Pending First Time Tacoma Owner TX
Discussion in 'New Members' started by Beltal0wda95, Jan 25, 2022.
  1. Jan 25, 2022 at 8:22 AM
    Beltal0wda95
    Beltal0wda95 [OP] Member
    Vincent
    2003 Black Tacoma PreRunner
    Hello everyone! As the title says I'm a pending first time Tacoma owner from Texas! I come from a family of mechanics and car enthusiasts, but pursued a different line of work. I have basic mechanical experience working along side my father and uncles and have always wanted to own my own Tacoma.
    I was lucky enough to stumble upon a 2003 PreRunner Double Cab with 148k! Being that this is my first experience with a Tacoma I am having our family mechanic look over everything today. There is paint oxidation on the hood and roof after sitting outside for years and the bed was well used without a lining so that will need to be worked on as well. First, all mechanical components will be worked on or serviced of course.
    If everything checks out mechanically I will finally be a proud owner of a Tacoma! I greatly look forward to restoring this truck over time. Wish me luck and please list any questions, comments, or concerns! I will post a few photos! Thank you all!
    A quick picture I took while it was raining
  2. Jan 25, 2022 at 8:33 AM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Welcome Vincent :hattip:
    Have them inspect the frame.
    Good luck with your purchase :thumbsup:
  3. Jan 25, 2022 at 8:39 AM
    Beltal0wda95
    Vincent
    Thank you!
    I mistakenly pressed create thread before adding a small picture of the frame, but I specifically asked our mechanic to check the frame for sure!
    BINK05TRD likes this.
  4. Jan 25, 2022 at 8:47 AM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2021 4runner "Luna" 2023 Solar Octane MT "Solaris"
    That's a good looking find bro.. welcome
    BINK05TRD, Beltal0wda95[OP] and Matic like this.
  5. Jan 25, 2022 at 8:51 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Welcome. I'm currently converting my 1 owner 2002 dc, 3rz to 4x4.
  6. Jan 25, 2022 at 9:08 AM
    Beltal0wda95
    Vincent
    Thank you! The guy I'm buying it from is giving me a really good price so I hope there is nothing wrong that I couldn't see!
  7. Jan 25, 2022 at 9:10 AM
    Beltal0wda95
    Vincent
    That looks really clean! How many miles are on it, if you don't mind me asking.
    Matic[QUOTED] likes this.
  8. Jan 25, 2022 at 9:16 AM
    Matic
    Tricky Dick
    Easley, SC
    180xxx or so. Was my 1st new truck purchased in late 2001. Been a really great truck all these years. Despite the paint fading on the roof and hood, it still cleans up really nice.
  9. Jan 25, 2022 at 9:23 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
  10. Jan 25, 2022 at 9:23 AM
    Beltal0wda95
    Vincent
    Wow that's awesome. The owner of the one I'm purchasing it from bought it in 2003 with 10 miles on it. Have you had the paint redone? I know it's not a cheap job if you want it done right.
  11. Jan 25, 2022 at 9:38 AM
    Matic
    Tricky Dick
    Easley, SC
    No I havn't. It's not suoer bad yet. I may get sime estimates on it this summer. Did the guy you are getting it from have all maintenance records? Water pump, lower ball joints, etc? V6 or 3rz? It looks pretty clean. Looks like the guy used the bed for work stuff. That can be cleaned up pretty good. Good luck and hope everything checks out ok.
  12. Jan 25, 2022 at 9:48 AM
    Beltal0wda95
    Vincent
    No, unfortunately he didn't have the maintenance records. Would it be safe to assume that I need all that replaced since I'm unsure if it's been done already? It is a V6 and he mainly used it to move washer/dryers/refrigerators between a few rental properties he owned, which would explain the wear and tear on the bed. I appreciate it! I hope everything works out smoothly!
    Matic likes this.
  13. Jan 25, 2022 at 9:58 AM
    Matic
    Tricky Dick
    Easley, SC
    The lower ball joints were a recall early on. I think you can type the vin # into toyotas website and see if they were done. I think there was a gas filler neck recall as well. Someone may be able to point out the website, I'm not certain which one it is. The other stuff i'm not sure of since it's a v6. Timing chain vs belt. You could ask those questions in the 1st gen section or just search thru it. The search feature in the upper right hand corner works to some degree but can be a bit wonkey sometimes. I can assure you that we have some really great people in the 1st gen section that can answer many of your questions. Cause 1st gen, best gen.
  14. Jan 25, 2022 at 9:59 AM
    Matic
    Tricky Dick
    Easley, SC
  15. Jan 25, 2022 at 10:00 AM
    Matic
    Tricky Dick
    Easley, SC
  16. Jan 25, 2022 at 10:28 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  17. Jan 25, 2022 at 10:40 AM
    Beltal0wda95
    Vincent
    Thank very much for all the resources! I've been checking this site out for a while because I've wanted one for so long. I've always been amazed by all the knowledge that's here! I'll definitely need to check for those recalls!
