PennSilverTaco's HVAC BS MegaThread!
Discussion in 'Garage / Workshop' started by PennSilverTaco, Feb 16, 2021.
  1. Dec 30, 2022 at 6:17 AM
    #401
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Yesterday, I was talking about how some Trane models have a virtually identical footprint regardless of cooling capacity. These are the specs for the XL1400, which hasn't been manufactured since 2002, but as you can see they all share the same height and 2.5-ton through 5-ton have the same width. Even the 1.5-ton unit was fairly sizable at just 9 inches shorter than the other six available sizes. Both the 1.5-ton and 2-ton share the same width, coming in at just 6 inches shorted than the five larger units...
    shakerhood likes this.
  2. Jan 2, 2023 at 11:13 AM
    #402
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Went up to the attic again during a rain storm to check on the roof (all is well) but while i was there i found this box with a broken ignitor Wonder if its J/5 stands for January 05.
  3. Jan 14, 2023 at 10:29 AM
    #403
    PennSilverTaco
    Charlie
    @6 gearT444E
    Goodman heat pump at my aunt's townhouse in suburban Atlanta...
    6262DA68-49CF-46B9-8F80-ACD439413115.jpg 3DE8FB2B-60DF-49DE-A19A-848E8DC7A5DE.jpg
  4. Jan 14, 2023 at 10:55 AM
    #404
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    As one who has built 5 house in the last 7 or 8 years, my recommendation would be to go single story if you are looking to build no more than 1500 ish sq ft. Also I would say my experience with hvac equipment is that the newer systems are all problematic and something will need to be fixed on them in the first couple years.
    if you focus on insulating and air sealing your new house a 2ton unit is plenty for 1500 sq ft provided it’s a single story, if you go two story you will keep the house more comfortable with 2 units and if you go traditional system with zones you will end up wasting energy when the upstairs is the only place that needs the cooling
  5. Jan 14, 2023 at 10:59 AM
    #405
    TacoMTga
    Brian
    Check into Mitsubishi mini splits also as they have a hyper heat model series that the heat pump works down to quite a low temperature and they have traditional style air handlers available on this system as well
    PennSilverTaco[OP] likes this.
  6. Feb 3, 2023 at 4:43 PM
    #406
    PennSilverTaco
    Charlie
  7. Feb 3, 2023 at 4:46 PM
    #407
    PennSilverTaco
    Charlie
    soundman98 and shakerhood like this.
  8. Feb 3, 2023 at 4:48 PM
    #408
    PennSilverTaco
    Charlie
  9. Feb 3, 2023 at 4:48 PM
    #409
    PennSilverTaco
    Charlie
    The oil tank also has to go, as the house was switched to natural gas...
    shakerhood and ColoradoTJ like this.
  10. Feb 3, 2023 at 4:49 PM
    #410
    PennSilverTaco
    Charlie
    shakerhood and ABA180 like this.
  11. Feb 3, 2023 at 4:51 PM
    #411
    PennSilverTaco
    Charlie
    Brand new Weil-McLain gas boiler...
    67C1AF4C-8B69-48E9-BFE9-508D0E931F5A.jpg 5B3B495B-C73E-42A3-9471-A076CD63BCFD.jpg
    soundman98, shakerhood and ColoradoTJ like this.
  12. Feb 3, 2023 at 5:39 PM
    #412
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I think your Grandmother got her money's worth....:thumbsup:
  13. Feb 3, 2023 at 6:00 PM
    #413
    PennSilverTaco
    Charlie
    It was already almost 30 years old when they bought the house!
  14. Feb 12, 2023 at 11:53 AM
    #414
    PennSilverTaco
    Charlie
    @shakerhood
    All but one house in this neighborhood was built by NV Homes from 2013-2017, and all but that aforementioned house has Goodman HVAC equipment. The one house built by a separate builder has dual Lennox units. All but two houses in my neighborhood have dual-zone A/C, and those have zoned systems with multiple thermostats. The twin townhomes across the street were also built by NV homes, and those all have ICP units, which I think are of higher quality than Goodman; I obtained one of these units from a neighbor after the system was replaced due to a rusted and leaky indoor coil. A few original buyers in the townhome development paid extra for two separate systems, but most have one system. There is one house in my neighborhood with dual Goodmans that had one of those Goodmans fail, and it was replaced with a Rheem.
  15. Feb 12, 2023 at 12:03 PM
    #415
    PennSilverTaco
    Charlie
    One Goodman and one Rheem; I have no idea what killed the other Goodman...
  16. Feb 12, 2023 at 2:13 PM
    #416
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think my unit is a Rheem, but will have to double check to verify.
  17. Feb 16, 2023 at 11:45 AM
    #417
    PennSilverTaco
    Charlie
    Yours is a Rheem; Ruud is identical to Rheem I. All but brand name though...
    shakerhood[QUOTED] likes this.
  18. Feb 16, 2023 at 11:51 AM
    #418
    PennSilverTaco
    Charlie
    @6 gearT444E
    @ColoradoTJ
    @Just_A_Guy
    @RustyGreen
    @shakerhood
    @Squatting Pigeon
    @Taco critter
    @TnShooter
    @wilcam47
    When my parents bought the house new, it had a Comfortmaker-branded Snyder General air-conditioner like all of the other houses in the neighborhood. These houses were all built between 1990 and 1993, and amazingly enough a couple of the houses still have the original units 30+ years later. All of the houses in the neighborhood have gas heat, and in 1990 I'm assuming David Cutler Group went with 80% efficiency furnaces. My parents sold the house in 1996, and I had the opportunity to chat with the new owner (who still lives there) a few years ago. The original Snyder General failed in 1999, and the whole system was replaced. The replacement air-conditioner lasted less than a decade and was replaced with the Bryant it currently has; I have no idea how old the Bryant is, but I'm thinking somewhere in the range of 2006-2009...?
  19. Feb 21, 2023 at 10:03 PM
    #419
    Stitchgirl90
    Stitchgirl90 Well-Known Member
    Amanda
  20. Feb 22, 2023 at 9:38 AM
    #420
    PennSilverTaco
    Charlie
    Central A/C unit at a vacant commercial property in Ivyland; I think it's a Lennox...
    861BE6AB-8DF2-4476-926B-D044AFEA7E5C.jpg 37D22D16-AC17-4FA2-9478-3C3A5A39224B.jpg
    shakerhood and TnShooter like this.
