PennSilverTaco's HVAC BS MegaThread!
Discussion in 'Garage / Workshop' started by PennSilverTaco, Feb 16, 2021.
  1. Sep 26, 2022 at 9:22 PM
    #261
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  2. Sep 26, 2022 at 9:28 PM
    #262
    6 gearT444E
    Deep South
    Herculiner Hootus
    The portable ones are a nice supplement! I will tell you the first time I learned the "ton" rating of an AC unit I was a little taken back, crude rating from where it's name came from but I guess the standard stuck LOL
  3. Sep 27, 2022 at 9:00 AM
    #263
    Toyko Joe
    Toyko Joe Here for the pictures
    How many sqft is your parents house? Even in the south, I only have a 2.5 ton that cools the whole 1700sqft house more than adequately. Rule of thumb is something like 600sqft / ton / 12000btu for cooling, and if you're in the north east the insulation rate should be more than enough to allow for proper cooling of 2700sqft with 4.5 tons cooling capacity.
  4. Sep 27, 2022 at 11:50 AM
    #264
    PennSilverTaco
    Charlie
    Zillow says my parents' house is 3,352 square feet, but I think that's overstated. Zillow also says that my parents' house has 3.5 bathrooms when it actually has 2.5 bathrooms. I believe it's like just under 3,000 square feet...?
  5. Sep 28, 2022 at 10:19 AM
    #265
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    My personal best is 13 birds from a Lennox Pulse. PB by weight would be a Duck from an oil furnace lol. Nastiest by far was a squirrel, I got most of it anyways.
  6. Sep 28, 2022 at 10:35 AM
    #266
    PennSilverTaco
    Charlie
    Were any of these animals still alive? I heard of a baby owl getting pulled out of a flue pipe here in PA not only alive but unhurt...
    Lt. Dangle[QUOTED] likes this.
  7. Sep 28, 2022 at 11:04 AM
    #267
    Lt. Dangle
    Ohio
    There were no survivors.
  8. Sep 28, 2022 at 11:05 AM
    #268
    PennSilverTaco
    Charlie
    I've also heard of squirrels getting into ductless mini-splits, snacking on the inverters, and getting their teeth welded together by the heat and voltage...
  9. Sep 28, 2022 at 11:06 AM
    #269
    Lt. Dangle
    Ohio
    I should say the squirrel was in the furnace flue long enough for the cat to become extremely interested in central heat according to the homeowner. By the time I showed up in the fall once the home had no heat, it was far too late.
  10. Sep 28, 2022 at 11:08 AM
    #270
    Lt. Dangle
    Ohio
    I've pulled more rodents out of Heat pumps than I can count. Best one was one with no critters, but said critters had stripped every single bit of insulation from the wires, high and low voltage, and the unit was still working lol. That was a mess, but I had to admire the fact that it was still in operable condition.
    Mouse piss is worse than dead mice IMO.
    Toyko Joe likes this.
  11. Oct 7, 2022 at 7:12 AM
    #271
    PennSilverTaco
    Charlie
    Does your furnace look like this? My parents' house has the 1st floor unit located in the basement and the 2nd floor unit located in the attic...
  12. Oct 7, 2022 at 7:34 AM
    #272
    Lt. Dangle
    Ohio
    That's a crappy install job. That humidifier leaks, it is going to drop water all over the furnace. So stupid. No reason the humidifier couldn't be mounted on the return and the bypass to the supply and eliminate the risk altogether.
  13. Oct 7, 2022 at 7:53 AM
    #273
    6 gearT444E
    Deep South
    Herculiner Hootus
    Just about a twin :)
  14. Oct 7, 2022 at 10:16 AM
    #274
    PennSilverTaco
    Charlie
    Did that come with the house or did you pay to have it installed?
  15. Oct 7, 2022 at 10:17 AM
    #275
    PennSilverTaco
    Charlie
    Welcome to the world of tract homes, and what's infuriating is that my parents paid extra for the humidifier...
  16. Oct 7, 2022 at 10:41 AM
    #276
    6 gearT444E
    Deep South
    Herculiner Hootus
    Original to the house, circa 2008 time frame.
  17. Oct 7, 2022 at 10:48 AM
    #277
    PennSilverTaco
    Charlie
    For some reason I thought your house was older. Are you in a subdivision?
  18. Oct 7, 2022 at 10:49 AM
    #278
    6 gearT444E
    Deep South
    Herculiner Hootus
    negative, just a single lot.
  19. Oct 7, 2022 at 11:13 AM
    #279
    PennSilverTaco
    Charlie
    But you bought it new?
  20. Oct 7, 2022 at 11:26 AM
    #280
    6 gearT444E
    Deep South
    Herculiner Hootus
    no sir, second owner i bought in 2015
