PennSilverTaco's HVAC BS MegaThread!
Discussion in 'Garage / Workshop' started by PennSilverTaco, Feb 16, 2021.
  1. Jun 3, 2024 at 6:06 PM
    #1041
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    No, it was still 22 systems at that point. The real problem I had was the concept of using a gas that varies its pressure with temperature to leak check is just bad on a fundamental level lol. There's a reason Nitrogen is used.
  2. Jun 3, 2024 at 6:07 PM
    #1042
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I've heard of people substituting Freon with propane...
    Lt. Dangle[QUOTED] likes this.
  3. Jun 3, 2024 at 6:11 PM
    #1043
    Lt. Dangle
    Ohio
    Tech 2000, yep. Can't believe I forgot that. Only real problem was they were noisy from rattles on the exterior due to not having enough screws. We used to stick mulch from the flower bed in between the metal and plastic beauty ring on top since it just snapped on lol.
    Good units though. The Evolution units came out a year or so before I switched to a Lennox dealer. The evolution stuff was very high end initially so pretty rare at that time. I will say the generation of 58MVP units was IMO the Heyday of Carrier. They weren't perfect, but far and wide the whole lineup of Carrier stuff at that time was very good.
    I gotta say this thread is a lot of fun, I don't get to reminisce about old HVAC stuff a lot as I don't talk work with anybody in real life. Thanks for letting me relive the old days a bit Charlie.
  4. Jun 3, 2024 at 6:12 PM
    #1044
    PennSilverTaco
    Charlie
    Gas furnace and water heater...
  5. Jun 3, 2024 at 6:13 PM
    #1045
    PennSilverTaco
    Charlie
    Evolution is Bryant and Infinity is Carrier...
  6. Jun 3, 2024 at 6:13 PM
    #1046
    Lt. Dangle
    Ohio
    Propane has an R-value.... Lol.
  7. Jun 3, 2024 at 6:14 PM
    #1047
    Lt. Dangle
    Ohio
    Good lord, lol. Yep. I had switched to Lennox by the time those lines were mainstream so not an expert... obviously.
  8. Jun 3, 2024 at 6:15 PM
    #1048
    PennSilverTaco
    Charlie
    Earlier in this thread you said you want the Rheem/Ruud stamped octagon units in a house you actually lived in due to inefficiency? Aside from the fact that they came out before the feds mandated a 13 SEER minimum, why would they be any less efficient than any other 10 SEER unit? Some of the newer ones were even 12 SEER!
  9. Jun 3, 2024 at 6:17 PM
    #1049
    PennSilverTaco
    Charlie
    I hear the new high-end Lennox units are technologically complex junk. Remember the Dave Lennox Signature heat pumps with built-in solar backup. They weren't on the market very long, so I'm assuming they didn't sell well...
  10. Jun 3, 2024 at 6:19 PM
    #1050
    Lt. Dangle
    Ohio
    They're not really any more inefficient when clean, but the short coils were close to the ground and were prone to getting very clogged. A taller unit like a round Carrier or a Trane had a much better chance of moving more air since they were taller. Just experience of seeing them for too many years. they wore like Iron though, just high head pressures.
  11. Jun 3, 2024 at 6:21 PM
    #1051
    PennSilverTaco
    Charlie
    My aunt's old house had a 1987 Ruud Achiever 10 matched up with an oil furnace. That thing absolutely cranked; I took it apart and cleaned it once...
  12. Jun 3, 2024 at 6:21 PM
    #1052
    Lt. Dangle
    Ohio
    Interesting fact about those if we are thinking about the same units, the only thing solar powered was the condensor fan motor if I recall correctly. We never understood that. We never sold one either. We also sold geothermals so a 17 SEER Air to Air HP wasn't anything we took seriously when a Water to air HP trounced it with little effort. Was more consistent as well.
  13. Jun 3, 2024 at 6:23 PM
    #1053
    PennSilverTaco
    Charlie
    The SEER rating on those was in the 20s...?
  14. Jun 3, 2024 at 6:27 PM
    #1054
    Lt. Dangle
    Ohio
  15. Jun 3, 2024 at 6:29 PM
    #1055
    PennSilverTaco
    Charlie
    I found a video of my aunt's 1987 Ruud that I made back in 2012!
    https://youtu.be/Q6ph4K5KzEI?si=S2y2GBeqwfcGmTjm
    Lt. Dangle likes this.
  16. Jun 3, 2024 at 6:33 PM
    #1056
    Lt. Dangle
    Ohio
    I kind of miss the sound of an old school Reciprocating compressor kicking on lol. When working a tired unit, it always had a bit of will it or won't it there.
  17. Jun 3, 2024 at 6:35 PM
    #1057
    PennSilverTaco
    Charlie
    My grandma lived like a mile away and had a virtually identical (except it was green) 1987 Rheem Classic X that still worked up until the bitter end. She got it replaced like three years ago because it had a leak in the coil...
  18. Jun 3, 2024 at 6:42 PM
    #1058
    PennSilverTaco
    Charlie
    @Lt. Dangle
    Cleaning my grandma's A/C unit was a bitch!
    https://youtu.be/qkQ2LYb5Qs4?si=PUS2rH_AmUAfVr5Y
  19. Jun 3, 2024 at 6:52 PM
    #1059
    PennSilverTaco
    Charlie
    @Lt. Dangle
    Lennox ductless heat pump used to heat and cool the temporary sales office (which will be turned back into a garage once the decorated model is sold)...
  20. Jun 3, 2024 at 7:12 PM
    #1060
    PennSilverTaco
    Charlie
    @Lt. Dangle
    Carrier A/C units at the newly renovated farm house near the 55+ community...
