything, so I'm wondering, am I okay? When I shut off the truck, the codes are gone, but when I start up again, the counter starts at 0 again.
  2. Feb 19, 2012 at 11:39 AM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Po307 is miss in cyl #7, but im assuming you have a tacoma which is either a 4 or 6?
    Weird.
    Dont worry about pending codes, toyotas use dual trip detection logic in the ecu so something has to trip twice within a certain cycle to pop a cel.
  3. Feb 19, 2012 at 11:42 AM
    ZMan2k2
    Richard
    Calgary, Canada
    06 DC LB SR5
    Okay, thanks guys.
